Question about Frigidaire FGUS2642LF
Frigidaire FGUS2642LF temperature regulation problems
Without any cause my Frigidaire FGUS2642LF freezer and fridge temperature will start to rise. I cleared out some food that was blocking the vent in the freezer & the temperature went back to normal after several hours. However, tonight the vent is still unblocekd and the temperature in slowly getting warmer in the freezer & fridge.
SOURCE: Frigidaire frs24zrh refrigerator not cool enough
Check out partselect.com. need to replace defrost timer and defrost thermostat. good luck.
Posted on Sep 26, 2008
Techsim
  • 59 Answers
SOURCE: Freezer losing temp... intermittent buzzing sound
Either the start device for the compressor is bad or the compressor has died. The easiest way to tell is to replace the start device. It cost around 30-40 bucks and the part number for it is 218721119. In most of these cases its just a bad start device. The start device is located on the side of the compressor in the bottom back of the unit. It will have a capacitor attached to it that you will want to keep and stick on the new one. If you need anymore help just let me know. Good Luck!
Posted on Nov 02, 2008
rpbuice
  • 161 Answers
SOURCE: Fridge not cooling- top freezer frosting over
"Fan in freezer does not seem to be running"
This wiil cause it to frost up in the freezer and this fan is the only way to get cold air into the Fridge area.
Posted on Dec 22, 2008
farfield
  • 462 Answers
SOURCE: Problems with Frigidaire Refrigerator not cooling
In turning it off you may have only closed the air damper. Set it to 1/2 way.
If ice or frost in the air damper area on refrigerator side you may not be defrosting the freezer coil.
Inspect from bottom looking up with a mirror and flashlight. You should have no Ice buildup frost that is even and white is normal. Feel Check the back wall mid way down to 1/4 way to bottom. Push on the wall slightly. Crunching like frost or snow behind wall is not normal. I suspect non defrosting here.
Next eliminate the inside fan motor. It has to run to push air all over the freezer and refrigerator. If this fan doesn't run the results will be only the area with the refrigeration evaporator coil will cool and it may get too cold and resemble a non defrosting situation where the air is not able to circulate because of frost build up.
Next eliminate the Ice maker and light as a source of heat. Unscrew and unplug them
Next eliminate the door gaskets from not sealing. A piece of paper set tween the door and frame and pulled across it and you feel resistance all the way and the gaskets are smooth and not warped they are OK
Next inspect the condenser fan and coil by the compressor underneath. A dirty coil here will cause diminished heat removal and possible for a partial cooling of some of the freezer.
Only after inspecting all these items and determining they are OK should you proceed with refrigerant checking. Also a person with out the ability to measure the actual amount of refrigerant being put in should be shown the door. Even with topping off (adding some) refrigerant I use a scale to determine that I do not put in too much. So if you have a friend that does this and no way to tell how much is too much.... well with all due respect your getting what you pay for.
If this helps you understand your problem and need more information please post back, I will follow up. If it helped you determine your trouble please rate me as high as you can. Thank You for using fixya and good luck.
Posted on Mar 22, 2009
SOURCE: Ice In Freezer Vents
thick frost on the back wall indicates a defrost problem, either with the defrost control, the heater, or the bimetal thermostat. Without personal inspection, i cant tell you which one it is, but i can narrow it down to those three
Posted on Mar 01, 2010
I have a hotpoint FF72P fridge freezer. it comes down to temperature (-22/+4) without any problem, but after this the compressor won't cut in.
takes time for the temperature inside the fridge -freezer to normalize after doors are being left open
turning off a fridge freezer on and off wont help it
it takes time to for the thermostat to kick start the compressor
and more time to reach the freezing temp lost
if you are certain the thermostat is damaged
call in a service man
have the thermostat replaced and have them check
the gas in the system is running the correct pressure
Jul 31, 2016 | Hotpoint Refrigerators
Temp on screen rises & flash high temp.
Hallo
The compressor winding's could also be faulty.
regards
May 19, 2016 | Frigidaire Refrigerators
Model #FGHC2331PF frigidaire. Controls were set for 35F fridge and 0F freezer, but when the fridge stopped the temps went up. They are now at 40F fridge and 5F freezer. Why?
Because nothing is perfect. As soon as the compressor stops running, the refrigerator will start to get warmer as the ambient temperatures will affect it. Then after a few degrees of temp rise, if thermostat is working properly, unit will kick on again to lower temps to preset level. And the cycle continues.
Apr 02, 2016 | Refrigerators
Why does my Hotpoint ff187e frost free fridge freezer lights flash and the alarm sound even after reseting them as per manual. rest them ok for a while but then restart what's the problem?
Fridge keeps beeping or buzzing: The following is for Frigidaire models but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls ·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open ·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset ·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.
Cause of Beeping Noise in Frigidaire Refrigerator eHow
Jul 27, 2014 | Hotpoint Refrigerators
Temperature rising in freezer and fridge motor running constantly
The temperature in the freezer will rise if there is no air circulation. Air circulation stops when the evaporator freezes solid. When this happens the thermostat cn not respond and the fridge keeps running.
Defrost the freezer and see if things return to normal. If they do then you have an auto defrost problem.
A technician can help you with this problem
Apr 01, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Frigidaire freezer cold, refrig in 50's.
Because the model FRT21P5A has a manual adjusting vent I believe your problem is either the defrost heater and defrost thermostat and or the cold control (thermostst) is not working correctly. When temperatures rise in the refrigerator side first that is a sign that the air flow from the freezer is restricted. You will need to unplug the refrigerator and remove the rear panel in back of freezer to confirm. If Iced over use a hair dryer to defrost and disconnect one wire on the defrost heater. Check the defrost heater with an ohm meter. You should get a reading. If defective and no reading you need to replace the defrost heater and defrost thermostat. Let me know what you find, Thanks Sea Breeze
Jul 19, 2009 | Frigidaire FRT21P5A Top Freezer...
The temperature of my fridge and freezer is rising even though I've pressed the set button to reset the temperatures.
u may have a defrost problem without model number it would b hard to figure out you may remove freezerfood to another freezer. and unplug box leavefreezer door open over night
Jul 08, 2009 | Refrigerators
Does outside temperature affect performance of freezer
Top mount refrigerator installed in a garage and the food in the freezer is defrosting when
the temperature in the garage goes below 55 degrees fahrenheit.
On top mount refrigerators you cycle the compressor and fan/fans from the food
compartment temperature. When the room temperature gets colder than 55 F, you have
long off times waiting for the food compartment to warm enough to trip the cold control.
This long off time is allowing the freezer temperature to get high enough that food can start
to defrost.
There is a kit for refrigerators installed in applications where the temperature can go as low
as 34 F and still maintain good freezer temperatures. The kit part number is 5303918301
and it contains a heater that mounts in the control box and an instruction sheet advising
how to install the heater.
Kit 5303918301 contains:
Part # 5303950194 Instruction sheet
Part # 241532101 Heater
Nov 21, 2008 | Frigidaire FRT21H8 Top Freezer...
Zanussi Electrolux frost free fridge/freezer - freezer defrosting
My husband left the freezer door open a couple of months ago, causing ice to form. The loud rattling noise was the fan hitting the ice. The reason why the temperature started to rise but the noise stopped was because the fan had got stuck in a block of ice and was no longer working. Simple solution - defrost the freezer for 24 hours. Touch wood, it is all working fine now!
Aug 29, 2008 | Zanussi ZI921 / 8FF Bottom Freezer...
Frigidaire FGUS2642LF Logo
82 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
