Question about Motorola Mobility H385 Bluetooth Headset
When trying to pare blue light turn of - Motorola Mobility H385 Bluetooth Headset
How do sync with my new phone?
1. You must start with the headset in the OFF position. Put the headset in pairing mode by Pressing and holding the Multi-Function Button until the lights are flashing alternating Red and Blue, you will then release the Multi-Function Button. Please note the headset will continue flashing Red and Blue until the paring cycle times out (approximately 2 minutes) or completes the paring with the cell phone. If you only press and release the Multi-Function Button the headset will not go into the paring mode.
2. Once the headset is in paring mode, go to the Bluetooth menu / connections of your cell phone. Select add new / search for / find new device (different phones have different but similar names for the options). The cell phone should find a device called VXi B250-XT. Move the cursor over the VXi B250-XT and press (OK, select, enter, or whatever your phone uses for a prompt). If the cell phone asks for a passkey code you will put in 0000 (four zero's). The headset will then pair and connect to the cell phone and be blinking Blue once every second. Your phone may ask you if you want to connect to the B250-XT and/or add it to your trusted device list, press (OK, select, enter, or whatever your phone uses for a prompt).
Aug 01, 2011 | VXI Corporation Blueparrott B250-XT...
MY VOYAGER PRO .. LIGHT FLASHES BLUE RED BLUE RED ... CAN'T TURN OFF, CAN'T RESET, CAN'T RE PARE
If you manually turn the headset off, make sure that it is by itself, no other phones in the area, no WiFi hotspots. Once this is done make sure that there is not a bluetooth already installed on the phone itself, if there is, delete it. Make sure that the headset has a full charge. Try the pairing again. If this still won't work, you can try Plantronics Tech service line 800-544-4660.
Here are two links that may be helpful:
Plantronics Voyager Plus User's Guide
Plantronics Voyager Plus Pairing Instructions
Good luck from Headsets Direct!
Jun 04, 2011 | Plantronics Voyager PRO Bluetooth Headset
I have a samsung SHP-M800 and i am trying to set my bluetooth (plantronics explorer 233)?????????????????????????
Hello my friend.First you must turn the bluetooth feature on your phone to on and find a setting invincible/discoverable/seen by other devices and turn it on too.Next, hold the call button on your bluetooth until the light begins flashing blue and red, this means it it in paring mode.Then find the plantronics device in your phone(scan for bluetooth devices). Select your bluetooth headset and enter the password (0000) when it asks it.
Feb 09, 2010 | Samsung SPH-M800 Cell Phone
What does 2 flashing blue light mean on the S9.
Blue (three flashes) powering on/enabling indicator light
Blue (steady) pairing mode
Blue with 10 quick purple flashes
pairing successful
Blue (long flash)
standby (connected but not
on a call or streaming music)
Blue (quick flash)
incoming call
Blue (long pulse)
on a call
these are all the normal blue flashes that the s9 makes
Dec 10, 2009 | Motorola Mobility S9 Headphones
Cannot pair
if you can pair this device go to paring mode by pressing the answer/end key and the volume up( +) key at the same time over 5 seconds until the blue indicator light lights up.
after do this try to paring again.
Jul 20, 2009 | Nokia HS-36W Wireless Headset
Pair 3xx plantronics with my phone
turn on blue tooth on mobile first..then press and hold the power button on plantronics untill the light flashes red and blue alternatively...then search for bluetooth from mobile and pair and if asking a code enetr 0000..
Feb 26, 2009 | Plantronics Explorer 320 Wireless Headset
HELP....
Well my user manual for HBM-550 says:
Prior to using the Headset for the first time, you must pair it with a Bluetooth enabled handset.
With the HBM-550 off, press and hold the Pwr/End button for 5 seconds,
You will hear two short beeps and the LED indicator will flicker in red and blue alternately, when the divice enters Paring Mode.
Using your Handset, find the Bluetooth Menu and "search for" or "add" new devices.
Select "LG HBM-550" from the list of devices and pair it with your handset.
When asked for the pass/PIN code during the paring procedure, please enter "0000" (4zeros).
Once paring has completed successfully, you will hear a beep.
After paring successfully, be sure to "Connect" to the HBM-550.
If you want to pair with other devices in the future, the headset must be placed in pairing Mode.
If the HBM 550 is in "Paring Mode" for 3 minutes, without being paired to a device, the Headset will automatically turn off.
Aug 13, 2008 | LG HBM-550 Wireless Headset
I have a blackberry curve and am wanting to pair my bluetooth HS850 to it. Please help!
There actually is a trick to the HS850 - flip the boom closed, then hold down the button just until the light holds solid - IMMEDIATELY after it does flip the boom open and this should keep the light solid. Then on your cell/device search for bluetooth devices - you should be able to find it now. Passkey for most devices is 0000.
Jun 30, 2008 | AT&T Blackberry Curve 8300 Smartphone
Paring blue tooth hands free
The defualt code is 1234,pls, make it sure that the device is shown to all and not hidden....
Mar 29, 2008 | Nokia N70 Cellular Phone
LG HBM 550 with Chocolate
Here is the problem, what most of the people do with this LG HBM 550 is press the PWR/END button on the headsent and when the headset light turn on Blue they let the button go and try to pair the device, this is worng when light is flshing Blue only it is not in the pairing mode.
You need to press and hold the button on the head set for five second and when the light flicker red and blue alternately, now device is in the paring mode.
Using you phone when to pair this device it might ask, depending on you r phone setting for the PIN or pass code which will be "0000"
Try ,,good luck
Regards
Chinmay
Nov 22, 2007 | LG HBM-550 Wireless Headset
Motorola Mobility H385 Bluetooth Headset Logo
14 people viewed this question
Top Motorola Mobility Radio Communications Experts
Coss
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
