Question about Braun Syncro 7680 Electric Shaver
Shaving timer is not working -- nothing displayed
The display is supposed to count the number of seconds/minutes of your shave when the shaver is turned on. However, when I turn on my shaver, the display doesn't count. It just keeps showing the charge level and "TEST". I can run the demo, as well as demo 2, but when I press the button to stop it, the last info shown in the demo is displayed.The shaver had gone into deep discharge due to a switch problem. I replaced the switch and it worked fine after that, except for this weird display problem. IS there some technique to "reset" the processor?
3 Suggested Answers
Cytherian
  • 109 Answers
SOURCE: Looking for a service manual for the Braun 7570 syncro razer
It's actually easier than it looks. On the bottom of the shaver is the charging port. That black plastic piece surrounding it can be pried off. Do it carefully, so you don't dent/scratch the casing. Once removed, the side pieces easily remove. You'll now see screws holding the body together. Have at it. :-)
Posted on Nov 07, 2010
Cytherian
  • 109 Answers
SOURCE: Clean and Renew stand for braun 8595 does not seem
The circuit board on the shaver may have become faulty. One thing you can try is to fully charge the shaver first, directly connected to the outlet, and then try using the cleaning base. Also, be sure that the fluid level is sufficient. Lastly, you may be able to buy a used but working condition cleaning station off of eBay. New replacements are a bit costly.
Flashing head message
This signal reminds you to replace the shaving heads of your shaver. New shaving heads guarantee continued optimal shaving performance.
What reminder signal your shaver gives depends on the model. Some shavers beep, while others show a flashing shaving head symbol on the display. Some with red half circle arrows, around the 3 shaving heads, or a flash of the 3 shaving heads. There are also models that beep and show a reminder signal on the display at the same time.
How to reset the reminder signal:
The replacement reminder is repeated at 7 to 10 successive shaves, depending on the model.
In some models, you can reset the razor. Press and hold the On/Off button for approximately 10 seconds.
If the shaving head symbol is shown in combination with an exclamation mark ("!") and a faucet symbol, it means that the shaving heads are blocked. When this happens, you have to clean the shaving heads or replace them. (Note: Only certain models have this feature)
Hope this helps, as mine is doing the same thing now.
Jun 22, 2013 | Philips Norelco 1250x Sensotouch 3d...
Shaving with an electrical shaver is considered to bet wet or dry shaving?
Most electric shavers are dry, meaning that you don't need any gel or a shaving cream in order to shave although there are some unique wet electric shavers' models on the market.
Feb 06, 2013 | Health & Beauty
What is an electric shaver?
Not like shaving razors, electric shavers work by shearing the whiskers, the hair enters the perforated metal heads of the shaver and is cut by the moving blade inside.
A red light is on at the lower-right corner, with a shape of the heads. does it mean it is time to relace the heads? how does the machine know?
It's menas that you change new replacement heads. That philips arcitec 1060 electric shaver replacement heads is Norelco RQ10 shaving heads.
Jul 30, 2011 | Philips arcitec 1060 Electric Shaver
What does a flashing red light at bottom of display when you turn razor off mean looks lit the 3 rotary blades
It means they want you to buy a new shaver head. U dont need too, and the light will automatically go off after 7 shaves from when it first came on.
Mar 06, 2011 | Norelco Arcitec Electric Shaver -...
Can i use shaving cream with a norelco electric shaver?
According to the Phillips website, it is NOT a waterproof shaver, therefore it is not advisable to use any liquids prior to or during shaving.
However, as a hairdresser and having experience with shaving men for many years, you can use the tried tested and true method of either shaving AFTER you get out of the shower so that your hairs on your face are softer from being in the moisture, or if you are not planning on having a shower, you can just use a hot face cloth on your face for a few minutes before you shave. This will soften the bristly hairs on your face and make it easier to shave.
I hope this helps. Please remember to rate my help. I would greatly appreciate it!
Apr 26, 2009 | Philips Norelco Micro 5625 XL Electric...
Red L.E.D light won't stop flashing
Shaving head check indication After two years of use the red shaving unit symbol î will flash for 30 seconds during 7 shaves to indicate that you should check the condition of the shaving heads. This indication is based on an average shaving time of 3 minutes per shave. When the shaving head symbol flashes, all other symbols and lights are out. When the shaver is switched off, the shaving unit symbol disappears. When the red shaving unit symbol starts flashing, you should check the shaving heads for possible damage. If the shaving heads are damaged in any way, they must be replaced in order to obtain optimal shaving results
Nov 20, 2007 | Health & Beauty
Replace heads light
I have been able to reset the replace head light on my 8894xl shaver by do the following: Step 1 - Fully charge and clean shaver Step 2 - Turn on shaver holding down on button until shaver display recycles from 0 to xxx minutes. Step 3 - Turn shaver off Step 4 - Turn on shaver again and hold down button until shaver beeps ONCE. (Light will go off)
Jun 09, 2007 | Norelco 8894 XL Electric Shaver
Braun Syncro 7680 Electric Shaver Logo
27 people viewed this question
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
