Getting carriage jam message but no jam - Office Equipment & Supplies
SOURCE: error - carriage jam message
My Photosmart 2610 just started having this same problem today. As many of you have done, I also went to the hp support website and tried just about everything. Finally I discovered the answer to my problem on my own. Here's what I did (you might want to have a wet rag handy to wipe the ink off your fingers):
1) With the printer on, I pressed "okay" to clear the error message. You should immediately hear the sound of the carriage (the contraption that holds the cartridges) moving inside.
2) Open the print cartridge access door (the main access point for the cartridges) and confirm that the carriage is indeed moving.
If the carriage won't move at all, I'm not sure that this solution will help you. However, if the carriage moves from side to side after you press "okay", please read on.
3) This is unorthodox, so bear with me: when the carriage moves away from it's "resting place" (in my printer it's on the right hand side) and is near the center of the printer, unplug the power cord from the printer. The purpose of this is to free up the undercarriage (which was the part that actually was jammed on my printer).
4) Ensure that the carriage moves freely from left to right and right to left by pushing gently on its sides.
5) Move the carriage to left side of the printer so you have room to access the undercarriage.
6) It might be helpful to have a flashlight or some other light targeting the undercarriage for this next part. If you look directly underneath the undercarriage, you should see a foam/spongy product resting in the base of the printer. The purpose of the sponge is to absorb any ink that escapes from the cartridges. Herein lies the problem: over time, as the undercarriage adjusts to enable the carriage and its cartridges to do their work, the undercarriage gets caught on the inky sponge. Note that the undercarriage is fragile, but is moveable by gently pushing it toward the front or back of the printer.
7) Adjust the undercarriage so you can see the sponge and the "axel" (for lack of a better term) that turns to move the undercarriage forward and back. It may take some detective work, but you should be able to determine where the sponge is supposed to lie. Your goal here is to push the sponge down as far as it will go so that it won't obstruct the movements of the undercarriage.
8) On my printer, there was also a small amount of sponge wrapped around the "axel" that prevented it from moving smoothly. I unwrapped it and double-checked that nothing else was obstructing movement.
9) Final step: leave everything where you moved it, shut the lid, and plug it back in. A little prayer never hurts either. Good luck! AIM ID if you need more help: GnarlyVeaux
Posted on Mar 10, 2008
SOURCE: How do I get fix a "carriage jam"?
I was able to run run a piece of photo paper through a couple of times and printer now seems to be working again. The theory was that running a heavy piece of paper through might help clear little piece of paper that was not visible. The photo paper is less likely to tear if it gets jammed too.
Posted on Apr 20, 2008
SOURCE: carriage jam message
I removed the cartridges and cleaned them. Powered on with a full reset, and Voila!
Thanks to all who posted other suggestions where I got the ideas.
Posted on May 24, 2008
Carriage keeps jerking back and forth with message of carriage jam
Posted on Oct 09, 2008
komguy
  • 2306 Answers
Sorry about the B.S., you can move the carriage by hand, and all you need is to clean the encoder strip that runs across behind the carriage assembly. You can wipe the strip gently with an alcohol swab or a Q-tip moist with alcohol. The bars on that strip tell the carriage where it is and grease or ink on it will give the carriage jam error. No calibration necessary after moving the head or cleaning the strip.
Posted on Jan 15, 2010
I just changed the (2) ink cartridges in my HP PCS 1610 All-in-One HP printer and now get an error message "CARRIAGE JAM - OPEN DOOR. CLEAR CARRIAGE JAM, AND THEN PRESS OK." I don't see any jam...
Have you tried moving the carriage to see if it really is jammed? Maybe you haven't put the levers down properly on your new cartridges....remove them, see if the carriage slides, then refit them and check the carriage again. You wont visually 'see' a carriage jam,; you have to try moving it. By the way, if it doesn't move, DONT force it to try and overcome the jam try and reason out why it doesn't move.
Hope this helps!
nicam49
Jan 18, 2011 | HP PSC 1610v All-in-One Printer
Carriage jam - Turn machine on, get carriage jam message, however the carriage can move freely if moved by hand. If I close and hit enter, carriage sounds like it's moving, then I get the error message...
Jan 07, 2010 | HP OfficeJet 7410 All-In-One InkJet...
Paper Jammed. Have appeared to remove all paper. But I keep getting "Carriage Jam, open door, clear carriage jam then pres OK" message. Message on my computer screen says "The print cartridge carriage is...
HP support has extensive documentation for both paper and carriage jams for your model:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00304007&lc=en&dlc=en&cc=us&lang=en&product=391182
I hope this helps!
Dec 10, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Error message carriage jam and/or paper jam
Often a carriage jam is caused by a paper jam. If you're getting a carriage jam message and a paper jam message, this video should help.
utube.png You-Tube video "wPjahOY5CDo" placeholder
Nov 21, 2009 | HP Photosmart C6380 All-In-One InkJet...
HP 7410 Poor printing, carriage jam message(fake), loud noise
Check the plastic strip that you'll see along the carriage track. Make sure it's clean. Take a soft cloth and dampen it. Run it up and down the strip and make sure it's clean. If there's any ink on it, it could cause carriage jams. The strip has tiny lines on it which tell the electronics where the carriage is. If the strip is dirty, you'll get jam messages and sometimes the carriage will slam against one end or the other.
Apr 13, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Carriage Jam
If either a paper jam or blocked carriage error message appears on
the control panel display, there might be some packing material inside the HP allin-
one. Lift open the print-carriage access door. The orange shipping lock might
still be in place on the left side of the HP all-in-one. Pull out the orange shipping
lock and throw it away
Jan 04, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Can not get by carriage jam message
I had an old HP printer and it would say the door was open or the cartridge jam. It turned out the cartridge was too far to the end of its belt cycle. It is weird, but I put a finger space width between the cartridge and the wall of the printer and then it read it correctly. Go figure. It would get off cycle whenever I replaced the ink cartridge.
Jun 04, 2008 | HP Photosmart 2610 All-In-One InkJet...
Carriage Jam
Make sure you can move the print cartridge holder freely and that it isn't being blocked by anything inside the printer, also check if the cleaning station is in the right position, maybe it is locking the cartridges.
Apr 22, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
HP Officejet 5110 - Carriage Jam Message
I have an Hp Officejet 5110. I have an error message saying "Open door,clear carriage jam, then press enter". But where is its door? How can I clear the carriage jam?
I tried pressing the # & 6 at the same time, but the error message still there.
Mar 09, 2008 | HP OfficeJet 5110 All-In-One InkJet...
10 people viewed this question
k24674
jasbo
jasbo
