Question about ZTE Cell Phones
Zte midnight z768g wifi connection problem
Will not connect to my home WiFi. Put in pass code and nick name. Says obtaining IP address then says disabled, secured with WEP.
3 Suggested Answers
SOURCE: Samsung Galaxy GT-I9000 keeps trying
  • Go into settings
  • Wireless and settings
  • Wi-Fi settings
  • Click on the menu botton and select advanced
  • Select use static IP
  • IP address would be a random IP address from your wireless router
  • Gateway would be the gateway address from your wireless router
  • The netmask is your subnet mask address
  • The 2 DNS addresses are your Default Ip address from your own router and wireless switch
  • If you have issues copy the details from the Ipconfig /all command from Dos
Posted on Jan 02, 2011
anwarocks
  • 220 Answers
SOURCE: galaxy mini won't connect to home wifi. I get a
Enable Wifi connection in your PC.
Posted on May 25, 2011
What is the IP, SSID, and code number's? SE24FL
you be doing wifi
im a very networking guy, retired. (certified)
first say what you are attempting to do with what
what computer;
what ?
rhw IP is the IP address. 2 classed intErnet and intrAnet.
SSID is the broad cast wifi node name.
sent out from the wifi router
what code ?
se24sl is a TV set
so what are you doing to it
let me guess,the TV asked this?
joining your homes local wifi,
sure you must know all that..
on ours only SSID, and pass phrase
if not know,and you must know it
we us our PC and browser go into OUR router
and get that information
on my home TV we built in our home a giga lan, wired network
no long inS, we plug it in and it screams.SO SIMPLE.
no neighbors can noT over load our wifi, kiilling my netlix,,vudo And hulul.
USING WIFI,takes more skills and heartache.
I put my router on highbands away from neighbors, is one trick
also wifi has many modes.
ad hoc
hotspot , 1 button connect
or full encrypted , mode.(me with 20 digit random pass phrase)
ive no idea at all how your router is confiigured.
Feb 11, 2017 | The Computers & Internet
I have had Wi Fi on my Kindle Fire and now it will not connect and keeps asking for an IP address
See if this article helps you.
http://classroom.synonym.com/ip-address-kindle-fire-15120.html
Jul 12, 2015 | Amazon Kindle Fire HDX 7
My zte z768g is showing wifi error. how can i fix that?
Make sure the wifi connection setup in your ZTE is still working, and you are close enough to the WiFi router to receive the signal. I assume the connection worked before.
Be aware WiFi can become bad when the router is not in the same room. Concrete walls are killers for WiFi signals.
Mar 27, 2015 | ZTE Cell Phones
How can I connect WiFi router to office network?
On your computer wireless card configuration, try changing the fixed IP address to the following -.
In the TCP/IP Protocol set Obtain an IP address automatically and set Obtain DNS server address automatically.
Jun 25, 2012 | D-Link DIR655 WiFi Router 4port switch...
Unbranded 7" wireless book can
I have the same problem. The only way I could get it to work is to click on the wifi icon. Select the wireless information tab, select your connection. Right click on it and delete it. Then Add new and reinstall. Right now I have to do this every time I power down or 'Suspend' but it does work.
Jun 02, 2011 | Computers & Internet
I put in the wep key put it doesnt let me in wifi and what is ssid how do i put wifi manualy
The Nintendo DS only supports certain types of Wireless Security, the Nintendo site specifies what version DS supports what versions of Wifi Security
An SSID is the name of your wireless network, so it's what you see when you try to connect to a wireless network at your home
to put in Wifi manually you have to put in the SSID, Wireless password, and depending on if your router is set up as manual or automatic, you may have to put in your IP Address and Subnet mask and finally you need to put in a primary DNS server, your primary DNS server IP Address is the IP Address of your router.
Mar 30, 2011 | Nintendo DS Lite
Samsung Galaxy GT-I9000 keeps trying to obtain ip address from home wifi but does not connect, but at work it connects to work wifi with no problems. Work is using a WEP encryption but my home is using WPA...
  • Go into settings
  • Wi-Fi settings
Nov 25, 2010 | Samsung Galaxy S GTI9000 Smartphone
Can't get my Sylvania 7" netbook to connect to internet using my Linskys WiFi. think I may not have correct IP Address or Server names.
If you think you may have an incorrect ip address, that probably means you changed it by setting a static address. Most systems (with the exception of business systems using domains), use auto ip addressing. Logging on to most wifi hotspots and most home wireless routers requires auto ip addressing. To set yours to auto (this is with XP, I think Vista and Windows 7 is similiar, you just find the controls in slightly different places) go to Control Panel, then to network connections, then right click on the 1394 connection and select properties. In the new pop-up box, if it is not already selected, select tcp/ip and then click properties. (You can also double click the tcp/ip item). In the new pop-up box, make sure both "obtain ip address automatically" and "obtain dns server automatically" are both selected by using the radio buttons. Click Ok on both pop-up boxes to close. While you're in the area, the control panel should still be open. Double click "internet options." Then click on the connections tab, and towards the bottom, click on the lan button. On the new pop-up box, uncheck automatically detect settings. This usually makes you wired connection faster.
Sep 10, 2010 | Computers & Internet
Connecting PSP to wifi
Change the primary DNS of your PSP to 4.2.2.1 and secondary dns to 4.2.2.2
Apr 25, 2009 | Linksys WRH54G Wireless Router
Cell Phones Logo
107 people viewed this question
Top ZTE Cell Phones Experts
john smith
Nyte_Ryder
vince
Are you a ZTE Cell Phone Expert? Answer questions, earn points and help others
