Question about JVC Car Audio & Video
Jvc kdr616 input not changing - JVC Car Audio & Video
I have a JVC RX-7010V AUDIO/VIDEO CONTROL RECEIVER. And I can not get it to hook up to my TV for surround sound I have to hook it up through my headphone jack on my TV.
On the back of the JVC receiver, there should be a TV input, Coax IN and OUT or AUX input (I don't remember if this model had HDMI). On the back of your TV, there should be an AUDIO OUT, connect this to either the TV or AUX inputs and make sure on your TV, to set the Audio Out is On in the TV menu. Turn on JVC and set input to TV and adjust volume. Another way is using the COAX input and outputs. Connect Output of cable box to Input of JVC, then connect Output of TV to Input on TV.
May 15, 2016 | JVC Audio Players & Recorders
Is there an external battery on the JVC MZ-V10 microphone that needs to be changed from time to time ? What is the little button for on the microphone?
The JVC MZV10 Stereo Microphone is an external microphone that's compatible with JVC HD EVERIO camcorders that feature an accessory shoe and a mic input with plugin power capabilities.
Mar 05, 2014 | JVC Audio Players & Recorders
Jvc hd56g786 channels stuck on digital cant get them changed to analog
Using the television's remote control, enter the user's menu. Search for video input and change from cable to antenna. If still experiencing difficulty, visit the JVC website and download the owner's manual to learn the procedure of changing the video input type and deactivate the television's digital decoder.
Dec 22, 2013 | JVC Televison & Video
JVC LT-40A320 FLAT PANEL BURN-IN
Change input device to some other you know really works. If problem persists, this may need attention by a qualified technician.
Jul 26, 2012 | JVC Televison & Video
My jvc cd reciever model #kdr616 has for some reason decided to constantly blow the 15amp fuse on back of the unit. can you point me in thev right direction to rectify this problem. thanks
Hi dionsparky,
If your replacement fuse has an exact current ratings and yet immediately blew after an installation, this is an indication of shorted parts in the supply voltage line. Most likely it was caused by shorted output IC which is mounted in the heatsink. If your handy with electronics and have some necessary tools, pull-out this IC by deslodering it to the board and try the unit without this parts. If the fuse does not blew and finally the unit power up, you must replaced this IC and your unit will back to normal again.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
May 27, 2011 | JVC Car Audio & Video
I want to change the video output setting to S-video on my JVC AV32820, but I can't find that on the tv menu. The only status choices I have are Standard, Choice, and Theater. None of these make a...
When you have an S-video input you often won't have a feature (menu) selection for that function specifically. The S-video is usually an alternative input for a specific video input. e.g. Video 1, Video 2 and etc. The action of actually inserting the S-video cable will select that function automatically. Make sure that your input matches the video input that you have selected and just hook it up. It will work.
Mar 29, 2010 | JVC AV-32820 32" TV
No sound from unit and no video from dvd input
You can try to change input to another open input on the receiver, does it pass the audio or video?, if it does it would appear that the JVC DVD input has failed.
Mar 03, 2009 | Denon AVR-3300 Receiver
Hooking up Xbox 360 to JVC TV 20 inch 1 year old tv from Luxembourg
change the plug on the back of your xbox 360 from hd to tv unless of course your tv is hd then change it to hd :]
Jan 27, 2008 | JVC TV-20241 20 in. TV/VCR Combo
Car Audio & Video Logo
26 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
