Question about Acer Computers & Internet
Replace hard drive acer aspire 5552-7803 - Acer Computers & Internet
SOURCE: Acer Aspire 5100-3583
What size drive is in it now? The user manual should tell you what size drive it can use. If you are not sure, the best thing to do is to go back with the same size. The brand does not matter. Is your hard drive IDE or SATA? What is the model of your laptop?
Posted on May 31, 2008
preachw996
  • 1179 Answers
SOURCE: My Acer Aspire 5100 Laptop wont detect the hard drive
If it works on another computer then either the ide cable in the acer is bad/loose at either end or the ide controller on the motherboard is bad. I would try a known good ide cable first as if this is the problem it is fixable alot cheaper than a motherboard. Hope this helps.
Posted on Mar 27, 2009
  • 121 Answers
SOURCE: Replacement Hard Drive
you would need a 2.5" sata hard drive. whatever size you prefer.
Posted on Apr 24, 2009
Stalcup
  • 20 Answers
SOURCE: need to replace acer aspire 5314 hard drive.
You need a 2.5" 150 Gigabyte drive; however, those laptops are prone to a short in the serial connection from the motherboard. This is an almost impossible task for an novice user to change a motherboard and the cost is not worth it. I installed a new hard drive and although the laptop recognized it, it still will not recognize it and load the operating system. Tested drive on another laptop and it works flawless. The hard drive became bad from the short which you can sometimes hit the bottom of the unit and make it work long enough to backup the data.
Posted on Nov 29, 2009
  • 389 Answers
SOURCE: How to replace Acer Aspire 5630 Hard Drive
The link below gives you the user manual. On the computer views is the base view which will show you the correct bay on the bottom of the computer. You will loosed the screws to that bay, remove the cover andl you will see the hard drive. Althought I have not removed this particular laptop hard drive, these drives usually pull up or back using a tab provided. The hard drive will probably have a cradle the actual drive is connected to. You will have to removed the old drive from this cradle and put the new drive back on the cradle exactly the way the old drive was attached,
I hope that this information helps and gives you a place to start solving your issue.
Brian
Posted on Jan 24, 2010
Remove hard drive Acer aspire e1-472 laptop
In that case it is probably under the keyboard.
6 minutes into the video you can see the hdd
how to replace hard drive laptop acer Aspire E1 472 replace RAM
Mar 13, 2015 | Acer Aspire E1-472G-6648 Misty Silver 14"...
Can a hard drive be fitted to an Acer Aspire One.
There are replacement hard drives available. Here is a video explaining how to find and replace it on the Acer Aspire One. Hope that helps!
http://www.google.com/url?sa=t&source=web&cd=3&ved=0CFsQtwIwAg&url=http%3A%2F%2Fwww.youtube.com%2Fwatch%3Fv%3DVFnIVZn3Wqk&ei=pQczTqrjHOu20AHouNXzCw&usg=AFQjCNEtkrqcv-miIBt5rxZAiXFYfOTQgg&sig2=aiAS34xek9zas8yvG0R2ew
Jul 29, 2011 | Acer Aspire One PC Notebook
How do i remove the HD in my Acer netbook to replace it?
Removing the hard drive from an Acer Aspire notebook just takes a few minutes. here is how:
> ? Turn the Acer Aspireoff. Unplug all cables attached to the system and turn it face-down. Remove thebattery. ? Remove the screws holding down the hard driveaccess cover and pull the cover away. The location of this cover varies frommodel to model, but it is readily visible on the back of the computer. SomeAcer Aspires' hard drive bay covers have only one screw; others have two. ? Grab the hard drive andpull it out at an angle. On most systems you need to push the drive to the lefta little bit and then pull up. Handle the hard drive from its sides. ? Replace the hard drivecover and screws. Put the battery back in and return all cables to theiroriginal location.
Nov 14, 2010 | Acer Aspire One Netbook
Acer Netbook OS
if you are getting this message about corrupted partitions, you need to check and possibly replace the hard drive. There is a program to check the hard drive called Hard Disk Sentinel. It is designed for SSD hard drives like the Acer Aspire One has. Yours has a 160GB hard drive in it now.
Mar 26, 2010 | Acer Aspire One Netbook 8.9" Notebook
Brian
Jan 24, 2010 | Acer Aspire 5630 Notebook
Apr 24, 2009 | Acer Aspire 3680-2682 Notebook
Internal hard drive replacement for an Acer Aspire 4720-4825
Try here ...I think you may like these laptop hard drives....Good Luck and let me know how it works out for you..
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&DEPA=0&Order=BESTMATCH&Description=laptop+harddrive&x=0&y=0
Mar 26, 2009 | Acer Computers & Internet
Computers & Internet Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
