Question about Heli-Max MD-530 Flybarless EP Tx-R HMXE0814
Heli-max md-530 will not bind with heli-max tx610
Will not bind to heli-max tx610
How do I trim it for stable fight?
try here, helped me loads with my slightly bigger 450 trex, the link is specific to your heli though, hope it helps :)
Sep 01, 2015 | E-Flite Blade 120 SR Electric BNF...
Can you bind the Heli max Helis to a D6i transmitter
Yes, you need to buy an AnyLink transmetter that will plug in the trainer plug of your tranmitter.
I put a web link to Tactic anylink products that can be order from internet from online hobbyshop, look in the Where to buy tab on anylink website. Have fun :-)
Dec 09, 2013 | Heli-Max MD-530 Flybarless EP Tx-R...
Front led light just blinks
Make shure transmitter is on and ready BEFORE powering heli and let rest the heli without any mouvement while and after powering up ( gyro setup ). Receiver maybe need to be bind for it to work, look for binding procedure in manual.
Nov 24, 2013 | SWANN Micro Attack Military Blue Gyr
SONY MDS JE 530. (C14) Toc error.
You may well be right. Try a different brand of disc.
Apr 01, 2013 | Sony MDS-JE330 Mini Disc Player
My helicopter will not hover!
If I understand what you're describing, the heli will fly properly at the start of each flight then becomes non-responsive and crashes. When you begin again, the same thing happens.
If that's correct, then it sounds to me like the heli is flying out of range of the transmitter. Check the batteries in the transmitter. If the batteries are ok, then check the distance to be sure you're staying within range. If you are within range, are you remembering to turn on the transmitter before connecting the heli battery? Did you properly bind the heli to the transmitter? Any other flyers in the area that could be causing interference? Power lines nearby?
Another thing, if it does fly out of range, and if your heli is properly trimmed, it should stop and hover. If it's not doing that, then check that your controls are in the proper position before connecting the battery.
Hope this helps.
Randy
Please remember to rate my response.
Aug 08, 2012 | Align T-rex 100x Microhelicopter Super...
My helicopter 9053 will not connect to my controller
The receiver is not binding to the transmitter. Make sure the batteries are in good shape in transmitter. I'm assuming it's a 2.4GHz radio frequency.
When you are about to fly, turn transmitter on first after 4-5 seconds turn
heli on or plug battery in on heli. In the manual there should be a page describing radio binding. It will describe on what gimbles to move and
in certain sequences to complete the process. When the light on transmitter stops flashing means the binding process is complete.
Hope this helps.
Dec 15, 2011 | xheli 9053 Outdoor Volitation Metal...
I have just bought a kds 450 sv helicopter and when i turn it on and plug it in it just beeps and a red light flashes on the kds800 gyro .nothing else happens any help with this would be greatley...
Me too i just boight one with the flymentor built in and same it just been and nothing happens, ive tried everything re binding but the binding been not to be working either it says to connect the jumer to the bind pins and it will flash red but it doesent?
Any help would be great same as the guy above...
Thanks in Advanceds....its just a nice awniment at the moment....
Feb 17, 2010 | Air Hogs Havoc Heli Helicopters
Power adapter i need a power
SPU65-105 SINPRO Stock 1 75.00 75.00
Lodi, NJ 07644 USA
Tel - 1-973-779-8282
Fax - 1-973-779-1490
135 Pasadena Avenue
TRC Electronics, Inc.
www.trcelectronics.com
This is the replacemnt power supply for this monitor.
Jul 20, 2008 | Max Displays MD-218 (Gray) 18.1 in. Flat...
Heli-Max MD-530 Flybarless EP Tx-R HMXE0814 Logo
53 people viewed this question
Top Heli-Max Toys Experts
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Heli-Max Toy Expert? Answer questions, earn points and help others
