Question about Kenmore Elite HE4 Electric Dryer
The dryer stops
When loaded with wet clothes it stops after 20 seconds. If I press on the door it will not stop.
  • Kenmore Master
  • 2,475 Answers
I would recommend you have someone take the dryer completely apart and clean the lint out. In the last 3 months, I have cleaned out 2 or 3 shoeboxes of lint from each of 5 machines.
This has nothing to do with the filter screen you are supposed to clean after every use.
It has to do with the lint that escapes the ductwork inside the machine itself.
You may be amazed how much you will find.
You will also need to check the ductwork from the back of your machine to the outside air. That pipe can also get clogged and cause the same results.
Be blessed.
Posted on Feb 13, 2014
Jimster
  • 240 Answers
SOURCE: kenmore 70 series model # 96573220
Sounds like the push to start switch has gone bad. Not to expensive to fix, and pretty easy to do as well. You can remove the rear of the console, remove the push to start switch (lift the tab, then turn to unlock) and replace. Be sure to mark your wires so they go back in the right order. Jim
Posted on Nov 18, 2007
hotuna
  • 288 Answers
SOURCE: Clothes Dryer will not stop or be quiet
On some Kenmore which is made by whirlpool, there is a resistor connected to the timer control. when the machine is off can you listen to the timer switch and hear it running, making a clock ticking sound? If so, you need a new resistor. Being a dryer, when you open the door and it stops the button needs to be reset before it starts again, right? So I wouldnt be looking at the door switch as much as the start button. It may be the evil one.
Posted on Dec 23, 2007
JR JR
  • 116 Answers
SOURCE: Kenmore Elite HE4 Electric Dryer - heat but not drying
you have thermistor failure/ located inside machine reason for premature heat
Posted on Nov 30, 2008
  • 1122 Answers
SOURCE: kenmore 64672 dryer gets hot but clothes still wet
you have a clogged wall vent or clogged dryer vent or a clogged lint trap,you are trapping all the hot wet air in the dryer and that's why it's taking so lont to dry-mike
Posted on Apr 23, 2009
  • 97 Answers
SOURCE: kenmore electric dryer (model # 110 60202990)
Hello Friend, Your problem is very simple to fix. You need a thermal fuse, very simple and affordable to replace. To replace the thermal fuse just remove back cover of dryer and look down where the air blows out. Now, just to the left where all the wires are you will see a white plastic part with two wires plugged into it. This part is called a thermal fuse. Just remove these wires and replace the thermal fuse. Your dryer will run like new. Happy to help, Tim.
Posted on Jun 25, 2009
How do you dry clothes in this machine please
A fairly common problem! The official instructions are
Before using your dryer, wipe the dryer drum with a damp cloth to
remove dust from storing and shipping.
1. Load clothes loosely into the dryer and close the door. Do not
pack the dryer. Allow space for clothes to tumble freely.
2. Turn the Cycle Control knob to the recommended cycle for the type of load being dried. Use the Energy Preferred Automatic Setting (,) to dry most heavyweight and medium weight loads. See "Drying, Cycle, and Temperature Tips."
3. Select a temperature setting on models with a Temp/Fabric selector. The cycle descriptions include temperature setting suggestions.
4. Push the START button.
Stopping and Restarting
You can stop your dryer any time during a cycle.
To stop your dryer
Open the dryer door or turn the Cycle Control knob to OFE
NOTE: The Cycle Control knob should point to an Off area when
the dryer is not in use.
To restart your dryer
1. Close the door.
2. Select a new cycle and temperature (if desired).
3. Press START
Extracted from
http://www.manualslib.com/manual/511763/Whirlpool-Lte5243dq.html?page=10#manual
Nov 14, 2015 | Whirlpool AWZ410 Front Load Washer/Dryer
Whirlpool Dryer GEW9200L always at "Wet" step - skips "Sensing"
Hello. To test properly, the dryer must be put in diag mode--a key dance of pressing "more dry, less dry--more dry, less dry" within 5 seconds with the door closed and dryer off. All lights will be illuminated and "88" will be in the display. If you open the door and a tone is heard, along with seeing a software revision number in the display, this means that the moisture circuit is shorted. *If this does not happen*, then open the door and, using a wet cloth or finger, bridge the moisture sensor bars located on the filter holder(metal strips approx 1/2 apart and several inches long). If you do this and a tone is heard and the software revision number is seen, THE SENSOR PASSES THE TEST. If it doesn't, you're going to have to troubleshoot further with a voltage/ohm VOM meter, or better, call for service because, unless you've done this before and know what to expect, you are gonna be INVOLVED in disconnecting sensor wires and checking electrical resistances and so on. You'll have to remove the toe panel(bottom panel on front of unit) to access the sensor wires. To exit diag mode, simply unplug the dryer for about 30 seconds. One thing though, if there is a lot of lint build-up, the sensor bars could be shorted by a bunch of lint crammed between the contacts--have seen that one on occasion.
Aug 13, 2015 | Whirlpool GEW9200L Electric Dryer
I have a Beko tumble dryer which now stops after a very short time even when the clothes are still wet. When I press restart it works again for about 30 seconds and stops again! Please advise on what the...
Dryers (all) have a safety device that causes the machine to shut down in case of over temperature. it;s located in the heater box. this could be faulty.
May 01, 2014 | Dryers
Washer will not turn on.
If the Add A Garment light is on, try this: the washer door will unlock after the Pause/Cancel button is pressed once. Pressing the Start button will restart the washer at the same point.
May 21, 2013 | Washing Machines
Fisher & Paykel dryer DE60F60EW1 has suddenly stopped working when I tried to change the program. How do I reset the machine
Here are a couple of possible reasons it stopped and solutions from the manual.
Adding/removing laundry in standby mode
If you want to add or remove laundry into/from your machine after the drying programme has
started, put the machine into Pause mode by pressing the START/PAUSE/CANCEL button. The
drying process will stop. Open the door at Pause position and close it again after adding or
removing laundry. Press START/PAUSE/CANCEL button to start the programme.
Any laundry added after the drying process was started may cause the already dried clothes in
the machine to intermingle with wet clothes and the result will be wet laundry after the drying
process is over.
It is not recommended to add laundry after the programme is started as it will increase the
programme time and energy consumption.
Childproof lock
There is a childproof lock to prevent any programme interruption due to the pressing of keys
while the programme is on. The loading door and all keys except the ON/OFF key on the panel are
deactivated when the childproof lock is active.
In order to activate the childproof lock, press on the StARt/PAUSe/CANCel and BUzzeR CANCel
buttons simultaneously for 3 seconds.
Fig.6 Using the
childproof lock
To start a new programme after the programme is over or to interrupt the
programme, the childproof lock should be deactivated.
To deactivate the childproof lock, press the same buttons for 3 seconds.
Two beeps will sound when the childproof lock is activated. A single beep
will sound when the lock is deactivated.
I was able to view the manual by a Google search and the third item on the Google search list was the manual, but it would only come up by selecting "quick view", otherwise it would crash the Acrobat reader plugin.
Jun 03, 2012 | Toys
Dryer not drying clothes, have had a small load in for over 2 hours still wet....
Hello s cissy. If the clothes are hot but not getting dry you probably have lots of lint accummulated in the vent pipe which is stopping the wet air from escaping to the out-of-doors. To solve this pull out the dryer, unplug it and then disassemble the vent pipe from the lower back of the machine. Clean out the inside of the pipe and the interior of the machine where the pipe connects.
If the clothes never get warm to hot, then you most likely will have to replace the heating element. Get back if that is the case and we can talk you through that repair. Joe
Thanks for choosing Fixya!
Nov 22, 2010 | Fisher and Paykel SMARTLOAD DE62TG1...
My dryer was working. I stopped it to take my clothes. When I went to put in the wet clothes my dryer would not start.
Try pressing on the door to close it and
see if it starts. It sounds like the door switch has failed or the actuating arm is bent. You should hear a click as the door just barely opens or is nearly closed. No click = no start. I.e. Door switch problem.
Jan 22, 2010 | Whirlpool GEW9250 Electric Dryer
Dryer stops in the middle of cycle
The door latch has failed, that's why your dryer stops. When the door opens it stops the drum and turns off. Fix the latch.
Jul 01, 2009 | Maytag PYE2300AY Electric Dryer
My dryer stopped working. Dryed a load of clothes
Check the door switch. A little lever sticking down through top rightof door opening. If it is not there you will need new doorswitch(sometimes the little lever breaks off). If it is there and doesnot click when you press it in you need a new door switch. if it clicksand clicks when you close the door then you have a bad thermal fuse.The thermal fuse is found by taking the back of the dryer off. The fuseis an oblong white plastic piece with 2 wires attached.
Door switch part number 3406109
Thermal fuse part number 3392519
May 17, 2009 | Whirlpool Dryers
Dryer not working properly
its likely to be the condenser unit in the rear of the machine full with lint check for a large clear / opaque unit with pipes connected and make sure it is clear
Jun 19, 2008 | Equator EZ 3612 CEE Front Load...
Kenmore Elite HE4 Electric Dryer Logo
35 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
