Question about HP PhotoSmart 7760 InkJet Printer
Printer carraige jam but is not jammed - HP PhotoSmart 7760 InkJet Printer
SOURCE: Carriage jam
My wife had replaced bith ink cartridges and the carriage was also jammed! what she did was helped the cartridge carrier up some and it finally clicked in!!
Posted on Feb 10, 2008
  • 217 Answers
SOURCE: Printer carraige of hp photosmart 475 has jammed at the far end
unplug the device and try to move the carriage with your hand ,but do not force to move it .if it does not moves just again plug in the wire and on the printer.and the carriage will move when the carriage comes out.just check out the cartridges that r they properly installed.
Posted on Nov 29, 2008
SOURCE: Cartridge jam won't clear HP 5610v
I had the same problem and just got it to work. go to
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00577763&lc=en&dlc=en&cc=us&lang=en&rule=22243&product=441125
go to the section "Moving the carriage" turn on printer and then unplug power. If you still cant move the carrage then remove both toner cartridge and all the trays. Then completely disconnect printer and stand it upright (so paper feed and cartridge tray is on top) Look thru the paper feed area to the left side of toner carrage and you will see a little plastic tab around the bottom back of the carrage. That tab is suppose to be inside a track on the bottom of the carrage. I think that when we put in or took out toner we must have pushed it to hard and that piece jumped out of the track and has "locked" the carrage. I just pushed the carrage up carefully and used a letter opener to move the plastic tab back into place (tab is spring loaded) print working fine now. Hope this solves your problem
Posted on Feb 15, 2009
  • 199 Answers
SOURCE: CARTRIDGE JAM - CARRIAGE JAM - PAPER JAM - RESET POWER
change the carrage block will solve this issue.the carrage block cable is damaged
Posted on Sep 12, 2009
  • 53 Answers
SOURCE: We have an HP C6180. Carraige jam with grinding noise
perform the steps in the webpage:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00786043&cc=us&lc=en&dlc=en&product=1153494
Posted on Oct 03, 2009
Printer 6150 say carraige jam but there isn't anything jammed
Please CLICK HERE and follow the steps provided and if the issue persists, reply back.
Regards,
Riztech
May 29, 2011 | HP Photosmart C6180 All-In-One InkJet...
Carriage Jam
Carraige rod is the rod that holds the cartridges and moves while printing on the paper and spreads ink on the paper and if this rod is jammed it is known as carraige jam.
Please follow the below steps.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01423360&cc=us&lc=en&dlc=en&product=3204464
Please open this link and follow the steps.
If still the issue persists, please follow the below steps.
STEP 1.
1. Un plug the power chord from the back of the printer.
2. Press and hold the power button of the printer.Wait for 30 seconds.
3. While holding the power button, re-plug the power cable.
4. Turn on the printer, if it is not on.
STEP 2.
Reset the All-in-One to the factory default settings by using these instructions:
1. Unplug the power cable from printer when the printer is powered on.
2. Press and hold OK and HELP buttons while plugging in the power cord.
Thanks Bye.
Please take care and KEEP SMILING.
Apr 10, 2010 | HP Photosmart C5280 Printer
It say carriage jam
Hi friend,
What probably happened is that paper jam caused the carraige alignment sensor to get out of place or to get covered, moved, etc and the printer doesn't know what to do...
What I would suggest trying is, unplug the printer, try pulling the carraige out to the center and then close it and plug it back in, see if this kicks it enough to reset itself.
Thanks,
Mar 20, 2010 | HP OfficeJet 7410 All-In-One InkJet...
I get a carraige jam. It asks me to remove paper,
Sounds like it needs serious servicing. You can look at having it fixed but it may just as well be worth it to replace the machine.
Feb 02, 2010 | HP Officejet Pro L7580 All-In-One InkJet...
Help hp psc 1610 all in one printer carraige jam
Try this website:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00107909&cc=us&lc=en&dlc=en&product=79477
Nov 26, 2009 | HP PSC 1610 All-In-One InkJet Printer
Jun 10, 2009 | HP Officejet 5610 All-In-One InkJet...
Cartridge carraige jamming
plz send it for repair as it is due to hardware failure
May 28, 2008 | HP PSC 1210 All-In-One InkJet Printer
Carraige Jam
maker sure the cleanout station is not stuck..it moves also...dont break it just see if it isn stuck...move the carriage back and forth. put paper in it and turn it back on.....if that does not work..take the paper out ..open the back and roll th big wheels a bit and try again.
Oct 13, 2007 | HP WanProbe V-Series Network Monitoring...
HP PhotoSmart 7760 InkJet Printer Logo
16 people viewed this question
Seeker5211
Seeker5211
