A) Power cables from Power Supply to motherboard:
1) Product information > Product specifications > HP Pavilion XT919 Desktop PC Product Specifications and What Ships in the Box,
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bph06613&tmp_task=prodinfoCategory&cc=us&dlc=en&lc=en&product=584612) According to my sources the motherboard is an Asus CUW-AM,
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=120&prodSeriesId=46171&prodTypeId=12454&prodSeriesId=46171&objectID=bph07170
If this indeed holds to be true, scroll the page down, look at the illustration under the Figure 1: Motherboard layout, heading.
Look at number 22 on the right; ATXPWR
Now scroll down to the motherboard photo.
The white connector with two columns of 10 socket holes, to the right of the black Ram memory slots, is ATXPWR.
Proper name is 20-pin ATX main power cable connector, on the motherboard. This is an example of a 20-pin ATX main power cable, and it's respective motherboard connector,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain20Note in the three photos the Lock on the side of the power cable connector, and the Tab on the side of the motherboard connector.
The Lock operates like a see-saw on a playground.
To remove the power cable the top is squeezed in, and this causes the hooked end of the Lock to come away from the Tab.
When the 20-pin ATX main power cable is deemed to be properly installed tightly to the motherboard, the hooked end of the Lock will be over the Tab.
B) IDE (PATA) harddrive uses a 4-pin standard Peripheral power cable.
So does the Optical Drive/s,
http://www.playtool.com/pages/psuconnectors/connectors.html#peripheralNote the rounded corners when plugging it in.
{Power cable has been misnomered as a 'Molex' power cable. Molex came up with the connector design. The name stuck. Kind of like calling an adjustable open-end wrench a Crescent wrench }
C) Floppy drives and card readers use a 4-pin small Peripheral power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#floppyD) Number 6 -> SYS_FAN, is where the Processor fan plugs in.
SYS_FAN stands for System Fan. A computer case fan. The illustration is wrong.
E) Number 21 is PS_FAN.
That to me stands for Power Supply Fan. Another misnomer. The Power Supply has it's own fan, and doesn't need power from the motherboard for it.
I'll bet this is where a System Fan, or computer case fan, would connect.
F) Number 29 points to the Primary IDE connector on the motherboard.
This is where the 40-pin IDE flat ribbon cable, plugs in for the Harddrive.
Number 24, Secondary IDE, is where the Optical Drive's, IDE flat ribbon cable plugs in.
Note*
The rectangular connectors for the IDE flat ribbon cables, has a 'bump', or protrusion, on the outside edge towards the middle,
http://en.wikipedia.org/wiki/File:PATA-cable.jpgIn this photo it is at the top/middle. There are different styles. Square block, or the two piece design shown.
These bumps, or protrusions line up with a cutout.
A cutout on the motherboard connector, or a cutout on the circuit boards for the harddrive, and optical drive.
IF there is no bump, or protrusion;
There is a faint red strip on one side of the IDE (PATA) flat ribbon cable.
The red strip denotes which side Number 1 wire is on. Number 1 wire in the cable, for number 1 pin in it's connector/s.
http://pinouts.ru/DiskCables/IDE_pinout.shtmlHere you can see by the pinout above, that for the black Primary IDE connector, and the blue Secondary IDE connector, Number 1 pin is at the Top.
Red stripe on edge of IDE cable will be at the top, when the cable is attached.
When plugging into a harddrive, or optical drive, Number 1 pin ALWAYS goes toward the power cable.
Towards the 4-pin standard Peripheral power cable.
Red stripe will be towards 4-pin standard Peripheral power cable.
H) Number 14 CD_IN is where the audio cable from the MAIN optical drive plugs into. If you have two optical drives only the main, or Primary optical drive audio cable plugs into the motherboard.
I) The front of your computer is the Front Panel.
The area of contact pins on the motherboard, that the main wires from the Front Panel go to, is the Front Panel header.
Under the photo of the motherboard, the pinout for the Front Panel header is shown, though not very legible.
In the illustration the Front Panel header is Number 30 - Panel.
Looking at the pinout, and looking at the actual Front Panel header on the motherboard photo, it looks as though they have the pinout upside down, in relation to how it actually is.
Note in the motherboard photo, the Front Panel header is shown with 5 pins across the Top, then a space, then 4 more pins.
The Bottom row is 10 pins in a row.
In the Front Panel header pinout, they show 10 pins going across the Top. 4 pins going across the bottom, a space, then 5 pins.
Upside down.
I think it should be this way,
Top Row starting on the Left side going towards the Right;
Pins 2, 4, 6, 8, 10, No Pin, 14, 16, 18, and 20.
Bottom Row starting on the Left side going towards the Right;
Pins 1, 3, 5, 7, 9, 11, 13, 15, 17, and 19.
1) Pins 2 and 4 are for a Reset switch, IF a Reset switch is used.
2) Pins 6, 8, and 10 are for the Power On LED. (Light)
This is for a computer that has 'Turbo'
Dual light Power On LED. May have Green and Yellow lights.
Green for 'Turbo', and Yellow for Normal.
Bunch of hooey, really.
'Turbo' mode is the computer operating in a normal mode, and Normal mode really is the computer slowed down.
Pin 10 is for the Negative ( - ) wire.
Pin 6 and Pin 8 are the Positive ( + ) wires. One for the Green side of the Power On LED, one for the Yellow side of the Power On LED.
3) No Pin 12
4) Pins 14, and 16 are for the HarDDrive activity LED. (Light)
Pin 14 for the Positive ( + ) wire.
If the HDD LED is dim when the Harddrive is active, switch the wires around.
5) Pins 18 and 20 are for the Power On switch.
6) Pins 1, 3, 5 and 7 are for an internal speaker. Used to hear BIOS Beep Codes.
Pin 3 is for the Negative wire ( - ), and Pin 7 is for the Positive ( + ) wire.
7) Pins 9 and 11 N/C. Not Connected. (External SMI lead)
8) Pins 13 and 15 are for a Keylock switch.
Some computers have a Keylock. Unlocked the computer will come on.
I -> believe, Not connecting anything to these two pins, is like having the Keylock in the unlocked position.
May be wrong. May have to have a jumper wire across these two pins for the computer to work.
9) Pins 17 and 19 are for a Message LED
(Sleep/Standby)
HOWEVER, the best method IMHO is to use an LED light, and touch two pins at a time, to see which ones are for the Power On switch.
When the computer comes on, (Power Supply), then you know which pins are for the Power On switch.
Computer running, do not touch those two pins again, and check the rest of the pins.
Computer turns off, and starts again? Restart switch
LED light blinks? Harddrive activity LED
LED light stays on steady? Power On LED.
Finding which two pins are for the Power On switch, also helps tell you where the rest of the pins are, by looking at the pinout on the HP Support page.
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=bph05159Scroll down to Figure 4: Front panel connectors
Same Front Panel header used for this TriGem (Cognac) motherboard.
Clearer though.
For additional questions please post in a Comment.
Regards,
joecoolvette
connection diagram for pins
