Question about Pyle AM/FM-MPX Single CD/MP3 Player w/Variable 7 Color Illumination PLCD82MP
Auxilary..playing my mp3 on my radio
How can i play the music on my ipod on my plcd82mp ? tried finding out how but could not find any information
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Pyle Master
  • 924 Answers
You would be best to go to the Pyle website and look up your owner's manual. The information you're looking for will be in the manual.
Posted on May 11, 2014
New Alpine radio, went through setup, plays fine on radio/tuner on all four speakers, but ipod (USB port) or internal CD only plays on front speakers.
Just a thought - the usb provides a digital signal which carries information about how the signal is to be processed; mono, stereo, surround sound stereo, etc.
If the mp3 music file was only recorded in 2 speaker stereo perhaps that is how it plays back.
Admittedly the radio signal is stereo and yet it plays on four speakers but unless it is a DAB radio it is analogue and maybe that makes a difference.
Perhaps there is an internal electronic fault with the digital processing part of the unit. I suggest reading the handbook again and then perhaps contacting the seller.
Mar 28, 2016 | Alpine Car Audio & Video
Tip
How to connect your iPod to a Car Stereo
Many car stereos have more new connections that MP3 playerslike the iPod can be connected and played through the stereo. For new carradio, you only need to connect the device and the MP3 player. If you have anold stereo, connect your iPod or connect a 3.5 mm stereo cable or FMtransmitter. Connect iPod directly to the stereo with a stereo cable willresult in better sound quality on the FM transmitter, which can be interruptedor static signal.
AUX
1. Find an AUX port. The AUX is a hole, only small to belocated on your car radio face. (The size is perfect for connecting headphonesor an auxiliary cable.)
2. Connect the 3.5 mm stereo cable into the hole in front ofyour car.
3. Connect the other end into the hole stereo AUX jack /headphone jack on top of your iPod.
4. Connect your iPod.
5. Activate the AUX input. This will be different for eachcar. You may need to field through your input options (e.g., FM, AM, CD, etc.)to access the AUX. Or you may need for your stereo pressing the Menu button.Then, the options for auxiliary input field to the AUX input as possible.
6. Find a song on your iPod and press the Play button whenthe auxiliary input is activated. If you do not hear anything, make sure thevolume on the iPod device and radio. If the iPod is playing your song, you'llsee the song progresses on the iPod screen.
FM Transmitter
1. Find an FM transmitter that is compatible with the iPod.So let your FM transmitter near your car radio.
2. Connect the iPod to the FM transmitter.
3. Tune the radio to your car radio has a frequency thatonly static, then the vote of the same frequency channel using the buttons +and -.
4. Connect your iPod. Then a number and press"Play." Make sure to turn all your volume on your iPod. You should beable to use his music. If not, find a new frequency until you find one thatworks with the iPod and the transmitter.
on Aug 09, 2011 | Apple iPod touch
Trying to play flash drive in USB port on stereo
Make sure that the music files are indeed mp3 format. An iPod will play several different formats but most av head units only play mp3. A lot of the songs that are downloaded from iTunes are actually mp4
Jun 08, 2014 | Pioneer DEH X3500UI - radio / CD / MP3...
Sony ICF-DS11iP doesn't play my Ipod touch. Radio, Alarm, Ipod Charging functions work. Pls suggest a solution
Please check the iPod connector on the Sony. If you can wiggle it, it is probably a bad connection. These models Sony radios have the connector directly soldered on a PCB and it tends to get loose after a while due to connecting/disconnecting the iPod. If it is loose, the connector needs to be resoldered back into place.
I have had the following circumstances when there was a bad connection:
- iPod will not be charged
- iPod can not play music through the Sony
- iPod will play music through the Sony, but an iPhone won't
Sep 03, 2011 | Sony ICF-C1IP (Black) Docking Station
My ipod wont play through the docking system, how do i solve this? it is a sony ICF-CS10iP. i have tried unpluging it. it used to work when i had this problem before. but it hasnt worked for a couple days...
Please check the iPod connector on the Sony. If you can wiggle it, it is probably a bad connection. These model Sony radios have the connector directly soldered on a PCB and it tends to get loose after a while due to connecting/disconnecting the iPod. If it is loose, the connector needs to be re-soldered back into place.
Jul 07, 2011 | Sony ICF-C1IP (Black) Docking Station
Ipod dock won't play music when ipod hoocked up. just blinks searching for ipod, finds nothing then shuts off
Try taking out all the outlets of the dock, and wait like a minute then plug it back in. Or click the reset button if it has one
Feb 02, 2010 | RCA RC65I iPod and iPhone 3G Docking Clock...
When trying to play the music on my Ipod it keeps reading format error. Why is it doing this and how can i get the music to play? Ehen I try to sync wiht windows media, it says did not fit on device.
MP3 files come in different resolutions try to load some different MP3's (from a diff source) and see if those work, they should. BionicSam
May 20, 2009 | Apple iPod touch
Ihome ih9 wont work with 3rd generation ipod nano
Look at the Box and the Manual! 3rd Generation is not supported by iH9! Clearly marked on the Manual.
Jan 03, 2009 | Dual Electronics ihome iH9BR iH9 Alarm...
Hooking up an MP3 to Alpine CDA-9805 head unit
ok when you look at the front of your system there is a button that has a (F) on it press and hold tell stuff comes on the screen then just keep pressing it tell you get to AUX off you should get it from there hope this helps
Jul 23, 2008 | Alpine CDA-9805 CD Player
Sound quality issues
Try to plug the auxilary cable all the way in.
Jan 10, 2007 | Philips HDD065 MP3 Player
Pyle AM/FM-MPX Single CD/MP3 Player w/Variable 7 Color Illumination PLCD82MP Logo
51 people viewed this question
Top Pyle Audio Players & Recorders Experts
 Grubhead
Grubhead
Gerhardus Stroebel
Are you a Pyle Audio Player and Recorder Expert? Answer questions, earn points and help others
