Question about Frigidaire Clothes Dryer Gas Valve 5303207409
I have a Frigidaire glgq2152es gas dryer that looks like it has a pilot like flame after it has finished the drying cycle or when it is in pause. The only way to turn it absolutely off is by shutting down the main gas valve (between the gas tank and the appliance's hose).The machine starts, the igniter has a good glow, it has a good flame and it heats properly the clothes. Is it the gas valve assembly - part number 303207409 - which is damaged because it doesn't close the gas flow? We recently changed both gas valve solenoids part number 5303931775 and it has the same kind of pilot flame on. Thanks, REC.
MNTECH
  • 1543 Answers
SOURCE: Dryer is getting hot but clothes are not drying
You have a vent problem. Eliminate all (if possible) flex duct (replacing with ridged aluminum pipe and aluminum elbows). Clean lint out of remaining vent pipe. Make sure vent is not crushed or obstructed, especially behind the dryer. If possible, make sure outside vent termination is not a two inch opening. (you want a full 4 inches)
Posted on Nov 10, 2008
  • 14 Answers
SOURCE: Frigidaire Gas Dryer - Heats for 1-2 minutes then gas shuts off
Most of the time, the culprit is a bad gas valve coil(s). Replace those, and your dryer should return to normal operation.
Posted on Jan 25, 2009
jumptrout51
  • 3361 Answers
SOURCE: gas dryer won't heat up
The ignitor can glow and still be defective.
Take a volt meter and check for power at the gas valve while calling for heat.
If you have voltage, replace the coils again.
No voltage, replace the ignitor and flame sensor.
Posted on Mar 08, 2009
TheMobilian
  • 8220 Answers
SOURCE: I have a Frigidaire model # FG01442ESO, gas drier not drying
Them coils is overheating Take a look
Posted on Aug 29, 2009
heatman101
  • 43501 Answers
SOURCE: Frigidaire Gas Dryer, won't heat to dry clothes,
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Posted on Aug 10, 2010
I have an LG gas dryer only 7yrs old. Some loads are coming out still soaked after the cycle has finished. I've looked through the back of the unit and the flame is igniting. However, I have noticed that...
i am not a dryer expert,so i can only make these suggestions.
1.make sure the lint filter is very clean.
2.make sure the dryer is sitting level on the floor.(if it isn't sitting straight on the floor,the clothes may not be touching the sensors,causing the heat to turn on & off while drying.
3 do not overload the dryer with wet clothes.
4.pick the right heat setting for the amount & type of clothes.
Mar 30, 2015 | LG Dryers
Dryer will not stop spinning when door is closed
Good Morning Jeff,
I see that you are having trouble with your Frigidaire dryer, model# GLGQ2152ES, to stop spinning, even though all the lights are off. It could possibly be the different boards and sensors miscommunicating with each other. I suggest giving the appliance a hard reset. You will do this by either unplugging it or cutting the power off at the circuit breaker for 2-3 minutes. When you turn the power back on, if the dryer is still spinning, without you wanting it to, I would suggest contacting either the manufacturer or your local authorized technician. Hope this is helpful.
-Best Regards-
Mar 19, 2014 | Frigidaire GLGQ2152ES Gas Dryer
Ho to convert a frigidaire natural gas dryer to a lp gas dryer?
Kits should be available at Sears.com, need to be a certified technician to change it. Involves changing igniter, burner scoop, and adjusting air shutters.
Feb 22, 2014 | Frigidaire GLGQ2152ES Gas Dryer
The dryer is making a loud noise-like metal on metal
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Asker's Testimonial " This should give me an ida of what to look for once I open er up " -
Apr 18, 2010 | Frigidaire GLGQ2152ES Gas Dryer
Clothes not drying
The temperture sensor is at fault. It shuts down before the temperture is hot enough
Feb 02, 2010 | Frigidaire GLGQ2152ES Gas Dryer
Frigidaire electric dryer aeq7000es1 low heat only code e4a store
this is a door switch issue make sure the door switch is not broken
Sep 14, 2009 | Frigidaire GLGQ2152ES Gas Dryer
Dryer flame on magtag wont stay lit. Pilot flares up but no flame
Thermocouple is probably bad. The pilot burns and heats a sensor which tells the CPU that the Flame can start, and the thermocouple heating up changes voltage with increase temperature and tells the CPU that the Flame is burning OK. If it is defective, there is no voltage change and the CPU assumes that the Flame didn't start for some reason, (Gas only!) and turns if off for safety. Over and over xx times.
My .02
Good Luck!
Mar 26, 2009 | Dryers
Nov 10, 2008 | Frigidaire GLGQ2152ES Gas Dryer
Dryer runs-no heat
I had a problem once with a gas dryer that would come on, the pilot would glow and the flame would run on a shortend cycle. The coil that opens the gas valve had a short circuit that would only short out when it heated up. It would drive me crazy since it appeared to be working. The short cycle time the first time, and then maybe not at all once it was warm gave me mixed signals.
May 15, 2008 | Dryers
Frigidaire Clothes Dryer Gas Valve 5303207409 Logo
26 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
