Question about Sewing Machines
Brother 651, vintage. Everything works but it isn't actually sewing anything. Thread isn't staying in fabric
SOURCE: Thread in needle or bobbin keeps on breaking
The tread only breaks in the needle. what can i do . i don't get to sew anything . I tread the needle and get everything ready and start the machine and as quickly as that the tread is broken and the machine has not sewn at all.
Posted on Apr 07, 2009
  • 9 Answers
SOURCE: NEEDLE KEEPS COMING UNTHREADED WILL NOT CATCH IN FABRIC
Make sure you are threading the machine correctly and it has the proper tension. Also check the bobbin the thread has to go thru the little lash
Posted on Jun 14, 2009
  • 55 Answers
SOURCE: Thread Breaking On Brother Sewing Machine
if thread is good quality you may have a sharp groove in your needle plate hole from needle breakage. if so, polish with emery tape.
scott
Posted on Jul 27, 2009
  • 96 Answers
SOURCE: stitching loose. won't thread the fabric
try to rethread the machine all the way back to the spool of thread and check the top and bottom tensions on scrap of same fabric
Posted on Dec 13, 2009
sburtenshaw1
  • 5 Answers
SOURCE: Shirring fabric?
When putting your shirring elastic on the bobbin, don't thread the elastic through the bobbin holder,adjust the stitch length longer,and loosen the tension, other wise if you want to put it through the bobbin holder you have to loosen the tension screw on the bobbin holder, and then you have to adjust it back for ordinary sewing,
Posted on Feb 13, 2010
How do I fix the stitching on my Brother XL-3010?
Your tension sounds far too loose. Or your needle is blunt.
Jun 25, 2015 | Brother Sewing Machines
Looking for Sewing Machine Thread for beginner!
Using thread different than you would normally use for practice will give different results. This will frustrate both the student and teacher. Not a good idea.
Feb 20, 2014 | Brother XL-2600I
Thread cuts at needle immediately when starting to sew.
check the needle plate for any small burrs
also on the bobbin & bobbin case
is the needle the correct one for the fabric being sewed?
Apr 17, 2012 | Brother LS-2125 Mechanical Sewing Machine
Borrow sewing machine from sister unsure how to thread it correctly and when i do the thread fromthe needle keeps breaking when i try to sew its a brother XL-5130 sewing machine and i know nothing on how...
you need to go to this webpage http://welcome.solutions.brother.com/bsc/public/us/us_ot/en/doc/manual_index.html?reg=us&c=us_ot&lang=en&prod=hf_xl5130eus&dlid=&flang=English&type2=-1 and download the instruction manual for this model. It has the threading up instructions plus selecting stitches, winding a bobbin etc.
The thread breaking is most likely due to incorrect threading up of the top thread. I suggest that if you can, you print out the manual, put into a little folder and place beside the machine and refer to it often. Follow the instructions in it on winding a bobbin, putting it into the bobbin case correctly and threading up the top thread. Make sure the bobbin goes into the case the correct way, as per image.
Remember, ALWAYS THREAD UP TOP THREAD WITH THE PRESSURE FOOT RAISED, this keeps the tension discs open so the thread can seat into the tension device correctly. And you must get the bobbin thread into the tension spring fully and then place the bobbin case into the shuttle using the little latch so it stays in place.
Also, new needle for every new project, and put the needle in "flat shank to the back". It will take standard domestic sewing machine needles 705/130H but it is important to select the correct sized needle for the fabric you are sewing so that the needle can penetrate the fabric but not leave big holes. So for light weights like chiffon you want a size 60 or 70. For medium weights a size 80 and for heavy fabric like denim or a coat weight wool you would use size 100. Ball points for stretch fabrics so that the needle pushes between the fibres and a regular point for woven fabrics.
I trust this helps you out, 4 thumbs up if so. Thank you.
Jun 28, 2011 | Brother XL-5130 Mechanical Sewing Machine
Top thread from spool somehow gets out of the needle when sewing. Sometimes top thread breaks; other times it just escapes the needle. I redid threading from top and from bobbin to see if that would fix....
Try loosening the tension and pulling a longer string of thread. Also, if the needle is not at the highest point, when you start sewing, the thread will pull out.
May 27, 2011 | Brother LX3125 Sewing Machine
Have a brother xl2230 has been working now the fabric went pull through what can I do ,the thread bunches on the end and the fabric just stays there
I need a little more detail, was it working ok and feeding the fabric through, then stopped moving? How is your top tension? Set at 3 or 4? No thread caught in the bobbin area? What is your stitch length? What kind of fabric, and what size needle? See, there a lot of things that I need to know in order to help you, Please give as much detail as you can when stating your problem, don't forget, we can't see what you are doing,
Apr 22, 2011 | Brother Sewing Machines
Stitching loose. won't thread the fabric
Dec 10, 2009 | Brother SE-270D Computerized Sewing...
Apr 07, 2009 | Brother LS-2125 Mechanical Sewing Machine
Sewing Machines Logo
13 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
