Screen totally black
Tesco Technika tv/DVD. Sound is perfect, but just a totally black screen. If I press the display button on remote, picture comes back on for a second then back to black screen again.
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 56 Answers
Try to play around with the cables as you might have not inserted all the cable properly .
Posted on Feb 13, 2014
SOURCE: DIBOSS tv shows no picture
Me too! Apparently Diboss are no longer trading, so no help there. I am aware that these panels have a common power supply issue, the faulty chip is only available from China and the last one I fitted only lastest a couple of days. However the fault described above is not the same. I've checked the psu outputs; all are fine and nothing changes when the picture disappears, therefore I can assume that I'm not looking at a PSU fault. As Iain says above, it appears to be a signal link, however I have no picture on ANY input and without circuit diagrams I cannot find any component that's common to all the various inputs. This leads me to think that either the backlight, or the screen itself is faulty. I'll keep trying and if I get it sorted I will report back.
Jon
Posted on Sep 24, 2008
SOURCE: 37LC7D, screen blank, cannot power off manually or w/remote
Hi, I would buy your TV
Posted on Dec 14, 2008
skotkolr
  • 558 Answers
SOURCE: Sharp LCD TV, Screen goes black sound stays on
Capacitors on the power pack are going bad they need to be replaced that should fix the problem.
Posted on Apr 07, 2009
SOURCE: 19'' Dynex TV does not come up as a Computer Monitor.
Follow these steps on the remote :
Press Input,
scroll down and select VGA.
Posted on Jan 03, 2010
  • 4234 Answers
SOURCE: Sound stays on, but no picture- goes black and stays that way.
This unit should still be under warranty and should be taken in for warranty service. Any attempt to access the interior will void the warranty. It is important that a complete description of the problem like you entered here be taken along when you bring the set in for service. This will insure that the servicer be able to reproduce the problem and resolve it.
From your description (and as a servicer), I would be looking for a component that is heat sensitive. These types of problems are fairly easy to locate and resolve.
Please take this in for warranty service and update this when you find out the details.
Thanks,
Dan
Posted on May 04, 2010
Monitor goes black - green light stays on
My screen is black, why do I not have a picture?
Answer Antenna is not hooked up to television.
  • Make sure that the antenna cable is correctly connected to the television. If it doesn't work there appears to be no signal.
Problem is caused by television broadcast
  1. Push 'INFO' button.
  2. If the screen shows channel number (1, 2, 3, etc) try another channel. Not all channels broadcast at all times.
  3. You may have a signal problem. Contact cable provider or local broadcaster regarding the specific channel.
Television is in EXT or SIDE mode, and there is no external source provided, so screen mute (black screen) is activated.
  1. Push NEXT SOURCE button on the remote.
  2. On the screen appears all sorces.
  3. Press the UP button to switch to the TV mode.
If you are using an accessory device (DVD, DVR, or VCR), be sure the device is on and running.
Blank screen when connecting to the accessory (DVD, STB, PC) device via HDMI to HDMI.
Answer
  • Make sure the cable is well connected .
  • To check which connection is selected, Press the i+ button on the remote control.
  1. When you see Blue mute / blank screen and the i+ display does not indicate any video resolution indication then there is no valid signal detected.
    • Make sure the HDMI output of the accessory is valid by changing the video output resolution to a resolution which the TV can handle.
  2. When you see a blank screen and the i+ display shows a video resolution indication then the connection is correct.
    • The blank screen is caused by the accessory device and not by the TV.
    • To detect and remedy the problem caused by the accessory device, check the instruction manual of this device.
  3. If the problem remains : reselect the HDMI external source input by changing to the other HDMI input and back to the connected HDMI :
    1. Press AV on the remote
    2. Press up and then ok
    3. Press AV again
    4. Press down and ok
    5. The compatibility check process between TV and accessory device will start over again.
  4. Reset (switch off and back on) the TV and also reset the accessory device.
Mar 05, 2008 | Philips 42PF9630A 42 in. Plasma Television
Why does my Sony FWD-42PV1 intermittenly black out?
if the tv blacks out and the light in front stays on its the backlight going out...my first vizio did it within 3 mos of purchase had to send in and they ended up sending whole new tv
Sep 11, 2012 | Sony FWD-42PV1 42 in. HD-Ready Plasma...
I have a technika flat screen / dvd player bough in April 2009. The TV green light will come on with both the remote and the button on the side of the TV however I have no picture or sound, just a black...
Chris, the problem could be almost any where. As a TV servicer, my course of action would be to test the voltage in the power supply. I would look for a bad capacitor in the power suppy. This capacitor may be bulged or skinned. You will need an ESR meter to locate a bad capacitor. A bad capacitor may look fine, when it is not. I have not worked on this model, I would certainly start with the power supply. Hope this clues you into a fix.
Jul 04, 2011 | Televison & Video
I have a 32''lcd technika tv bought from tesco under 2 years ago.it has sound but no picture
This can be caused by several things. First check the remote control to see if the contrast has been tampered with this can make it look like it has no picture but in actual fact it has.
Pick the remote control press the menu button if the menu comes up then adjust the contrast till you see the picture clearly.
If this does not work take then the picture IC is blown i would advice to refer this to an expert to take a closer look so as to avoid total condemnation of the unit.
Hope this has been helpful
Jul 04, 2010 | Televison & Video
No picture on tv when i turn on dvd. get split screen black & whi
Give this a try. Using your user's manual, locate the "Configuring your recorder" section. Under this section there will be "System setup - general" subsection. Being that you are unable to see anything on your tv display you will need to use your manual as your display. Press the "SETUP" key on your remote. Once again using your manual as your display, scroll down to "Restore factory settings" and press "ENTER" As long as you are located in North or Central America and using interlaced video outputs you should have your normal display back.
Hope this helps.
Nov 24, 2008 | Protron PD-DVR100 DVD Recorder
Technika dvd1031 split screen
User the video button the remote to cycle through the various display types (4 in all) press the video button once and wait a few seconds - if you just use the yellow to yellow composite connection you should not get any more than one blank screen. Look at the readout on the top right when you get a picture to see what you have selected.
Sep 10, 2008 | Televison & Video
How do you take progressive scan off
eject the tray and press the stop button for 5 - 10 seconds...if not stop then try pause button
Nov 17, 2007 | TruTech TT320
Blinking Stand By/Timer LED
You can try this on the remote in standby mode, meaning tv plugged in but set off. Press Display,5,vol+,power on remote.Press each button within a 1 sec interv. Next the CRT display the item being adjusted. Press 1or4 on remote to select item. 3or6 to change the data. Press Muting then Enter to write into memory. Service Reset muting green enter red. Press 8 then enter on remote to initialize. turn set off to exit. wait least 10 sec. before turning back on.
Sep 10, 2007 | Sony KV-32V40 32" TV
Televison & Video Logo
190 people viewed this question
Top Televison & Video Experts
