Question about Philips Magnavox 20MS3442 20" TV
Could i get an ariel to use the tv on my porch?
I HAVE ONLY USED IT FOR VIEWING LYRICS OF dvds with grafics.
  • 26 Answers
Well, as far as there are still TV transmitters in your region, it should be possible with your set. For the type of areal, you'll have to find out if the transmissions are on the VHF or the UHF bands. At least, here in Belgium, there are no transmissions anymore. Everything is cable-tv or sattelite. And you need the original remote control from the set, otherwise you cannot get into the setup pages.
Posted on Jun 17, 2014
How to tune in tv stations via the ariel?
follow the Instructions you received with TV
Mar 17, 2015 | Televison & Video
Philips powervision tv my tv tuner pin is broken
You're discussing about the input socket [Ariel socket] to your TV is broken; I assume, and posts this solution. In most cases, this is a irreparable fault; because, this socket is directly connected to the tuner, and is a part of tuner body [case]. If it is broken, the the tuner should be replaced with an identical one. You should check out the number of the tuner used with your TV; can be noted on it by a sticker. Just buy that number tuner, and replace it. The tuner can be bought from most of the electronic spare part selling shops.
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy Pull up older posts. Surf the site with patience.
Apr 17, 2014 | Televison & Video
Snowy picture
Check its Ariel cable for firmness. Check the orientation of antenna.
If all are correct, check and replace its tuner. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience. Pull up older posts. Surf the site with patience.
Apr 07, 2014 | Sceptre X32BV-Naga 32 in. LCD TV
Moved house and tv will not tune into inside
You could try a 15dB UHF amplifier that will usually feed upto 2 TV's they cost about £10-15 and usually have a pass through 240V plug and will work with the Sky Magic Eye.
Mar 18, 2010 | RCA Mikomi 5290925 15 in. LCD TV
Sharp Aquos TV will not display contents of DVD using Microsoft Media Player 11
it sounds like a problem within your vga connection on the tv check around and see if there is some firmware for this fix or right click on your desktop were there is no icons and select properties select settings tab and set ur display as needed.
C
Oct 24, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
LE32R74BDX
this is because most new lcd tv's have a poor tuner built in and require a stronger ariel, to pull in the analogue or digital signal. Check that your ariel is freeview capable whether using freview or not, as these ariels are better at pulling in the signal, or do what i have had to do and buy a mains plug in signal booster from Asda for about £6.00, this did the trick, especially if you don't want to replace an ariel costing about £30.00
Jun 13, 2007 | Samsung LN-R409D 40 in. LCD Television
How can I add lyrics to iPod nano?
"iTunes 5: Adding lyrics to songs for iPod nano If you like to sing along with your tunes, iPod nano can display song lyrics right on its screen. Here's how to add lyrics to and view them on iPod nano. Entering lyrics In iTunes 5, select a favorite song. From the File menu, choose Get Info. Click Lyrics, then enter the words to the song in the text box. Click OK when finished. Copy the song to iPod nano. Viewing lyrics If you've entered song lyrics, you can view them at any time in iTunes 5. Just select the song, Get Info for the song, and then click Lyrics. If you want to view them on iPod nano, do this: On iPod nano, start playing any song to which you've added lyrics. Press the Center button repeatedly. The number of times depends on if you have artwork or not. Here's the order of things when you press the Center button: Play status > Scrubber > Album Art > Lyrics/Description > Rating If you don't have Album Art or Lyrics, then you'll just see the Rating Play status > Scrubber > Rating Lyrics should display correctly in most languages. If they do not, try removing any special characters in the Lyrics pane in iTunes, copy the song back to iPod nano, and try again. Note: Some types of files such as WAV and QuickTime files don't support lyrics, though you can convert WAV and QuickTime files into a format that would allow you to add lyrics such as AAC or MP3. "
Sep 28, 2005 | Apple iPod nano
Philips Magnavox 20MS3442 20" TV Logo
24 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
