Question about Dyna-Glo Heating & Cooling
Won't fire up
Filled with deisel
Skoda octavia vrs deisel turns over but won start
Have you checked the firing to ignite the fuel? Aside from timing, the proper heating of a glow plug is important to ignition.
Jan 04, 2015 | Skoda Cars & Trucks
Why does a Ford focus deisel not fill without the pump constantly cutting out? It takes so long to trickle the deisel to fill the tank, the pump can time out twice before the tank is full.
just one of those things , try holding the nozzle as far out of the filler neck tube as you can with out spilling the fuel or try with the nozzle up the other way a little bit awkward but does let the air out of tank without pushing fuel back up filler
Jul 06, 2014 | 1997 Ford Escort
Mitsubishi fuso 1995 4 cylinder diesel can not start
Using starting fluid on a deisel engine will cause: Blowing the headgasket, blowing a prechamber out of the head, bending a rod, cracking a piston, backfiring into the intake, and fire. Any of the above may have happened. I like to use wd-40 as starting fluid in my deisel engine. Starting fluid is bad for a deisel engine, espically the newer ones.
Dec 15, 2013 | Cars & Trucks
Hi there I've got a 05 polaris predator 500 Tory
hi try cleaning the carb or check your air filter box might be filled with oil so all you have to do is clean the air filter out with water let it dry and soak all the oil up with a rag or sponge. Best of luck!
Aug 28, 2013 | Garden
Need firing order for a 304
Jeep firing order for 6 cylinder petrol 153624. For 6 cylinder deisel 142635. and for a V8 18436572. hope this helps
Dec 03, 2012 | Jeep CJ Cars & Trucks
2000 ram 3500 deisel dies at 2000 rpm won't start
could be fuel elated, there are two fuel pumps, the high pressure pump to feed the injector system and the lift pump to get fuel from tank to the high pressure pump. Check fuel filter also and start there. The fuel pumps are expensive. What have you checked so far and eliminated?
Feb 23, 2012 | 2000 Dodge Ram 3500
Have put petrol into deisel car 35litres addedinto tank with about 25litres of deisel already in
You need to drain the tank and fill it back up with Deisel. Also, if you ran the car make sure and change the fuel filter. It may start a little hard and sputter at first but it should be okay. These accidents happen once in a while but it shouldnt hurt as long as you dont run it with the petrol in it.
Hope this helps...
Oct 11, 2009 | 2007 Volvo Glt
Put petrol into deisel tank
take of the fuel sender hose of tank and be prepared to catch any spills wen finshed fill with deisel
Oct 21, 2008 | 2003 Ford Focus
Ford focus 1.8 turbo deisel 1999.
do not understand you what you mean. assuming your car was ok before you changed f/filter you need to bleed the fuel system of air. esiest to do would be to loosen fuel line at the injectors and have assistant crank the engine while you observe for clear fuel leak without any air bubbles from fuel line.tighten fuel lines and start engine. might have to repeat a few times. good luck.
Jul 03, 2008 | 2000 Ford Focus
Heating & Cooling Logo
20 people viewed this question
Top Dyna-Glo Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
drifterray
Level 1 Expert
Are you a Dyna-Glo Heating and Cooling Expert? Answer questions, earn points and help others
