Question about Whirlpool GH5184XPQ Microwave Oven
F3H code shows on screen and won't heat - Whirlpool GH5184XPQ Microwave Oven
Kitchenaid microwave khhs179lss-0 has error F3H
Hi, F3H mean that Humidity Sensor Failure. You have to refer to the Tech Sheet and test the sensor.
Mar 23, 2011 | KitchenAid KHMS155L Microwave Oven
Whirlpool Microwave error F3H
F3H Humidity sensor failure 1. Unplug microwave oven or disconnect power.
2. Connect a new sensor to the board (at P5).
3. Plug in microwave oven or reconnect power.
4. If no failure code appears when starting sensor function:
 Replace old sensor.
5. If failure code appears when starting sensor function:
 Replace power supply board.
6. Plug in microwave oven or reconnect power.
Aug 04, 2010 | Whirlpool GH5184XPQ Microwave Oven
F3H message; microwave not heating
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
hgsshg
May 08, 2010 | Whirlpool Accuwave Microwave Oven
Started with lights on ceiling left side three tube replaced tubes replaced board now getting f3h code
You may not get an answer because your question is very confusing. You are asking about a Microwave and talking about lights on the ceiling which appears to be a florescent which you replaced 3 tubes on, but then you mention a board and a f3h? None of this really makes any sense to me. Maybe someone else may be able to understand but I cannot. Please elaborate in detail.
Feb 03, 2010 | Microwave Ovens
When trying to popcornn the sense goes off and F3H comes on
F3H means you have a failing humidity sensor, but the first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes. Then let us know if the hard reset does not fix it.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you don't find yours, or if you want to look at it without disassembling the oven, you can usually download it here.
You can usually find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
May 17, 2009 | Microwave Ovens
Kenmore elite microwave is not working. code F3H apeared after trying to run "baked potato" setting. no functions operate, display screen functions normally.
I unplugged the microwave for a few inutes, and let it reset itself. found solution on another site that DID NOT CHARGE ANYTHING for people to share solutions with each other!!!!!!!!!
Aug 02, 2008 | Elite Microwave Ovens
Error code F3H on model GH5184XP
F3H is a humidity sensor error.
You may be able to clear the error by unplugging the oven for a couple of minutes. Then plug it back in, reset the clock and try again.
If it still has the error after a reset, please write back so we can give you another suggestion.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 18, 2008 | Whirlpool Microwave Ovens
Error Code
I would recheck the control board installtion that you made, as well as verify that you got the correct replacement. Also the board may contain static sensitive componets so you might want to make sure you are grounded when handleing the control panel. Good luck
May 14, 2008 | KitchenAid KHHS179LSS Convection /...
Microwave troubleshooting
I found the fix to the F3H error on another site. Just turn the power to the microwave off for ~2 minutes at the circuit breaker, and then turn it back on. Microwave will start working again then.
Feb 23, 2008 | Whirlpool GH5184XPQ Microwave Oven
Whirlpool GH5184XPQ Microwave Oven Logo
24 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
