Question about Poulan Pro 22" Self Propelled High Wheel Mower
What Briggs and Stratton engine was used on a Mod. PR7Y21CHB Poulan Pro Lawn Mower
What Briggs and Stratton engine was used on a Mod.PR 7Y21CHB
5 Suggested Answers
jgwhomeequip
  • 1902 Answers
SOURCE: Is the air filter on my lawn mower is washable?
You can do both. Just make sure that if you wash it with your hose you let it dry out EXTREMELY well before putting it back on your system
Posted on Jun 01, 2009
  • 10 Answers
SOURCE: Riding lawn mower problem
valves need adjusting.
mowerman1857
  • 389 Answers
SOURCE: Poulan lawn mower, Briggs Stratton engine, revving problem
Most likely problem is dirt?moisture in the carburetor float bowl. You would have to remove the bowl, clean it out and also clean the main jet up in the center of the carburetor. Another problem could be that the governor is out of adjustment but this is not something a novice could or should do
Posted on Sep 14, 2009
  • 59 Answers
SOURCE: I have a poulan pro
tilt the mower down by the handle, and underneath on the bottom of the motor you will find a drain plug. it has a 3/8 square hole in it. This is the oil drain plug.
Posted on Sep 25, 2010
Poulan pro lawn mower will start with pull. Will NOT start with KEY
Take key switch out and look for damaged or broken parts or replace switch.They will come with new key.
Jun 11, 2016 | Poulan Pro 22inch 625 Series Briggs ...
Popular Pro 625 series. starts and runs but why does it die while cutting?
Poulan PR625Y22SHP Lawn Mower User Manual
homeappliance.manualsonline.com > ... > Poulan Lawn Mower
Poulan PR625Y22SHP Lawn Mower User Manual ... Briggs & Stratton 850Professional-Series Commercial Replacement Push Lawn Mower Engine (190cc, 7/8
Sep 11, 2015 | Garden
I bought a poulan pro 6.25 series with no manual please tell me the correct engine oil to use for a PR625y22RP engine please
I'm guessing you have a basic Briggs and Stratton engine, which is the standard on these machines (or a Tecumseh). The standard oil used in almost every mower on the planet is straight 30 weight oil (not multi-viscosity, such as 10W30). Just 30 weight. There should be a label on the side of the engine and on that label, it will actually be listed, but I'm going with 30 weight. For longer engine life, use synthetic oil. It will need less changing. Here is a photo off one of my Tecumseh's. You'll see it clearly states SAE 30 right there on the sticker. Hope this helps. knucklebstr.jpg
Jun 15, 2011 | Poulan Pro 22inch 625 Series Briggs ...
Where is the oil plug on a Poulan Pro 625?
Hi ca rishell
The oil drain plug is under the mower, look for the pipe plug in the engine housing, be sure to remove the spark plug wire before working near the blades as a safety item...
Free Answer, Please rate me
Apr 16, 2011 | Poulan Pro 22inch 625 Series Briggs ...
Just looking for the type of oil I need to use for my poulan pro 625 series
Briggs and stratton sae 30 engine oil or any other reputable brand sae 30 engine oil is fine. Regards Phil
Apr 15, 2011 | Poulan Pro 22inch 625 Series Briggs ...
Cannot find drain to change oil.
Poulon 550 yellow 22" Briggs and Stratton. It looks like you have to drain it out the cap by tipping it. There IS no plug on mine - spent 40 minutes looking for one, and I know what both types of the plug look like. What a lousy design. This mower is a piece of junk. The valve froze a week after I got it. Never again. A headache.
Dec 13, 2010 | Poulan Pro PR550N22SH 22Inch Briggs ...
Poulan Pro lawnmower (Briggs and Stratton 128 cc engine) will start when primed but will not stay running. New Lawnmovewr, < 3 months since purchased at Walmart
IF IT IS A BRIGG & STRATTON ENGINE YOU CAN GO ONLINE TO BRIGGS & STRATTON.COM AND ASK THEIR TECH SECTION ABOUT THE PROBLEM. FOR 3 MONTHS OLD SOUNDS LIKE DIRT OR WATER MAY HAVE GOTTEN INTO THE TANK. WHEN YOU PRIME THE MOWER YOU ARE FORCING GAS INTO THE CARB AND ENGINE AFTER THAT THE ENGINE SHOULD PULL THE GAS IN THE ENGINE, I WOULD SAY THE CARB MITE NEED REBUILDING BUT NOT AT 3 MONTHS
Sep 17, 2009 | Poulan Garden
Jun 01, 2009 | Poulan "Poulan" Push Mower
Poulan Pro 22" Self Propelled High Wheel Mower Logo
43 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
