Default ip for lan extender dx 4021 - Computers & Internet
3 Suggested Answers
SOURCE: Hi, I am having D-link
The reset provided on LAN extender is for reboot & not the the hardware reset for LAN Extender. Use console cable. Go to hyper terminal mode & you will be able to access LAN Extender irrespective of whatever IP settings are. Then in Menu under software Maintainance you will find Factory reset. Use that option & it will come back to original 192.168.0.1 address. Then you can use it again normally. You still find problems mail me at following address.
Sanjay Mujumdar.
snehak@vsnl.com
Posted on Mar 09, 2011
imon_deb
  • 341 Answers
SOURCE: wat is the default IP
you can use the link to get the deafult ip
http://www.kirti.co.in/it-helpdesk-services.html
Posted on May 05, 2011
How to make lan extender (D' Link DSL-1504G) to CU & RT
www,mywifiext.net for extenders www.routerlogin.com for routers.
the IP address is usually found on the case of the router along with the default user/ password login. You can google for default ip pass logins for any router.once you are in you can set things up.however you router should have come with a disc which would make the whole process easier.
Jan 24, 2015 | Computers & Internet
Why doesn't my netgear extender ask for name and password when I try to use it to connect to internet. It tells me that there is an authentication problem
Hi there! smile.gif Please note that the Tenda 150mbps Wireless Range Extender A3 uses a default IP address of 192.168.0.254 - you must set your IP address to the 192.168.0.* range (* = any number between 2 and 253) to login.
The default access username / password (if required) are admin and admin.
Once you've logged in, you can configure the access point to route through your existing wireless router as the default gateway (eg. if your wifi router is 192.168.1.1, then you would route through that, and set your Repeater (Extender) IP to 192.168.1.2 so that you can connect to it and then "relay" your connection through the repeater. It doesn't mirror the connection details for the existing wifi router, it simply creates an "additional" access point to connect through to your existing wifi router - creating a bridge, essentially.
The extender can be linked to the existing wifi router via LAN cable or WDS. For WDS, you will need to set the IP's 1 digit apart in the last segment (see above IP difference), and switch them both in the Wireless menu to ""Wireless Networking Mode: Network Bridge (WDS), but the SSID must remain the same (eg. "Tenda1") for both of them (it doesn't cause a network loopback), and any wireless security authentication must be identical (password / pass phrase / key + encryption algorithm) on both devices. Again, as with the above point, remember to set the gateway of the extender / repeater to that of the primary WiFi router.
For extra information and disambiguation (if required), see the following page, and scroll down: http://www.enjoypad.com/wireless-access-point/96-tenda-...
Oct 26, 2014 | NetGear N300 Essentials Edition Wi-Fi...
I cant access the 192,168,2,1
For extra information and disambiguation (if required), see the following page, and scroll down: http://www.enjoypad.com/wireless-access-point/96-tenda-... Hope i helped you.. great day to you.
Jan 30, 2013 | TENDA A3 150Mbps Wireless Range Extender
Unable to enter the extender's setup (configuration) pages anymore. Tried resetting the extender; repairing the local area connection; tried accessing the extender through its ethernet port....
How to reset the device?
Locate the reset button next to the CAT5 (RJ45) connection. Press and hold the reset button for 10 seconds and then let go. You should see your 10/100 LAN connection at your computer go away and then come back. That will confirm a reset has occurred. The unit settings should all be back to default including its IP address of 192.168.1.1.
Oct 14, 2011 | EnGenius ERB9250 300Mbps Wireless N Range...
How do i open my nat for my motorola sbg900
for static IPs: check your router settings. router should be in "bridged" mode so that all the devices have own static "lan" ips like 192.168.0.1 / 192.168.0.255 router will have one lan ip static and one global ip(one it gets from service provider) you must manually give one address of 192.168.0.1 / 192.168.0.255 for your xbox. then give correct subnetmask (default 255.255.255.0) and gateway routers lan ip (default 192.168.0.254) you can aslo put routehrs lan ip as default dns if needed dmz or port forwarding is a tool in your router settings you can assign outside ports to specific ip i have only done manual port forwarding, not sure how dmz works.
Feb 26, 2011 | Arris SURFboard SBG900 Wireless Router...
Hi, I am having D-link DSL 1504G LAN extender, it is use for so many days. Recently i tried to reset it's not happening and its old setted IP is also not working. The default IP is 192.168.0/1.1.. IN LED...
Sanjay Mujumdar.
snehak@vsnl.com
Feb 17, 2011 | Computers & Internet
I am trying to install my netgear Universal Wifi Range Extender WN2000RPT. I have green lights for my connection to the router, the extender is on and it is connected to the main PC. But I only have...
For that you need to check WAN settings and also make sure local ip settings gateway should be your router ip address. Make sure WAN settings are fine connect internet cable to WAN port of router. Then check. You can configure router with below method. Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then configure wan settings and lan settings enable wireless if you want to use wifi Then save settings and restart router Then connect cable from internet service provider to WAN port of router and connect ethenet lan cable from computer to lan port of router. . Let me know if you need further assistance. Thanks for using FixYa.
Nov 10, 2010 | NetGear Computers & Internet
Dax router
The 2 wire Home Portal 100w is a Modem/Router combination with wireless. But it has only one LAN port. So I understand that you are trying to use a DAX router for extending the number or ports. The reason they may not communicate if 2wire LAN is connected to DAX WAN is both may have same IP address. If the router has similar IP on WAN and LAN, it will not communicate. For that changing DAX router's LAN IP will be a solution or you can do LAN to LAN cascading. Connect 2Wire LAN to DAX LAN and dont use the WAN port. This way you dont have to change anything in the configuration
Dec 04, 2008 | 2wire HomePortal 100W (1000-400026-000)...
No access to set up modem or router
you might have configured your lan settings wrongly.
If your modem was setup for DHCP then you configure your lan to receive IP address automatically, DNS automatically.
If DHCP is disabled on the modem, you have to USE static IP Address for your lan ip and default gateway should be your modem default ip.
the default IP for modem is usually 192.168.1.1
if DHCP is disabled on the modem the sys ip is 192.168.1.3
So Configure your LAN setting as follow and Type http://192.168.1.1 in the address url.
Lan Settings:
IP Address: 192.168.1.3
Subnet Mask: 255.255.255.0
Default Gateway: 192.168.1.1
click ok.
and type the above url, press enter the modem will ask you for username and password.
Good Luck.
Dec 27, 2007 | D-Link DSL 300G+ (DSL-300G+) Modem
Computers & Internet Logo
739 people viewed this question
David Payne
David Payne
