Question about Hitachi 51F500 51" Rear Projection HDTV-Ready Television
Need to know how to scan tv for channels hitachi 51f500
Bought a antenna but im only getting one channel, how do i get more channels
4 Suggested Answers
SOURCE: PROBLEM WITH GETTING LOCAL hd CHANNELS
You need to have a set top box.
By law, as of March 1, 2007, almost all televisions should include a built-in tuner (called HDTV, digital, or ATSC tuners) that can receive high-definition programs over the air by simply connecting an antenna. Your HDTV doesn't have such a tuner, you'll need to connect an external tuner (or cable or satellite box) to watch high-definition programming. External over-the-air HDTV tuners currently cost at least $150.
Posted on Nov 21, 2008
  • 668 Answers
SOURCE: cant attain digital channel scan on hitachi rear projection tv
Do you have the tuner locked out for use of HDMI input only?
Most of the time when a selection is not able to be hi-lited it is
because a feature that is activated locks out other selections.
Hope this helps,
Skyassoc
Posted on Jun 17, 2009
  • 5 Answers
SOURCE: hitachi projection tv digital channel problem
yes i have same tv it has no digital tuner >( you must get a converter box
Posted on Aug 29, 2009
I'm trying to connect to antenna. Every time I scan the channels it only scans Channel 1.
The main system control memory IC to this set is faulty. Check and replace it. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Feb 01, 2016 | Hitachi Televison & Video
We have a prizmo tv and I want to get just local channels. bought a antenna. then what?
You need to look for the settings for the input type. It is usually cable or antenna (digital). Switch to antenna.
Then you need to look for 'auto find' channels, so it can scan to locate and set the channels in your area.
Your TV must have an internal digital TV tuner (ATSC) in order to get new digital broadcasts.
Dec 29, 2014 | Televison & Video
Proscan tv problems
Yes. You should connect the TV with an external antenna, and should do an auto-scan, to search and store all the available channels. Refer its user manual for details.
Jan 28, 2014 | Televison & Video
Hello, I bought an ONN TV #LE-22G90 a few months ago and I can't receive any digital channels. My time zone is: Eastern time (I live near Sherbrooke, Quebec, Canada). The tuner mode is: Antenna. I...
I bought the same TV wich is in fact a Seiki TV, see the warranty paper. The television has digital and analog tuners so is able to receive digital channels.Our television receive signal thru a rabbit ear antenna and we had some trouble to scan all the digital channels. We had to change the orientation of the antenna to receive correctly the signals and we had to scan many times. We finally conected the TV to a roof antenna so we where able to scan all the channels of Montreal, north Vermont and north New York areas since we are living in the south shore in front of Montreal. After the scan was completed we conected back the TV to the rabbit ear antenna and the television is working correctly receiving all the stations of Montreal area with a very good picture quality.
Claude
Sep 07, 2011 | Televison & Video
Cable in my area has switched to digital cable. I own a Hitachi HDTV about four years old. When I scan my channels it will only scan analog channels...the digital channels are an option but I don't...
Unfortunately, you need a set-top box. The Hitachi 65F59 has an ATSC (digital OTA) and NTSC (analog) tuner. It doesn't have a clear-QAM (unencrypted digital cable) tuner.
There are a few DVR set-top boxes with QAM tuners that you can buy separately. (You will need to make sure a given model is compatible with your service. FIOS uses a different option on the Cable Card than other providers.) Alternatively, you can get a cable box from your company.
Retrevo has the manual for this Hitachi TV here: http://www.retrevo.com/support/Hitachi-65F59-TVs-manual/id/371ci977/t/2/ . You will need to enter a code to access the PDF.
If you want OTA HD, you will need to determine the correct antenna for your area and the direction to the transmitters. (External antennas pick up more stations. In some areas amplification may be needed to get a good signal.) See antennaweb.org or tvfool.com for searches on the appropriate antenna to get a signal and where to point the antenna. Antennaweb assumes an external antenna but is very conservative in the received channel list. You would need to set the TV signal input to Air and rescan for channels if you choose to go with the OTA signal.
I wish that I had better news for you.
Sep 06, 2011 | Hitachi 65F59 65" HDTV
My father in law has one of these digital recievers and on channel scans it says no channals! im unfamiliar with these recievers and i was wondering if u need to register or need a special antenna or what...
where was the receiver bought from? The receiver needs to be registered before it can get channels. Also you need the help of an expert that will help you scan the channels using the right/correct frequency.
The receiver needs to be connected to a dish, subscribed (registered), and it should get channels.
Good luck.
Nov 24, 2010 | Televison & Video
Cant get any itv channels after retuning my new tv because of bad reception on itv channels.its a new aerial and the tv in other room ok its HITACHI 26ins L26HPO3U
in the manual i noticed a note about the active antenna and it should be showing not active when standard antenna is used.i also tried channel scan instead of first time installation which i tried a few times.so i dont really know which worked,just kept trying.
Jan 04, 2010 | Televison & Video
VIORE PLC7V95 7'' portable TV, cant get channels when scan
I notice that on mine, the positioning of the included tv antenna is very, very, very finicky. I also don't know how to "add" a new channel other than to hook it to the big house antenna and pick "re-scan" (or auto-scan or whatever it's called).
So I think your best bet is to pick a better antenna or know that even the tiniest fiddling with the antenna makes a diff. Sometimes, I even have the antenna horizontal (using the magnet) to get the good reception on a given channel. Seems like a hassle except that what should I expect from a tiny antenna....
Jun 15, 2009 | Televison & Video
Hitachi projection tv digital channel problem
Jan 30, 2009 | Hitachi 57F500 57" Rear Projection...
DH Channels
I cant get all my channels on my tv. I do my channel scan but all i get is 13 channels
Mar 20, 2008 | Hitachi 57F510 57" Rear Projection...
Hitachi 51F500 51" Rear Projection HDTV-Ready Television Logo
52 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
