Question about Crafts & Hobbies
Problems taking corners
Have larger Lionel silverline passenger trains & many times taking corners the cars come off tracks
SOURCE: Lionel train power issue
Answer a number of questions:
Is the tranformer power adequate for the train and is it a working tranformer?
Will the train run by connecting the wires directly to the two points of the train (wheels and center rail connector)?
Are the tracks new?
Is the lockon new?
Posted on Jan 07, 2009
SOURCE: WE are trying to get our lionel holiday train
There is no on/off switch. Remote will give no indication of working. Try putting engine and coal car only and try. I have had this train set for two years and the remote tends to work whenever it wants.
Posted on Dec 27, 2009
SOURCE: New Lionel Polar Express train set-up issue. The
My son just got this train and we are having the same problem. Taking the last car off solved the problem for us. I think it has something to do with accessories and the transformer voltage output (See page 14 and 15 of the instructions).
I have still not determined why it won't run with the final car but am assuming it has something to do with the lights on the cars pulling too many amps and not enough left to run the train. I will let you know if I find a solution. If anyone else knows how to solve the issue, any assistance would be greatly appreciated.
Thanks
Posted on Dec 25, 2010
  • 35 Answers
SOURCE: Lionel Train transformer goes full throttle only
Sounds like the "variable resistor" that allows for a variable speed is either defective, or has become corroded on it's switch contacts. You might get lucky with some electrical contact cleaner spray and spraying it in or around the variable speed switch. Otherwise, I'd just invest in a new transformer.
Posted on Dec 16, 2011
technowee362
SOURCE: I have a Lionel ZW transformer older version
Just wanted to add a note to this problem you are having....Question is this...How big is the train layout and how many power clips do you have on the track??
Reason is being if you only have one power clip for the whole track, you will notice a decrease (slowdown) of the train in certain area(s) so i would recommend adding another power clip or two to your layout, also If you are using old regular O track, make sure you have the metal pins in all 3 railsHope this helps
Posted on Apr 06, 2012
The Lionel lines train is going too slow and it
time to clean & lube your train & track.
here's a couple link's that should help :
Maintaining Your Lionel Trains
Cleaning Track
Nov 11, 2014 | Crafts & Hobbies
Lionel legacy will not run more than 2 trains
see pages 44 & 45 of attached pdf to figure out your power requirements for all locomotives, lamps/light bulbs & accessories.
compare total needed to power output of your transformer, if total is less that output of transformer, clean wheels, roller pickups & track.
if total is greater than output of transformer, you need more power/larger output transformer. lean wheels, roller pickups track.
http://www.slsprr.net/history/1954LionelTrainsAccess.pdf
Apr 05, 2014 | Lionel Crafts & Hobbies
Lionel toys
see attached pdf.
Jan 19, 2014 | Lionel Crafts & Hobbies
Lionel g gauge wont run on track
I think you have solved the problem. Check all the wheels to be sure that they all turn. The locomotive isn't powerful enough to drag a car with a stuck wheel.
Dec 25, 2013 | Lionel Trains Holiday Express G Gauge...
The train keeps jumping off the track
Is the track properly and carefully put together? Is one or more sections damaged take one of the cars and gently push it around watching in those places where the train derails. If it only happens at a track joint look at it more carefully.
Nov 30, 2013 | Lionel Trains The Polar Express O Gauge...
Check out these Lionel Customer Service Videos.
http://www.lionel.com/CustomerService/service-documents/video.cfm?documentID=6334
http://www.lionel.com/CustomerService/service-documents/video.cfm?documentID=6337
Dec 31, 2012 | Lionel 6-30068 North Pole Central...
When the train is heading around the track, it stops on the curve, and will only start again, when you turn it off and back on??? Does this on both ends when turning the corner? Can you halp??? Tha
Check to see if the train is lifting off the track on the curve and the roller is not making contact with the center rail. Run the engine alone slowly and try both forward and backward.
Nov 20, 2011 | Lionel Harry Potter Hogwarts Express...
My new lionel train slows down on far side of the track
There is bad contact in the track connections. You can sand the track connection sites. Another method is to run another power wire to the other end of the track where the train slows down. Even better is 3 or 4 evenly spaced power wires from the transformer to the track.
Jan 26, 2011 | Lionel New Haven Freight Train Set
Is lionel 40 watt transformer from toy train enough power to run a dual motor larger train engine it just lites up and sputters
It would depend on what engine you're trying to run. The 40 watt transformer's circuit breaker will trip off if you put too large of an electrical load on it. If the engine light stays on while it sputters, the track or the engine's motor and electrical pick-ups may need cleaning. Older engines that haven't been run for a while can get stiff. Your engine may need some lubrication.
Jan 18, 2011 | Lionel 40 Watt Transformer Train Set Track...
Ι've just joined 2 ovals 40x60 lionel fastrack, used some other items 2 Lionel 6-12018 FasTrack O-36 MANUAL SWITCH RH, 2 Lionel 6-12017 FasTrack O-36 Manual Switch LH, A few 6-12014...
It sounds as though you may have two defective transformers. Lionel has reported problems with some of their smaller transformers. I would have the transformers and the engines checked by a Lionel service station or contact their customer service department for help.
Nov 12, 2010 | Lionel 40 Watt Transformer Train Set Track...
Crafts & Hobbies Logo
Top Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Craft and Hobby Expert? Answer questions, earn points and help others
