Question about Edu-Science EDU Science TS007 Astrolon Telescope with Tripod
Step by step assembling Astro Precision 600 - Edu-Science EDU Science TS007 Astrolon Telescope with Tripod
Stop light dont work in my 1999 astro
Have you checked the brake light bulbs most common problem is burned light bulbs. remove tail light assemblies by lifting rear deck lid and removing fastener watch for assemblies to have an aleignment pin. remove assemblies and twist connector to remove bulbs. if their dark colored, or you can see the wire broken replace with the same number bulb. Number will be on bottom of where bulb plugs in.
Jan 12, 2011 | 1999 Chevrolet Astro
Tip
How to Replace Analog Joystick on PSP-2001
If your PSP's joystick won't go in a certain direction -- or characters walk by themselves, this part needs to be replaced. It is sold at the website all the way at the bottom for $16.95 and they can do this repair job for $18 more! However, it's not very difficult. Here are the steps:
Step 1. Open PSP. There are 2 screws on the top of the PSP.
Step 2. There are 4 screws behind the PSP and one on the bottom, as circled in the picture.
Step 3. Remove the faceplate and locate the PSP 2001 Analog Assembly. It is held into the console by 1 black screw, as circled in the picture.
Step 4. Remove the black screw and pry the joystick out of the PSP as shown below.
Step 5. It is important that you remove this clear silicon piece from the old joystick and install it into the new one. Its purpose is to communicate the movement of the joystick from the assembly to the motherboard. It sits between the assembly and the motherboard.
Step 6. After you transfer the piece, pry the motherboard slightly up as you slide the new assembly back in place as pictured.
Step 7. You will need to pry this piece up to slide the assembly into place so that it is seated. Replace the black screw and close it back up.
RELATED ITEMS
PSP-2001 Analog Joystick Assembly
Precision Screwdriver Set
to open PSP, PS2
PSP PSP-2001 Motherboard Silicon/Rubber
on Apr 14, 2010 | Sony PlayStation Portable (PSP) Slim...
How do you remove the hvac control from the dash of a 1996 astro van? looks like the front of the dash has to be removed first ,but I can't see any way to remove it.
A/C-Heater Control Unit Removal & Installation To Remove:
  1. Remove the IP cluster trim plate.
  2. Remove the retaining screw from the left side of the HVAC control assembly.
  3. Pivot the HVAC control assembly.
  4. Remove the HVAC control assembly from the dash in order to access the vacuum and the electrical connectors.
  5. Disconnect the electrical and vacuum connectors from the HVAC control assembly.
To Install:
  1. Installation is the reverse of removal.
Jul 09, 2010 | 1997 Chevrolet Astro
How do i get to the spark plugs on my 2000 astro van
Last time I did plugs on an Astro, I jacked up the front, removed the wheels and removed the inner wheel well material to access the plugs (some of the are a reach, persistence pays off).
Hope this helps.
May 20, 2010 | 2000 Chevrolet Astro
Is it possible to adjust the front wheel
There is no adjustment, The hub assembly is a bolt in assembly with presealed permanent bearings. I looked up the part to verify & it appears it even comes with the sensor when replaced as an assembly.
I recently replaced similar ones on a FWD SUV & didn't even remove the Ball Joint or the Tie rod ends, or the Axle. I removed the axle nut, pressed in the axle enough to make sure it wasn't stuck,(silicone lubricant) removed the brakes & caliper & rotor then removed the bolts holding on the hub assembly & using a slide axle puller, gently & gradually tapped this out. then just reassemble. I spent no more than 2 1/2 hours replacing both front hubs & I'm not that young anymore. No excessive pressure to harm the ball joint, just tapping. I did have to remove the speed sensor from the back side.
good luck
Feb 14, 2010 | 1998 Chevrolet Astro
Placement of O-ring in fuel line to pump assembly 1998 Astro
Was it a clean new o ring? If not get a new one for used ones will leak. Yes they simply slip onto the outer lip of the pressed line too
May 25, 2009 | 1996 Chevrolet Astro
Looking for the torque specs for 1998 chevy astro van?
1998 chevy astro 4.3 v6 torque specs include :
* foot pounds *
balance shaft (if equiped) gear bolt = step 1 = 15 ft.lbs. step2 = additional 35 degrees.
camshaft sprocket bolt = 18 ft. lbs.
connecting rod cap = step 1 = 20 ft. lbs. step 2 = additional 70 degrees.
crankshaft damper bolt = 74 ft. lbs.
crankshaft oil deflectorbolt/nut = 27 ft.lbs.
cylinder head bolts = step 1 = 15 ft. lbs. step 2 = additional 73 degrees. (tighten in sequence)
exhaust manifold bolts = step 1 = 11 ft. lbs. step 2 = 22 ft. lbs.
flywheel bolt = 74 ft. lbs.
main bearing cap bolts = step 1 = 15 ft. lbs. step 2 = additional 73 degrees.
oil filter adapter bolt = 15 ft. lbs.
oil pan bolt/nut = 18 ft. lbs.
oil pump bolt = 66 ft. lbs.
rocker arm with press in studs = 18 ft. lbs.
rocker arm with screw in studs = 19 ft. lbs.
valve lifter retainer bolt = 12 ft. lbs.
water pump bolt = 33 ft. lbs.
* inch pounds *
balance shaft retaining plate bolt = 106 in. lbs.
camshaft retainer plate bolt = 106 in. lbs.
front cover bolt = 106 in. lbs.
intake manifold upper = step 1 = 44 in. lbs. step 2 = 88 in. lbs.
intake manifold lower = step 1 = 27 in. lbs. step 2 = 106 in. lbs. step 3 = 133 in. lbs. ** (tighten bolts in sequence)
thanks for your vote !
Dec 28, 2008 | 1998 Chevrolet Astro
2001 ASTRO VAN AIR CONDITIONING
i suspect the vents are controlled by vacuum and are not opening due to a vacuum leak.
Robert
Sep 01, 2008 | 2000 Chevrolet Astro
Sharper and Router difference
As its name suggests, the shaper - essentially a router with added power -- is a tool used to shape wood. A shaper consists of a sturdy table and an upright shaft connected to a powerful motor. Its micro-adjustable fence ensures perfect precision cuts.
Aug 27, 2008 | Astro Pneumatic Air Riveter
Edu-Science EDU Science TS007 Astrolon Telescope with Tripod Logo
26 people viewed this question
Top Edu-Science Optics Experts
Craig Butler
Craig Butler
john cordey
john cordey
Geoff White
Geoff White
Are you an Edu-Science Optic Expert? Answer questions, earn points and help others
