Question about AKG C 519 M Microphone
AKG C519Ml connect to shure belt pack
Er r1 error message on shure wireless body pack
Does the display show something like "E1" or "F1"? See Shure's website at:
http://shure.custhelp.com/app/answers/detail/a_id/2818
Apr 03, 2014 | Shure ULX1 Body-Pack Transmitter...
Can I do this ?
I gather from your question you want to connect it to a mixer with phantom power. It is designed for a wireless body-pack transmitter such as SLX which supply's the phantom power for the microphone. Shure makes adapters to allow it to be connected. Start looking at: http://www.shure.com/americas/search?q=PG30-TQG.
Jan 04, 2014 | Shure PG30-TQG Consumer Microphone
Shure ULX1 transmitter issue. Tapping the pack, tap goes through the system.
It's probably best to call Shure at 800-516-2525. They can help you best troubleshoot and get it repaired if it is faulty.
Jan 31, 2013 | Shure ULX1 Body-Pack Transmitter...
WHAT COMPONENTS DOES A WIRELESS 87A SHURE NEED
Since it is a wireless , it needs a transmitter.
Connect the receiver to the amplifier you need to use or to the mixer .
samples of receiver here:
http://www.shure.com/americas/products/wireless-systems/all-systems/index.htm?shMicrophone=BETA87A
Aug 06, 2012 | Audio Players & Recorders
Shure ulx1 signal dropout
There are many things that can cause a drop out on a wireless microphone. See the following troubleshooting guide:
http://shure.custhelp.com/app/answers/detail/a_id/3834
Apr 03, 2012 | Shure ULX1 Body-Pack Transmitter...
Have a Shure PGX Wireless system using over-the -ears and belt packs. Could cell phones be causing our dropout problems at our Sunday morning worship services?
Unlikely, Always make sure both aerials are pointing straight upwards and mount unit as high up as possible, these have switchable frequencies too, try another channel.
Apr 28, 2011 | Shure PGX Series Wireless Microphone...
Pin configuration for a shure slx1 transmitter
Pin 1: Shield
Pin 2: 5 volts bias
Pin 3: audio
Pin 4: Loading resistor (connect pins 3 and 4 together when using a condenser microphone.)
Sep 16, 2010 | Shure SLX1 Body-Pack Transmitter for...
Shure Wireless Mike no Output
Check the battery with a volt meter. If the battery measures lower than 8 volts on a volt meter, replace the battery. I have seen entire cases of brand new batteries that are defective. Make certain to check it with a volt meter. If the battery tests fine, then send the bodypack to Shure for repairs. www.shure.com/service
Dec 18, 2008 | Shure ULX1 Body-Pack Transmitter...
Wiring pattern for line input TA4F Connector Shure belt pack RF System Thanx
The wiring is on the Shure website at:
http://shure.custhelp.com/cgi-bin/shure.cfg/php/enduser/std_adp.php?p_faqid=7
Nov 05, 2008 | Shure (UA870-WB) Microphone
AKG C 519 M Microphone Logo
43 people viewed this question
Top AKG Audio Players & Recorders Experts
Michial Gueffroy
Rob Beech
Ben Armstrong
Are you an AKG Audio Player and Recorder Expert? Answer questions, earn points and help others
