Question about Sunbeam Coffee Makers & Espresso Machines
Low water warning light flashing when water level is not low
  • 40 Answers
The water level sensor is based on a floating magnet. The magnet breaks out of it's holder in the water tank. Remove the water tank via the door on the back of the machine, tip the water out (and the magnet will probably come out too). Put the magnet back in the housing down near the water valve, and wedge the black lid on with a bit of plastic. Refill and enjoy coffee.
... or put some black tape over the red light.
Posted on Sep 23, 2014
2 Suggested Answers
  • 1089 Answers
SOURCE: The low water level light comes on in my S24, it
There is a low water sensor tube in the water tank. Pull it out and leave it out for 30 seconds, then lower the bell back into the water tank. If the bell gets water inside the it looses the aire pressure to activate the sensor. There should be only air in the bell and hose.
Posted on Jan 07, 2010
Why would the oil light stay on?
That depends on the type of oil warning light being displayed. There are 2 types of warning lights
1. Low oil pressure light which all cars have
2. low oil level light which some cars have.
Low OIL PRESSURE warning means the oil pressure is below minimum and when this happens there will be insufficient lubrication of many engine parts because sufficient oil cannot get to all parts of the engine it is required to lubricate. Until the cause is identified and rectified the warning light will remain. If you run your engine with low oil pressure you will cause expensive damage to internal engine components.
Low OIL LEVEL warning means the oil in the sump has dropped to a dangerously low level (which may be due to an oil leak or abnormal oil consumption by the engine.) This warning means the oil level needs to be topped up and the warning will stay displayed until you top up the oil. Running the engine with low oil will cause expensive engine damage.
Since it is a 2 minute job, Oil levels should be checked fortnightly as a minimum, together with radiator coolant and power steering fluid levels, if you run the car most days each week as most people do.
It is possible for a warning light to remain displayed when the cause has been dealt with because there is a problem with the sender unit. However it needs to be established with alternative checks that the problem has been fixed before investigating if there is a problem with the warning light itself.
Nov 21, 2015 | Cars & Trucks
Jetta Warning Light
It says that your vehicle is low on coolant.Get the coolant level checked.If low has to be changed.
------------Check out few help links related to your issue.Click the link below:---
Service 4wd warning light on Dash? http://howtobyme.blogspot.com/2011/11/service-4wd-warning-light-on-dash.html
Car Turns OFF due to low oil pressure warning light? http://schematicsdiagram.blogspot.com/2011/12/car-turns-off-due-to-low-oil-pressure.html
Hybrid warning Light ON? http://whatisbyme.blogspot.in/2012/05/2005-toyota-prius-hybrid-warning-light.html
Order Coolant Bypass Tube? http://whatisbyme.blogspot.in/2012/05/1991-toyota-camry-order-coolant-bypass.html
Coolant Leak? http://technoanswers.blogspot.in/2012/04/1994-toyota-camry-coolant-leak.html
COOLANT LEAK AT DRIVER SIDE NEAR FIREWALL? http://schematicsdiagram.blogspot.in/2012/04/2006-cadillac-dts-coolant-leak-at.html
MAF, IAT, MAP and Coolant Level Sensor problem all together? http://schematicsdiagram.blogspot.com/2011/12/maf-iat-map-and-coolant-level-sensor.html
Engine Coolant Temperature (ECT) Sensor Replacing? http://schematicsdiagram.blogspot.com/2011/12/gmc-engine-coolant-temperature-ect.html Loosing Coolant? http://whoisbyme.blogspot.in/2012/06/loosing-coolant.html
---------- Coolant temperature sensor dies again and again?
http://schematicsdiagram.blogspot.com/2012/01/coolant-temperature-sensor-dies-again.html
----------- Where to Add Coolant? http://repairhelpcenter.blogspot.in/2012/06/2000-daewoo-lanos-where-to-add-coolant.html
------------ Blue Water Warning Light on Dash? http://whatisbyme.blogspot.in/2012/07/blue-water-warning-light-on-dash.html
Oct 09, 2012 | 1995 Volkswagen Jetta
I have a 2006 c5500 and the water light came on. Is it as easy as draining the fuel filter? and should I drain the fuel and change the filter?
It's important to understand that a "Water" warning light, does not relate to fuel.
If it is indeed a 'water' warning light, then it is likely to be either:
1) windscreen washer bottle water is low, or
2) engine coolant fluid is low (check the level of your coolant resevoir bottle)
If your coolant is low, then you should investigate why you are losing coolant fluid.
Cheers,
May 07, 2011 | GMC C3500 Cars & Trucks
My camera says low light even with high amounts of light
The low light warning means the shutter speed is too slow and you may experience hand shaking at that level of light. Try reducing your zoom level or turning on your flash.
Mar 05, 2011 | Samsung Digimax D53 Digital Camera
Warning light
if its the ignition light,its not charging the batteryif its the oil light it means low oil pressure,caused by low oil level,oil old and thin,oil pump needs checking
Apr 06, 2010 | 1982 Yamaha XJ 650
Where to add coolant for radiator on a 95 vw jetta?
Add Coolant to spherical reservoir at right rear of engine compartment as viewed from front. If it is low the coolant gauge flashing light will warn you of a low condition.
Jan 01, 2010 | 1995 Volkswagen Jetta
Cherokee warning light
you water level in your windscreen washer bottle is low check all water levels it is go practice to check all water and oil levels once a week
Dec 27, 2008 | 1995 Jeep Grand Cherokee
Warning light comes on when accelerating from a stand-still in 1st / 2nd gear
Hi it sounds like the low water warning light for the windscreen washers, some models have a warning for low level. when you are accelerating the water level is running away from the sender. check the levels and fill up all your water bottles. try after that. hope this is your problem and it is ok.
Jun 18, 2008 | 1997 Saab 9000
Coffee Makers & Espresso Machines Logo
229 people viewed this question
Top Sunbeam Coffee Makers & Espresso Machines Experts
ray gallant
Gil Shultz
Are you a Sunbeam Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
