Question about Dometic NDR 1062 Refrigerator
No power to control panel. ac power at wall plug is ok. fuses and breaker are ok.
Ill a bad 12V battery cause control panel to not "light-up" the function indicators. (have not checked battery yet due to bad weather)
    Top Expert:
  • Dometic Master
  • 4,262 Answers
Control unit runs off 12 volts 120 volts for heater element
Posted on May 27, 2016
5 Suggested Answers
SOURCE: Dometic DM2862 made in 2007
Heating element is out. They are usually about $40.00 give or take.
Posted on Aug 30, 2008
  • 51 Answers
SOURCE: Throwing breaker when plugged up to AC
The heating element most likely has a short in it. Pull the to leads leading to it test the ohms to see if you have a short
Posted on Sep 07, 2008
  • 68 Answers
SOURCE: My fredge rm 2652 not working
You need to check your fuses on the fuse panel inside your coach. The frig will not operate on gas or electric without 12 volt power to the frig circuit board.
Posted on Mar 19, 2009
GodBlessU
  • 3513 Answers
SOURCE: Dometic 2652 does not cool that well. Food spoils.
Hi
There could be leak which causes the no cooling state in your unit.To check the cooling ammonia system, the 110v heater or the 12 Volt heaters can be hotwired direct to a power source, this will check the cooling system, The 110 V is best to check. But you need a repair person to get it diagnosed.
Please get back to us if you have further query else please accept this particular suggestion.
Thanks for contacting fixya.com
Posted on Aug 24, 2011
Wiring diagram for a 1988 sunline travel trailer.some of the light switches and outlets have no power going to them.what could be the problem?
Your trailer has two electrical systems, 12v and 120v. The 12v system has a battery and perhaps a converter/charger to power it. The 120v system must he hooked up to 'shore power.' Both systems have their own protection. The 12v system has a fuse panel, check for power at each fuse. 12v wall switches are often smaller and don't look like typical 120v switches like in a house.
The 120v system has a breaker box and circuit breakers. Reset each breaker by turning off then on again. In addition, the 120v outlets might have a GCFI outlet near a sink. It often is wired first in a breaker circuit, thus giving GCFI protection to other outlets in the circuit. Test the GCFI and make sure it clicks off and can be reset.
May 01, 2017 | RVs
2000 Isuzu Rodeo, how do I reset the circuit breaker for the power windows
a fuse is a circuit breaker
if the fuse for the power windows is ok the the problem is else where -- could be a relay that is faulty
Sep 10, 2016 | 2000 Isuzu Rodeo
I shut down the fridge. Not getting any power to it now. I have checked breakers and fuses. There is power to 110 outlet where it plugs in. No power to gas valve. What do you think the problem is?
Your Norcold refrigerator is powered by 12V DC, not 110V AC. You need to check input power at the power board. If the fuses are good and you have good 12V to the refrigerator, check to see if you are getting 12V past the 5amp fuse on the board. If not, you may have a bad board. Norcold Power Circuit Boards for Sale The Norcold Guy
Jul 12, 2015 | Norcold Inc Norcold 1210IM Refrigerator
How do i check internal fuse
No internal fuses...Check your power panel circuit breakers to see if one of them (in a dual package) has tripped without moving the handle or indicating it's tripped The easiest way to do that is use a volt meter to test for 240 volts AC at the power receptacle on the wall.
There may be 3 or 4 connectors. The two outer ones at a 45 degree slant should show 240 volts. If voltage is not present then the circuit breaker is bad.
Dec 06, 2014 | Kenmore Kitchen Ranges
What part provides power to the conrol panel?
You need to remove top and check for 12v and 5v,( put multimeter leads on wires one at a time) going into display panel from main board. If you see 12v and 5v than display board is very bad.If no voltage at all then main b. is bad or the noise filter fuse is bad.
Apr 07, 2014 | LG WT4801CW Top Load Washers
Cigarette liter stopped working then the next day the blower motor stopped working, Now the buzzer for head lites being left on stopped working and interval wipers stopped as well. This has been within a...
no power, means, what, cig lighter plug dead,?
try something else there, like a cell charger, still dead.?
if it is truely dead, the fuse is blown.
does head lights work, and engine run?
ok fuses that bad are bad, blown. (blown elements)
ok fuse that look GOOD, can in fact be bad, (tiny cracks.)
we never fail to test good looking fuses or go nuts for sure.
you can test fuse 3 ways.
1: DMM ohms, 0 ohms reading
2: voltmeter shows, 12v, on both sides of fuse, key on.
3: a fuse tester dealy bob at any autostore. (ill pass)
there are other ways, but are way too complex to type.
(ok a battery powered test light , yes, all auto stores sell them.
glow with a good fuse)
bingo?
Sep 03, 2013 | 1991 Honda Accord
No electrical power to anything - even dome light.
Check battery and chassis earth connections are ok.
Check for 12v power at the fuse/power disrtribution fuse bus; - if no power there, trace circuit wiring back to battery.
Jul 12, 2009 | Chevrolet Blazer Cars & Trucks
Maytag Dishwasher MDBH965AW will not power.
Make sure there's power getting to the dishwasher. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the dishwasher (inside the junction box, behind the bottom kick panel), if this is the case, the wiring must be repaired or replace
If the junction box checks out ok, the wall outlet socket is live, replace the main control or timer module.
Jun 19, 2009 | Maytag 24 in. MDBH965AW Built-in...
Dometic NDR 1062 Refrigerator Logo
48 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
4stevetaylor
Level 1 Expert
RV REFER LLC
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
