Question about Garmin Nuvi 800, 850, 855, 860, 880, 885T
Charge garmin nuvi 850
How do I charge Garmin 850 GPS with USB cable
SOURCE: how do i charge garmin nuvi 250 on my computer
HI,
I have the problem solved I at first had this problem after about 5 minutes of messing with my GARMIN NUVI and having many electronic gadget I thought about diffrent buttons to hit at the same time heres how you charge your NUVI with a computer and a usb cable
1st: make sure your NUVI is OFF then plug in the usb cable from the computer to the NUVI, after you hear your computer ding from new device connected, and the NUVI displays the computer icon move to step 2
step 2: if you have xp go to START and MY COMPUTER. with vista its START then COMPUTER button on the right side
step 3: with MY COMPUTER window open hold the NUVI power switch to the ON position and RIGHT CLICK the NUVI device logo (blue triangle) and select EJECT .. ( DON;T HIT SAFiLY REMOVE)
step 4: when you see GARMIN display on the screen you can letgo of the power button on the NUVI ****** if you unplugthe usb it will display message stating EXTERNAL POWER LOST SWITCHING TO BATTERY POWER***** while it is plugged to the computer the battery meter will disaper
Posted on Dec 03, 2008
SOURCE: Garmin 750 - 90 days old
it's battery problem
make sure to charge it
Posted on Dec 25, 2008
ginko
  • 19396 Answers
SOURCE: Battery does not hold charge in Garmin nuvi 770
The video on the link below shows how to replace the battery in a Garmin Nuvi:
How To Change The Battery On A Garmin Nuvi 760
See also battery_repair.
Posted on Apr 10, 2009
ginko
  • 19396 Answers
SOURCE: garmin gps won't charge while driving
If the Nuvi won't charge when connected to charge but charges on USB, then the charger port is faulty.
If the Nuvin does not charge at all , then the battery must be replaced.
Posted on Apr 13, 2009
  • 638 Answers
SOURCE: I cracked the screen on my Garmin Nuvi 750. Can it
Maybe this can help.
http://www.sharc.net/gps_repair.htm
Posted on Jul 15, 2009
HOw do you charge it?
This unit comes with a charger (AC). There is alxo a car charger. Both have a USB connecter that plugs into the side of your unit.
Sep 20, 2011 | Garmin nuvi 350 GPS Receiver
Garmin 265 wt is charging via USB cable.It will not connect to the garmin website.
The Garmin Communicator Plugin needs to be installed on your computer.
http://www8.garmin.com/products/communicator
Also check to be sure that the data cable is the correct one.
When connect between the nuvi and the computer, the nuvi should show that it is in mass storage mode by displaying a computer on the screen.
The correct cable is Garmin part number 010-10723-01.
http://www.gpscity.com/garmin-usb-pc-cable.html
Aug 18, 2011 | Garmin nuvi 265WT Car GPS Receiver
My garmin nuvi 200w keeps going into mass storage mode when plugged in to charge.as soon as it is plugged in to charge the screen appears that shows the garmin plugged in the computer. and the map...
1) Disconnecting the nuvi from the charging cable.
2) Press and hold the battery meter icon for 8 seconds. This puts the nuvi into "system test" mode.
3) Plug in the power cable.
4) Click "Exit." The nuvi should now reboot, but remain in GPS mode!
Aug 06, 2011 | Garmin nuvi 200W GPS
Garmin nuvi 205 is not recognized by garmin updater or by garmin site while trying to register
Make sure that your 205 is fully charged and that the usb cable is plugged directly into a usb port on your computer and not thru a usb hub.
Thanks for using FixYa
Apr 24, 2011 | Garmin nuvi 205W GPS Receiver
What do I use to hook my gps to the pc, to update it
You will need a USB cable to make this connection.
Any USB generic charger will work. I used on my Garmin the Motorola cellphone USB cable.
The procedure is like this:
Connect, start Garmin Nuvi and disconnect; then reinsert the USB plug when your Nuvi model number is displayed at the bottom of the screen. You can even charge your Garmin this way. To reduce the charging time follow these steps:
# change the display brightness to less than 25%
# turn off the Garmin device.
Mar 04, 2011 | Garmin nuvi 255W GPS Receiver
Can i charge my GPS (GARMIN nuvi) through my laptop?
Yes you can, just use a mini-usb to usb cable..... its the same kind of usb that most cameras use to hook into a computer
Charging it this way will take a few hours for full charge
Nov 05, 2010 | Garmin nuvi 255W GPS Receiver
Can i charge my garmin 255w thru my laptop
Yes you can,Connect your nuvi to a computer using a USB cable.The computer must be on for the nuvi to charge.A camera USB cable can be used to do this,or any USB cable that fits both the nuvi and USB port on the computer.
Jul 15, 2009 | Garmin nuvi 255W GPS Receiver
How can i charge my garmin with the computer
Is Windows (?) detecting the Garmin (USB devise)?
Is this the original cable? Is this one labeled as "USB Charging Cable" it's will not work.
Maybe you need to install the USB driver.
Connect the USB cable directly to a USB port on the computer.
Jun 06, 2009 | Garmin nuvi 250W GPS Receiver
Can I find a copy of the Garmin Nuvi 350T manual online please?
Yes. There are 3 ways to charge the Nuvi. Computer USB cable, 120VAC transformer wall plugin, and the cigarette lighter DC 12V plug for your car.
May 24, 2008 | Garmin nuvi 350 GPS Receiver
Garmin Nuvi 800, 850, 855, 860, 880, 885T Logo
22 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
