Question about Microsoft Windows 2000 Professional for PC
Not able to intstall windows 2000 profession on intel d945gcnl board ACPI error
Hi
i am trying to install windows 2000 professional on intel D945GCNL board. it is giving blue screen error about ACPI
please  help me
  • 2 more comments
  • Anonymous Dec 27, 2007
    Hi Team,
    I am trying to install windows 2000 professional on intel D945GCNL board. it is giving blue screen error about ACPI in my system pls assist
  • gandalal Feb 12, 2008
    Windows 2000 Professional is not install in Intel orignal D945GCNL Mother board so give solution
  • Anonymous Feb 22, 2008
    configuration intel original m/bd945gcpe,c2d processor2.2,ram 2gb ,hdd250gb sata seagate, sat samsung dvdwriter
    when iam installing win2000pro blue screen comes
    disable acpi or press f7 key to contiune setup or contact hardware update
    or update bios program pls help about this
    my id softfeel_touch@yahoo.com
  • Lynx0849 Oct 29, 2008
    I have replaced my motherboard in my Windows 2000 Server machine with an Intel D945GCNL motherboard and it failed to boot with a complaint that the BIOS was not ACPI Compliant.
    I then swapped out the system disk and tried to do a new install and when the installer trys to start Windows 2000, it fails with the same error.
    Help?
I pass the blue screen thanks carlosmilek very much :)
Posted on Jan 19, 2009
  • 983 Answers
As these motherboard are specially designed for windows xp so it does not supports to install windows 2000... these motherboard recommends only windopws xp,sp2 or higher versions than that like windows2003,media center edition, vista ... so we cant install windows 98 or 2000 and all ... so upgrade ur pc to win xp sp2 that s best
Posted on Feb 06, 2008
Update Bios to version 0033, works for me
Posted on Nov 18, 2008
  • carlosmilek Nov 18, 2008
    Update bios to version 0033, works for me
I am systemadmin my compane systems one or two systems run time hanging prablem.......... my name is karthikeyan,K
Posted on Feb 08, 2008
Same problem, when doing F7 it gets past the ACPI dump but hangs on Win2K setup. Intel doesn't support Win2K with this board.
These mother boards will not support windows 2000, check the below link of INTEL
http://www.intel.com/support/motherboards/desktop/sb/CS-008326.htm
Regards,
Praveen Nair
Praveen@alsagrsaudi.com
Posted on Jan 26, 2008
I try this on a Spanish Version of Windows 2000 SP4 and it didn't work. The installation proccess will load the ACPI even if i press F7.
Posted on Jan 24, 2008
I am facing the same problem and will try as per your suggestion. Thanks for the post.
Posted on Jan 11, 2008
    Novelist:
  • 69 Answers
I am Vikram Kumar Thumu from India-Hyderabad. I have seen your message on the issue related to the error message related to the ACPI during the installation of Windows 2000 on your PC. I would like to provide my suggestion on this issue.
PROBLEM: During Windows installation the system displays a blue error screen reporting that the BIOS is not suitable for use with ACPI.
Solution :
If your system reports this error then reboot it and wait for the prompt about pressing F6 (to use other mass storage devices). At this point press F7 (not F6) so that setup will install APM power management in place of ACPI power management. Installation should then continue to completion successfully.
I hope this should resolve the issue for you.
If you need any further assistance on the issue, you can mail me at thumuvikram@rediffmail.com, I'll be glad to assist you.
Bye...
Posted on Oct 27, 2007
SOURCE:
Download Intel D945GCNL
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Intel%c2%ae+945+Express+Chipset+Family+Boards&ProductProduct=Intel%c2%ae+Desktop+Board+D945GCNL
Nov 24, 2011 | Intel D945GCNL Motherboard
I have a intel d945gcnl board. My computer restarts when it used upto 30 mb graphic memory.
Hi, you can try to upgrade the graphic driver from here:
Remember to select your operating system.
You can also try to add more memory ( ram )
to your system.
Or you can add a better graphic card
PCI Express x16 connector
Hope this will help you.
Aug 19, 2011 | Intel D945GCNL Motherboard
Audio Problem
http://intel.driversdown.com/Intel-drivers/Intel-Desktop-Board-D945GCNL-HD-Audio-Controller-5605-Windows-Vista(32-64)-XP(32-64)-2000_77686.shtml
Intel Desktop Board D945GCNL HD Audio Controller 5605 Windows Vista(32/64)/XP(32/64)/2000
Installs the Realtek audio driver version 5605 for Intel® Desktop Boards.
IMPORTANT: Audio drivers may fail to install in Windows* XP 64-Bit Edition. Symptoms may include error messages, such as "Error in installation" or "Unknown error". Microsoft's Update for Windows XP x64 Edition (KB901105) fixes this issue. After installing this update, the audio drivers for Windows XP 64-Bit Edition will successfully install.
Apr 23, 2009 | Intel D945GCL Motherboard
Audio driver not installing
go here
http://www.intel.com/support/motherboards/desktop/D945GCNL/
Jan 13, 2009 | Microsoft Windows XP Professional With...
Problem installing windows 2000 prof. on intel D945GCNL Motherboard
Do you have the correct version of Windows for INTEL based x86 processors?
Either that or you may need to update your BIOS software for that.
Dec 14, 2007 | Microsoft Windows 2000 Professional for PC
Problem istalling windows 2000 professional on a pc with intel d945gcnl motherboard
try to make bios settings default and make a proper installation
The bios in this system is not fully ACPI compliant. Please contact your system vendor for an updated bios. If you are unable to obtain an updated bios or the latest bios supplied by your vendor is not ACPI compliant, you can turn off ACPI mode during text mode setup. To do this, simply press the F7 key when you are prompted to install storage drivers. The system will not notify you that the F7 key was pressed - it will silently disable ACPI and allow you to continue your installation."
Dec 04, 2007 | Microsoft Windows 2000 Professional for PC
Microsoft Windows 2000 Professional for PC Logo
577 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
