Question about Rockford Fosgate RFZ3412 Car Subwoofer
What is the airspace for an rfz3412
Not a prob. got free **** so what is the airspace for an rfz3412
What are the possible reasons a plane would do this?
Departure controllers have blocks of airspace with altitude limits. Chances are that there was other traffic that they needed to have out of the way so they held him at 5000 before clearing him to the next controller's airspace.
Jan 04, 2017 | Aircrafts
What does more/less airspace mean in terms of sound when talking about a sub-woofer box?
air space behind the cones of a speaker is critical to the performance of the speaker. the space behind has to be air tight. If the specs state a minimum of 1.25 cu ft and a max of 1.75 cu f t that is what you will have to achieve for the performance If you build a box for 1.75 cu ft then when the speakers are fitted you will probably spot on. Go on line for speaker box construction and you will get valuable info. for your project
May 29, 2013 | Kicker Comp CVT 10" Car Subwoofer
What's the airspace a 12 inch jl audio w3 need?
You're gonna need .5 cubic ft minimum
Sep 18, 2012 | Car Audio & Video
Yes im trying to figure out what the airspace for a rockford fosgate p1 12 in sub. i want to build a ported box for it to put in a entertainment room
Hello... I can help you with this. The correct airspace for a p1 Fosgate 12 is 1.79 cubic ft. I don't think the performanace of a car audio sub will be the best choice for a home audio application, though I hear of it being done on many occasions. Just that the design of the sub is different for different applications, car, home, p.a., etc. Hope this helped! Good luck with your venture!
20 year car audio installer
Mar 14, 2011 | Rockford Fosgate Car Audio & Video
What is the airspace needed for eclipse sw8152dvc
hi you need minimum 5 cm airspace in front
and 10 cm minimum at back
in order having clear sound
Jan 13, 2011 | Eclipse SW8152DVC Car Subwoofer
I have a 2011 gmc sierra and im putting a kicker comp vr 12 in there and i was wondering how much airspace i would need the box im looking @ is .98 i hope its enough airspace and its ported box
For optimal performance there is really only one size for the box .Firstly, you get two different types of subwoofers, an open air, or closed air sub. If it is an open air sub ( hole with mesh in the center of the magnet) no ports are required, and the box should be sealed on the inside with silicone sealant. If it is a closed air sub ( no hole in the magnet) you need a 50mm port about 120mm long. If it is a 12 inch sub the box size will be 13 inches x 13 inches x 13 inches. Hope this helps
Dec 04, 2010 | Kicker CompVR 05CVR84 Car Subwoofer
Does this TV overheat and fail if installed in a cabinet with no cooling system? Can the boards burn out?
ANY TV WILL FAIL IF PROPER COOLING IS NOT PRESENT. A GOOD RULE OF THUMB IS AT LEAST 2 INCHES OF CLEARANCE AROUND THE ENTIRE SET. ANYTHING LESS, I WOULD RECOMMEND ADDITIONAL COOLING SOLUTIONS.
Aug 13, 2010 | Pioneer Elite PRO-1540HD 60 in. Plasma...
Kicker 8 inch l5 problem!
Possibly. Actually there are sub rings you can buy to convert a regular box over to one that will accept a square sub without cutting the whole out in your box to make it square. The airspace may be lacking a little bit.
May 20, 2010 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Airspace needed?
http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/
Go directly to the website and it's all there.Sealed, Ported, and Bandpass specs
Apr 09, 2010 | Coustic Car Audio BP124 Car Subwoofer
I need to know how much airspace my 10" DVC audiobahn speaker requires
what type of audiobahn sub is a critical and missing factor of your statement so the specs im about to give you are very generic and can vary because like i already said i need to know the model number to be precise
it should be at 0.6 -2.35 and vented for the aw1005n this specification is for that sub only and depending on what kind of music you listen to will help decide the airspace u need if u get that model number let me know
May 22, 2009 | AudioBahn DUB200 Car Subwoofer
Rockford Fosgate RFZ3412 Car Subwoofer Logo
Top Rockford Fosgate Car Audio & Video Experts
seankane89
Level 1 Expert
Tygh Duval
Tygh Duval
Professor_V
Professor_V
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
