Question about Gateway M305CRV Notebook
Where is the cmos battery on a gateway m1625 motherboard
3 Suggested Answers
SOURCE: Where is the CMOS Battery for the gateway M320 located?
I have a BIOS password issue?
Posted on May 25, 2009
ssebata paul
  • 159 Answers
SOURCE: my cd player wont work, cant find it in my system?
replace new or use external
Posted on Dec 30, 2009
Need to replace cmos battery in Gateway MP8708
Power down PC. Open the PC tower. Look at the motherboard and find the CMOS battery. Looks like the picture below. Make sure you touch some sort of metal area on the PC to ground yourself before touching the components. Use something thin to pop the old CMOS battery out. The CMOS batteries are usually universal. CR2032 is the usual type used. These can be found at a CVS or Walgreens. Once you have acquired the next battery, make sure the CR2032 is facing up and just press it in.
-Ben P.
Dec 31, 2012 | Gateway Computers & Internet
Cant find cmos battery on gateway dx4320-19 motherboard
Welcome to FixYa
Here is an image of a cmos battery for a motherboard. Hopefully you could use this as a reference
A cmos battery could be located anywhere on the motherboard but they all look alike.
Hope this helps
May 11, 2011 | Gateway DX432019 PC Desktop
Can anyone tell me where the CMOS battery is on a gateway fx6802 pc? Or how to reset the bios?
CMOS battery situated in motherboard. To reset Bios please re pin the jumbernazarmpp_0.jpgnazarmpp_1.jpg
Apr 30, 2011 | Gateway Computers & Internet
What is the correct battery for the BIOS memory for a Gateway model 4025GZ notebook ?
http://cgi.ebay.com/GENUINE-ACER-250-REAL-TIME-CLOCK-RTC-CMOS-BATTERY-/250619795738?pt=Laptop_Batteries&hash=item3a5a1a991a
Method.
When your Gateway computer is switched off, it still keeps track of various system information such as the date and time, thanks to a small battery that never powers off. The size and thickness of a dime, the CMOS battery can run out and need to be replaced. You can swap out a dead CMOS battery with a new one by removing the Gateway computer's side access panel.
Difficulty: Moderate
Instructions Things You'll Need:
  • Phillips-head screwdriver
  • CMOS battery replacement
  1. 1
    Shut down the computer. Remove the power cable from the back of the computer case. Disconnect the cables for the monitor, mouse, keyboard, and printer.
  2. 2
    Set the computer case over on its side. Use the Phillips-head screwdriver to remove the two case screws at the far left end of the case.
  3. 3
    Slide the side access panel to the left and remove it from the computer case. Find the CMOS battery port, which will be located to the lower left of the processor in most Gateway computer models.
  4. 4
    Lift up the plastic clip holding the CMOS battery in place. Slide a fingernail under one side of the battery and lift it off the motherboard port.
  5. 5
    Check the orientation of the new battery and compare it to the CMOS motherboard port. Push the new battery into place in the same direction that the old battery was facing. Push down the plastic clip.
  6. 6
    Set the side access panel back onto the Gateway computer case and reattach the case screws. Plug in the Gateway computer and power it on.
Jan 01, 2011 | Gateway 4025GZ Notebook
When i turn on my gateway m1625 it only blink but never load the bios what can i do and how thank you for helping me
Start taking your laptop apart piece by piece and test it after each removed component:
1. Remove the hard drive and test the laptop.
2. Remove the DVD drive and test the laptop.
3. Remove the wireless card and test the laptop.
4. Unplug the display panel from the motherboard/video card and test the laptop.
etc....
Continue taking it apart until you have only three major components connected: motherboard (with video card), processor, and memory. If you still experience the same problem, most likely it's bad motherboard.
By the way, before you start, try reconnecting the memory module. If you have two modules installed, try removing them one by one and test the laptop with each one separately.
Sep 23, 2010 | Gateway M-1625 Notebook
Hi, how can i reset BIOS password, notebook Gateway MT6705?
According to Gateway, there is no easy way to change the password. You need to contact Gateway Customer Services and ask for assistance.
Dec 17, 2009 | Gateway MT6705 Notebook
Where is the CMOS battery on the located?
you will find it on the motherboard.
it will have a wire attatched to it that plug's in like a telephone battery
Jul 27, 2009 | Gateway Computers & Internet
Gateway 450rog cmos battery
The CMOS battery is located on the motherboard, just under the bottom left side of the keyboard, by the letter 'V". It looks like a clock battery, marked 3V (volts). The battery comes out of its "cage/connector" by gently lifting it with a small flat screwdriver. Replacement CMOS batteries are inexpensive and readily available at any computer shop. Hope that helps
Mar 15, 2008 | Gateway 450ROG Notebook
CMOS BATTERY
Gateway 450ROG CMOS BatterySmall internal battery that maintains calendar and clock settings.
PLEASE NOTE: This is not the battery that powers your laptop; it only maintains certain internal settings. If you need a main battery, please refer to the page on our web site for your laptop model.
CMOS batteries are located on the motherboard; if you are not comfortable with the inner workings of your laptop, you may want to consider having the battery installed by a qualified technician.
Here is the link to their site for your cmos battery
http://www.gatewaylaptopparts.com/shopexd.asp?id=1082
Feb 25, 2008 | Gateway 450ROG Notebook
Gateway M305CRV Notebook Logo
20 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
