Question about Faema Smart A2 Automatic Espresso Machine - Espresso Machines Faema
HI I have a faema coffee machine and i am taking it to a event tomorrow to sell espresso coffee i would normally have it running throu the mains i am now going to use a water tank that is more conside
Coffee machine that is being used for coffee event
SOURCE: User Manual
Please email me tomorrow at dspringer5114@hotmail.com. I can scan my manual and send you the pdf from my office. I just need you to remind me. Thanks
dgsrgr8
Posted on Jun 01, 2008
EsWorld
  • 1618 Answers
SOURCE: User Manual for Faema D92/A, doesn't dispense coffee, only water
This will take some time so bear with me.
The problem with the machine is most likely the solenoid valve(black or blue electrical box connected on the side of the group), for easier access remove the front panel there are about 5 screws holding it in place, 2 on the bottom and 3 on the top under-side. Disconnect or turn off the water supply. Then using a 14mm open end wrench remove the nut and the discharge pipe. Do Not remove the 4 small allen wrench screws on the brass piece connected to the machine. Now remove the electrical box over the silver pipe, and using a cressent remove the silver pipe from the brass rectangle square. Slowly open the water supply, if water shoots out then the head is clear, we will move on if not, use a pin and clean the middle hole. Check the silver pipe also there is a small plunger in there press it in if it moves freely then we are good, if not you can try soaking it in puro caff until it clears or just get a new solenoid coil. Remove the shower screen and screw in the group head, you can soak those also.
If you still cannot get water, then we will have to go deeper into the machine.
Posted on Jun 03, 2009
EsWorld
  • 1618 Answers
SOURCE: we have an older faema due machine. Currently the
The tip of the steamwand is clogged or the fitting where it connects to the boiler is blocked with carbon.
Posted on Jun 20, 2009
  • 3 Answers
SOURCE: Commercial Faema Espresso Machine with 2 heads, model #E97/A-2
I need the E97 faema Manula the A3, I think it is the same as the A2, I appreciate it if you have it and sent it to my mail. Thanks gbproduc@hotmail.com
Posted on Dec 01, 2009
  • 176 Answers
SOURCE: I've got a faema E91/A 3 group espresso machine.
the original cord how many wire have? on the label what writes? if you have 5 wire (blue= null or neutral, green whit yelo= grounding, brown, black and grey= phases, is posible to have a red wire instead of grey, black or brown wire), on the blue wire whit one of the phases must have 220 V, on the brown whit another phase you must have 380V, if you had a bad conection is posible to damage something in electronic automatisation of the espresso machine, that machine must be conected in a water suply whitin a softner an befor use is posible to must be triggered manually. by the way, this machine must be proper instaled by a specilised personell beacause it is the risc of electric injuri and other bad things. your E1 is posible to be a temperature probe damaged or because of water mising and in 20-30 min. the machine was reaced a high temperature and safety thermostat has occurred. the best you can do is to call a repairman to solve this, if you try to repair your self it is posible to make worst.
Posted on Feb 21, 2010
Our coffee machine is continually beeping and the water flow will not flow automatically, is there a reset button or something
It's beeping because it's in programming mode. Usual reason with a machine of this age is that the touchpad has failed. Water gets into the touchpad membrane after a while, which makes the controller think a button has been pressed. If it thinks the STOP button is being pressed/held for more than 5 seconds, it goes into programming....
To confirm: Remove drip tray, take lid off controller box and unplug one of the flat plugs from the keypad (there will be two long thin plugs next to each other, and probably a space or two for extra plugs). When you get the correct one, the beeping will stop and the machine will resume normal operation on the working keypad.
Oct 23, 2014 | Faema Smart A2 Automatic Espresso Machine...
Faema smart a2 espresso machine i need to reprogram it is there any one can help me out
Assuming you've got a grind which brews out correctly when manually brewed.....
Fill and tamp a portafilter, ready. Press and hold 'stop' pad until machine beeps. Tap the pad you want to program. Lock in the portafilter. Press and hold the pad until you get the volume required. Press 'stop' to exit programming, the machine will stop beeping.
Jun 06, 2014 | Faema Smart A2 Automatic Espresso Machine...
Waterpump makes a lot of noise
It is possible that the water coming into the pump from the mains is obstructed. If you have a water filter, that might need to be replaced. Some of the pumps have a stone filter on them, you will see a huge nut on the inlet side of the pump, that might need to be cleaned. Also check all water lines make sure you have no kinks. Pay attention to the gauge on the machine when the noise is happening if the water dispensing pressure lever should be at about between 3-6 bar when not being used and about 9 when brewing espresso.
Feb 19, 2014 | Faema Smart A2 Automatic Espresso Machine...
Need a users manual in english for the faema due espresso machine
Try Googling (faema)(FA60081)(manual) without parens. You may have to refine your search to get an English version.
Oct 10, 2011 | Faema FA60081
I purchased a Faema D92/S-1 from a restaurant that was closing. I was wondering if there is a place where I can find directions on how to operate it. Also, looking for replacement parts such as side...
try to get www.nuovaricambi.it (usa office) and ask them for service in your area, they are selling spare parts to services.... good luck and all the best
Feb 03, 2011 | Faema FA60081
I have a faema no stop 2 head espresso machine from 1983. how do i start the machine?
Just turn on the main on/off switch wait about 20-30 min. for the machine to get up to temperature once is ready you can use it.
To make an espresso, put the espresso in the warm portafilter and push the down oce is ready push it back up.
If you need more details, Let me know
Jan 13, 2011 | Faema FA60081
We have a faema e92 but our mains water is off, can we manually fill the tank without mains water?
The machine can sack the water directly from a water tank since the water inlet hose is conected first to presure pump. Just insert the water inlet hose in a water tank, however please take care that if you leave the pump work without ay water for more than 2 minutes the pump might be destroed.
Feb 13, 2010 | Faema FA60081
Does the Faema D92/A-2 have a bacl flow valve on it so the steam will not back flo into the city water system
A backflow preventor is normally installed by your plumber on the inline for the machine.
Oct 30, 2009 | Faema FA60081
User Manual
dgsrgr8
May 31, 2008 | Faema Coffee Makers & Espresso Machines
Faema Smart A2 Automatic Espresso Machine - Espresso Machines Faema Logo
16 people viewed this question
Top Faema Coffee Makers & Espresso Machines Experts
pawnpower
richie46
Are you a Faema Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
