Question about HP Photosmart 7520 All-in-One Color Inkjet Printer - Black
Printer in an error state
I have a document that is stuck in the queue on my printer. I have tried turning the printer off, disconnecting it, restarting computer, etc. and it still won't clear. I cannot print anything.
dg9dotorg
  • 151 Answers
SOURCE: HP Deskjet 3845 print queue not clearing
Have you tried going to safe mode, turning off the printer and manually opening it at the control panel>printers... try and delete or cancel prinitng at these settings...
Posted on Dec 09, 2007
SOURCE: Printer printing documents again when computer restarted
go to the "computer" place at the start
then go to printer, or do whatever u have to do to go to printer
then click the button or icon
it should show the documents names
click it and press delete
there
Posted on Mar 06, 2009
SOURCE: my HP laserjet P1006 won't print
free driver download
Posted on Apr 01, 2009
Rider On Way
  • 1679 Answers
SOURCE: my printer, HP 8500, has
There are 2 simple methods to resolve any print job stuck in queue issue. However, both the methods will not fix printing issue if the HP Printer is in Error mode. Make sure your printer is able to print self test page to prove its functionality,
First method.
This Utility program resolve all the printing issue for HP Printers Only ( Network and USB connection )
This Utility will Resolve :
1. Check Connectivity between the Pc/laptop and HP Printer
2. Check if there any Documents stuck in Queue
3. Check if all the software/Drivers are correctly Installed
4. Check if the HP Printer icon is the default icon to print
5. Will Resolve Printer Spooler Issue and few more issue
Download the file on Desktop and Run the program ( Ex. File name = HPPDU.EXE )
Click Here to download the Utility and save on Desktop location
Run the HPPDU file and follow the instruction on screen to fix.
If this does not fix, try the 2nd Method given below ( this is manual process to clear the print job stuck in queue )
This works for all brands of printers ( HP, Canon, Epson, Brother etc )
Click Start > Programs > Accessories > then select Command prompt, then the black window will open and there type NET STOP SPOOLER and hit enter that will confirm service is stopped , after that on the black window type NET START SPOOLER and hit enter. Repeat this step 3-4 times and end the command with NET START SPOOLER and hit enter. Open the Printers folder and Refresh the Window ( Press F5 on the keyboard )
The service will be started and all print queue should already be remove.
// Above given solutions help in resolving print queue issue, however check the printer functionality if it is working fine ( the printer should be in working condition and should be able to print self test page, this utility cannot fix printer hardware issue //
Regards,
Ron
* Please rate this solution with Thumbs up and comment to help us improve providing support
Posted on Jul 02, 2011
puertobori
  • 7733 Answers
SOURCE: Using printer on network. Status
Reinstall it! There are some corrupt installation isssues and need a reinstallation.
If you need more help post back!
Thumbs and testimonial are welcome!
Posted on Jul 27, 2011
I cancelled a document while it was printing and it is still in my queue days later as deleting and it wont let me print anything else or restart that print job.
The best way to delete the print job is to turn the printer off, then disconnect the cable from the printer to the computer. Turn the printer on with the cables off, and go to your computer and delete the document, Then once it's deleted, turn the printer off again, and then hook the cable back up. Then turn the printer back on. That should do it.
Good Luck
Mark
Sep 13, 2014 | HP deskjet 3940 color inkjet printer -...
All print jobs stay in queue with epson all in one xp600 series
Hi Violet,
There might be a number of reasons due to which your documents get stuck in a printer queue. Overloading and driver issues are the major reason behind this. If you are simultaneously printing hundred of documents then sometimes your printer jobs gets stuck in the printer queue. Then if your Printer drivers are corrupted then also while printing the documents sometimes it might get stuck in the print queue.If You Still Need Assistance Then Follow US For On : Epson Printer Support
Feb 05, 2014 | Epson Stylus CX6600 All-In-One InkJet...
I have a document stuck in the print queue, which won't cancel or restart, help!
Turn off printer for 2 minutes @ least, turn back on, or delete printer and re-install printer. Go to HPsupport website enter your printer model info update drivers.
Jan 28, 2012 | HP PSC 1510 All-In-One InkJet Printer
I cannot get my document printed. when i try to print I get the message printer is busy then , another message that states a printing error occurred appears
Open Notepad and type the following lines:
net stop spooler
del %systemroot%\system32\spool\printers\*.shd
del %systemroot%\system32\spool\printers\*.spl
net start spooler
Save it in your root directory as: C:\DeletePrintJobs.cmd
Create a shortcut for it and move it to your Desktop
Now everytime you have print job(s) that got stuck in the print queue
go to your desktop and Double Click on the DeletePrintJobs.cmd
It will clear all pending print jobs in the print queue and allow you to
print new jobs again.
Jul 18, 2011 | Computers & Internet
My printer, HP 8500, has been trying to delete a document for hours with no apparent results. I am unable to print anything else although it does put a new document in queue. I do not get any error...
First method.
Regards,
Ron
Jul 02, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
Everytime I go to print a document, it won't print. I go to open all active printers and it has documents I've tried to print in the past that didn't end up printing, and I go to delete or cancel the...
1. make sure to check if the hardware is able to make color copies, that way u can be sure there is no harware issue. 2. You can download and run an HP utility tool that can help you fix the problem instantly from this page: http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?cc=us&lc=en&lang=en&softwareitem=mp-91788-1 3. If you still get the same issue, restart the computer and check the print queue. If there are no print jobs in the queue, you resolved the issue. 4. If print jobs remain in the queue, check the connection between the HP printer and the computer, make sure USB is properly seated if its a USB connection, otherwise if it's wireless, make sure both devices are connected to the network. 5.If issue still persists,make sure the printer is set to online. 6.Manually clear the print queue, restart the comp then try printing again. &. If #6 doesn't resolve the issue.Restart the print spooler by clicking on Control Panel, then double-click Administrative Tools .Double-click Services--In the list of Services , double-click Print Spooler . The Print Spooler Properties window opens, then click Stop to stop the Print Spooler. Click Start to restart the Print Spooler.Click OK and restart the computer.Try printing again. 8. If print jobs from one specific software program are getting stuck in the print queue, the issue might be with the software program or the print driver.Close the software program from which you are trying to print, and then open it again.Print a document from the software program.If the print job gets stuck in the print queue again, try printing a document from Notepad to determine whether the problem is with the program or the driver.Repeat the steps earlier in this document to manually clear the print queue.Type a test message in Notepad and print it, making sure you select your HP product as the printer. If you can print the document from Notepad, but not from the software program, contact the software program manufacturer for assistance.If these steps resolved the issue , you do not need to continue troubleshooting. 9. Remove and Reinstall HP software, then try printing again. If these steps resolved the issue , you do not need to continue troubleshooting. If the issue persists , continue to the next solution. 10. A power reset drains the power from the product and returns to the same settings after restarting. A power reset is a common troubleshooting step, and you can perform one for conditions like print jobs getting stuck in the queue. With the product turned on , disconnect the power cord from the rear of the product.Unplug the power cord from the wall outlet.Wait at least 15 seconds.Plug the power cord back into the wall outlet.Reconnect the power cord to the rear of the product.If the product does not turn on by itself, press the Power button to turn it on. 11. If you have tried all of the preceding solutions in the order presented , and the issue is not resolved, try HP forums.
Mar 22, 2011 | HP Deskjet F4180 All-in-One InkJet Printer
MY LEXMARKX5650 THERE IS A DOCUMENT STUCK IN MY QUEUE. IT SAYS DELETING BUT IT DOESNT DELETE I CANT PRINT MY OTHER DOCUMENTS I REALLY DONT WANT TO HAVE TO RESTART THE PC IHAVE A FILLED IN DOCUMENT THAT...
Disconnect the printer from the computer. Open the print queue, and be sure that the title bar says "printer offline". If it doesn't, select "use printer offline" from the file menu. Then try to delete the file multiple times if necessary to clear the queue. You may have to reboot the computer, but try this first. Also, you can try pressing cancel on the printer itself. If none of this works, disconnect the printer from power for 10 minutes, and try again. Good luck!!
Sep 29, 2010 | Lexmark X4650 InkJet Printer
Document stuck in queue and will not delete or print.
Its a common problem. All you have to do is to restart the Print Spooler service and delete the print queue. To restart the service follow the steps: Open Control Panel > Administrative Tools > Services. Now find service named "Print Spooler" and right click over it and select "Restart" to restart the service.
Now open the "Printers and Faxes" folder and try to delete the print queue. Now you will be able to delete the print queue. If applicable you can follow the steps once again if any print queue refuse to get deleted.
Once the print queue is empty, you can print from your printer smoothly.
Cheers!
Apr 05, 2010 | Dell 926 All-In-One InkJet Printer
Prin queue problem
disconnect printer from computer
cancel documents in queue
if using a straight USB connection, delete all instances of printer. else remove duplicate printer icons.
reboot & reconnect printer (swap cables if not detected)
This will fix your problem.
Don't forget to rate my help! :-)
Thank you for using FIXYA!
Pablo
Aug 31, 2008 | HP DeskJet F380 All-In-One Printer
HP Photosmart 7520 All-in-One Color Inkjet Printer - Black Logo
29 people viewed this question
Seeker5211
Seeker5211
