Question about IOGear GCS72U - KVM / audio switch - ports (S7584636) KVM Switch
Iogear not switching
I just got new computer as my old one died I have a work and home set up with the KVM IOgear to switch back and forth, plugged in the second computer and the switch won't switch I push the button and the light just stays on the single computer. I did try turning the computers off and then on again :)
  • 5 Answers
SOURCE: Iogear KVM Switch Not Working at All
jerk_shop is correct, the GCS632U does get the power it needs to function from the USB ports of the computers it is attached to. Make sure the USB portion of the KVM cable is plugged directly into a computer without the use of any USB to PS/2 adapters. You will also want to make sure that at least one computer is turned in order for this KVM to function.
Posted on Jan 17, 2009
firesnake09
  • 2923 Answers
SOURCE: All Keys do not work on keyboard with KVM switch
GCS632U is designed to work with standard USB keyboard an mouse only. You have to make sure that you are not using any type of adapter such as PS/2 to USB adapter. To further isolate the problem, please follow the steps below:
1. Connect the USB keybord directly to th computer to make sure that the keyboard is working properly.
2. Make sure that the keyboard is connected to the keyboard port on your KVM switch. You may take a look under neath this GCS632U (near the USB ports) and you will see an icon where to connect the keyboar and mouse.
3. If you're still gettings the same problem, Try power cycling this kvm switch by disconnecting if from the computers and disconnect also the keyboard and mouse from the KVM switch and leave them disconnected for a minute or two.
4. Reconnect everything after two minutes and then reboot the two computers.
5. If same problem exist, try using different USB keyboard.
NOTE: This KVM swith does not work correctly with wireless, gaming and smart keyboards because it's designed to work with standrd USB keyboard only.
Posted on Apr 06, 2009
SOURCE: IOGEAR KVM SWITCH WILL NOT TOGGLE BETWEEN COMPUTERS
On my KVM switch it works pressing
Scroll lock key twice then
press up or down arrow
to toggle
Posted on Apr 30, 2009
Sailorm0on
  • 61 Answers
SOURCE: KVM will only switch one way
Please make sure that the keyboard is hooked up on the KB port of the KVM. check underneath the GCS632U for the correct console port. you will see a keyboard and mouse icon. Make sure that the keyboard is connected to the keyboard port. tap scroll lock key twice to switch between computers.
Posted on May 16, 2009
  • 5603 Answers
SOURCE: repeated IOGear KVM switch failures
As a wild guess, it sounds like a static discharge MIGHT be affecting the switcher causing it to crash.
Try increasing your humidity to 40% and grounding yourself before touching the keyboard... This is the season for these static electricity problems... get nipped all the time and you MAY not even feel it to be enough to zap the switch.
Posted on Jan 11, 2010
Testimonial: "Great idea, Fredy. I am having static problems all the time in my office. I will make a ground pad on my desk top. Thanks"
This worked great for a couple of months and now
It may be possible that the KVM has gone bad. Make sure the keyboard is plugged into the keyboard port of the KVM as this is the only port on the KVM that will recognize the hot key commands. If you have ensured the keyboard is plugged into the keyboard port and you have tried multiple keyboard and still experience problems I would assume the KVM is having problems. IOGear KVMs have a three year warranty and their support can be reached by email support@iogear.com.
Jul 26, 2010 | IOGear GCS634U KVM Switch
New IOGear GCS632U KVM inop
First, disconnect the KVM switch from the computer(s). Disconnect also the keyboard and mouse from the KVM switch, including speakers (if there is). Leave the KVM disconnected for 5 minutes.
Before you reconnect the KVM switch, make sure that the computers are turned off. Re-connect the KVM switch to the computers, and then reconnect the keyboard and mouse.
Turn on the first computer, followed by the second one. If you are still not getting any light indicator, then the KVM switch is dead.
You may contact IOGEAR through 866-946-4327.
Thank you for using FixYa!
Jun 08, 2010 | IOGear GCS632U 2-port KVM Switch
I am looking for the hotkey combination for our HP 336044-b21 KVM switch from a iogear KVM?
IOGEAR KVM switches uses Scroll Lock for the hot key. The models of IOGEAR KVM switches starts the letters "GCS". I don't think that your HP 336044-b21 came from IOGEAR.
Anyway, if that's an IOGEAR KVM switch, you may quickly press Scroll Lock twice + Enter (for two port KVM).
Scroll Lock twice + port # + Enter (for 4 port, or 8 port KVM).
NOTE: You need to verify the brand of your KVM switch by referring to the user manual of it.
Thank you and good luck!
May 20, 2010 | HP 336044-B21 8-port KVM Switch
AN IT person set up my computer so that I could switch back and forth between the old and new computer (Win 7). I click "Menu", Click the > arrow 6 times to select the appropriate bos, I then select...
On that model of KVM switch,making sure Both computers are on, you should only have to hit the "Scroll Lock" key twice, then hit the up arrow to switch between computers. like "tap-tap" on Scroll Lock key then "tap" on the up arrow key. See if that works.
May 14, 2010 | IOGear MiniView GCS62 2-port KVM Switch
IOgear KVM not working with laptop
First, you have to make sure that the KVM switch is directly connected to your laptop, and NOT to a docking station.
This KVM switch is designed to work with direct connections to the computers.
Second, the light indicator on the KVM switch is not an indicator for power. It's an indicator to see which port is active. If your laptop is connected to port 2, but the focus of the KVM is in port 1, then the port 1 will have a light, not the port 2.
You may also refer to the user manual of the KVM.
Thank you!
May 13, 2010 | IOGear GCS634U KVM Switch
GCS62 - both computers must be on for this thing to work?
It seems that you KVM switch is not working properly. computers connected to a KVM switch are not dependent to each other. you should be able to work on any of your computers while the others were turned off.
Jun 06, 2009 | IOGear MiniView GCS62 2-port KVM Switch
Switch starts switching back and forth between computers itself
There are no firmware updates for the GCS62 also the KVM appears to not have a firmware upgrade port. If the KVM is auto-switching have you tried hitting the ESC key or Space Bar? That should stop the auto switching.
Feb 12, 2009 | IOGear MiniView GCS62 2-port KVM Switch
KVM unresponsive
Greg,
Try swapping the KVM cables from the 2008 computer into the Vista computer and see if the problem follows the 2008 computer. This KVM gets the drivers it needs from the OS and the IOGear web site does not show any support for 2008.
Jan 16, 2009 | IOGear GCS632U 2-port KVM Switch
Dec 09, 2008 | IOGear GCS632U 2-port KVM Switch
Open Questions:
IOGear GCS72U - KVM / audio switch - ports (S7584636) KVM Switch Logo
53 people viewed this question
Top IOGear Computers & Internet Experts
John Anderson
John Anderson
Greg Cann
Greg Cann
Dave Harris
Dave Harris
Are you an IOGear Computer and Internet Expert? Answer questions, earn points and help others
