Question about Goodman Heating & Cooling
Damper control which way are dampers supposed to be positioned for air to flow downward? i recently bought a brand new house and it seems the heat isn't working in the basement but the upstairs is really hot
    Novelist:
  • 189 Answers
Dampers in the basement should be opened.
Posted on Nov 28, 2014
t1m130
  • 86 Answers
SOURCE: message: "in recovery"
the "in recovery mode" is refering to a thing called energy recovery management its one of the features on your tstat what it does- when you are using the program on your tstat the "in recovery" starts your unit early so if the tstat is set to be 70 degrees at 8 in the morning when 8 o clock hits it will already be 70 degrees in your house you can turn this feature off if you want in the installation setup codes
Posted on Jun 28, 2009
  • 288 Answers
SOURCE: i have a regency wood stove, and when i push the
the damper may have to be operated manually back and forth to free up any obstructions between the rod and the flu pipe
Posted on Nov 26, 2009
danowilliams
  • 105 Answers
SOURCE: Heater works, but only on Emergency Mode
It sounds like you have a "setback thermostat" A control intended to increase efficiency by allowing the fan to run for an adjustable amount of time after the heater turns off, whether the heater is electric or part of a heat pump. If the "setback" time is too long, the element will cool off and the fan will blow cold air. Try and locate the instructions for the thermostat and see if the "fan run time after heat turn off" is adjustable and reduce it by half. Most emergency heat circuits bypass control circuits (its an emergency, you know), and require manual control.
Posted on Jan 11, 2010
  • 4736 Answers
SOURCE: Gas Furnace Model GMH 95070,
Seems to me, the problem is not with gas, it's with the size of the duct work. 4" diameter is way to small if the entire duct work system is only 4". The trunk line may have not been sized proper,y. so the volume of heat has now been translated into high pressure, which is why the registers are noisy.
Also 6" ducts coming off a larger trunk line to each register is the norm for 1000 sq ft home.
Also, are your registers in the floor or the ceiling? Ceiling registers historically are a little noisier than floor registers. Mainly because, they're overhead and closer to your ears. But, if they were up-sized to 6", the noise would decrease quite a bit.
Hope this helps.
Posted on Feb 10, 2011
SOURCE: Have a Honeywell M847D1004 Actuator for my zone
No, more than likely it is the plastic wheel and I have found no available replacement parts for that. Honeywell did an amazing job with providing a quality product that will fail after 3 years
Posted on Jul 27, 2011
Why the air sometimes does not blow in a 2000 Isuzu Rodeo
Since it is intermittent. Check plugs to the controller and blower.
Dec 03, 2016 | 2000 Isuzu Rodeo
Heater core hot but not in cabin
the damper at the core must be open,
so the rules are" (heat exchangers) 101
1: hot engine, yes.
2: hot core, yes. (water must flow and both tubes hot to core)
3: air flow through core, not. (fix cause, if blower is running on high
then the damper is closed.
do you need a drawing? the FSM covers that , all cars, factory service manual even shows every step, in diagnosis.
1990 is a toyota corolla. so books on that car , match too.. hint?
they make 2 kinds if 1990
one with cable damper (temp)
and with water valve. got valve>y/n, no then its damper
this is a cable car, so the cable must move the valve or the damper
open fully to get hot air
valve below. (1990 corolla book)
using 2 persons, make sure the valve works
and is not clogged inside. it.
Feb 18, 2015 | 1990 Geo Prizm
Can i hook up a thermostat to my hot blast wood/coal stove to control the heat in my home
Yes, you most certainly can. It depends on how handy you are and to what extent you are willing to go to make this happen. A lot will depend on how comfortable you are with electrical wiring and understanding HVAC controls and their function.
First though, this is the typical way a wood fired forced air furnace is designed to operate. There is a control transformer and relay to control either a combustion air fan (that you do not have) OR a motorized damper for combustion air that you also do not have. The relay closes on a call for heat from the thermostat and opens the damper from its minimum position to allow combustion air into the firebox. As long as there is solid fuels (wood) in the heat chamber, the fresh supply of combustion air will allow the fire to burn or begin to burn very quickly.
As the temperature in the wood furnace plenum increases, the automatic fan control will start the fan and it will run as long as the bonnet temperature is higher than the fan'on' setpoint on the fan control... Now the house warms up and the thermostat satisfies which allows the combustion air damper to spring back to the minimum position, causing the hot fire to die down due to lack of combustion air.
The now smoldering fire will not generate enough heat to keep the fan running too long, so the automatic fan control shuts the fan off until the house cools approximately 2 degrees below thermostat setpoint. The thermostat calls for heat and opens the damper and on goes the cycle....
An important item to remember is that on the automatic fan control, there is a 'limit switch' function. The motorized combustion air damper or the combustion air fan must be wired through the limit switch in case the bonnet temperature exceeds 200 degrees F. This function will then allow the damper to go to the minimum position or the combustion air fan to go off, causing the fire to cool down due to lack of adequate combustion air.
You don't want the thermostat controlling the circulating fan directly, because of two things: 1). If the fire is out, there is no heat to circulate but the thermostat wouldn't know that and it would start and run the fan continuously until a fire is built. and ....
2). You would still be running up and down the stairs monitoring the fires burn rate by opening and closing the lower door manually.
ALL the components you need are readily available from WW Grainger....basically : a fan/limit control
a thermostat
a 110v x 24v 40 va control transformer
a 24v spdt relay
20 ga. two conductor thermostat wire
24v actuator and linkages to mount to the existing combustion air damper. A bit of creativity is required here. I would not recommend retro-fitting a combustion air fan.
14-2 wg romex for wiring the fan control
Again, it depends to what extent you are willing to go to achieve the end result. Will it be exactly like a new system?? No, but it will operate a lot better than that which you describe.
Oct 24, 2014 | Home
2011 jeep liberty heater blows cold air
gas not diesel right?
what engine? option? size?
there are only 3 causes (and many parts to fail)
  1. engine coolant not hot at 180F or more.
  2. said coolant not flowing Through heater core (feel the 2 hoses?)
  3. air not flowing over heater coil. , damper stuck closed?
once the above is found.we can diagnose why?
the FSM covers all this , in the HVAC chapter.
say engine is hot, and core is hot.
you check the damper and its stuck closed.
1: controls not telling damper to move. (falling)
2: damper motor bad. (called the HVAC acuator by jeep)
on this new of car, we must scan it, the scan tool that supports
jeeps will set HVAC errors aplenty.
my innova 3160 can do that.
my FSM dont do that new a car.
or
engine not hot
heater core not hot
or damper door stuck closed on core, blocking heat.
Mar 21, 2014 | 2011 Jeep Liberty
Which direction should dampers be in order for the air to flow down? I bought a new house and all the hot air seems to be upstairs while it's freezing in the basement.
If you look at the end of most dampers, there is a line on the end of the shaft. this line when it is in line with the duct it is open, and when it is 90 degrees to duct it is closed. for most damper and motor, when it rotates clockwise it goes to open. and counterclockwise it shuts. default position on zone systems is open, most damper motor spring return to open. There is a allen set screw that anchors the motor to the shaft. to set up the motor and shaft, turn power off, unset set screw and rotate damper ccw and reanchor the set screw, repeat for all damper and associated motors.
Feb 13, 2014 | Goodman Manufacturing Hvac Direct R410A...
I have a kenmore side by side. FF side too cold. Replaced t-stat and defrost timer. All settings and air flow set right. FF still too cold. T-stat set all the way down . Should be at 3 or 4
You need to provide a model number in order to look over the parts list and see what type of auto damper your model has. There are ways to test an auto damper to see if it opens and close properly. An auto damper can be electrical or mechanical. Kenmore model numbers look like this example=> 321.2345789 and can be found artound the fresh food compartment door frame.
1 Turn power off to refrigerator.
2 Open the fresh food sections door and remove all items on top shelf.
3 Adjust the fresh food control to its coldest position.
4 Remove the light shield by pulling down on the back corners of the cover and then slide the cover forward.
5 Remove the edge sealing device, radiant shield supporting screws at the back bottom center of the control housing mounting screw at back, bottom center of the control housing. Slide the control housing to the right and lower the housing.
6 Disconnect the temperature control housing from electric quick disconnect.
7 Remove the temperature control housing from the refrigerator and then place on a
flat work surface.
8 Remove the auto damper control rod retainer, control rod and the slide control
gear from the auto damper control.
9 Now turn the control housing over.
10 Remove the two auto damper mounting screws, then remove the auto damper from the control housing.
11 Mark the auto damper rod about 1/4 in. from and away from the housing.
12 Uncoil the auto damper capillary tube at about 4 in.'s
13 Submerge into a glass of ice (not water). then watch for door to move to the closed
position.
14 Remove from ice and warm capillary tube with your hand. Then watch door for an opposite reaction.
15 If no movement is detected, replace the control. 61005971 Damper Control Assembly
The above is only a demostration of how to test a refrigerator with an auto that uses a capillary tube to open and close the damper. Your refrigerator will need to be identified by the correct model number to let you know what type of auto damper your model has, Post your model number and I will tell you what you will need to test yours, Thanks Sea Breeze
Apr 12, 2013 | Refrigerators
GE Gold Over The Cooktop Microwave condensation - help!
It sounds like insufficient air flow. The damper must be one that doesn't require too much air flow to open it.
Was the damper he used to replace it the same as supplied by GE in the install kit? Otherwise, if the new damper has too strong a spring in the door, it will restrict air flow.
For more free DIY and other help & advice, feel free to contact me.
William E. Miller, AS-EET
pupista@gmail.com
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Mar 15, 2017 | Microwave Ovens
The freezer is running and cold, the refrigerator seems to be getting warmer like as if the cold isn't transferring. Is there a fan suppose to be running or what?
It is quite common for a refrigerator to begin the first signs of a defrost problems once he fresh Food section begins to warm. Auto Dampers are an additional component to check while searching for the true reason for Fresh Food compartment warming. First look inside the freezer compartment and and see if there is a layer of frost building on the rear wall. If yes you will need to manually defrost unless you have anothr place to store the freezer goods. Unplug refrigerator and then remove the rear panel of freezer to get a good look at the snow covering your evaporator coils. Defrost with a hair drier. Now we need to look for the cause Auto Damper, Click here for the photo location of these parts=> MSD2756GEW Controls Section the adaptive defrost control is most likely the problem and is listed in the photo as location 13 and the auto damper
61005988 Adaptive Defrost Assembly
The Auto Damper model refrigerator has two controls and both have capillary sensing.
The Auto Damper controls the fresh food temperature and the Freezer Temperature
Control guides the freezer temperature. The fresh food compartment temperature is maintained by a damper assembly located at the back of the temperature control housing. Changes in air temperature cause the damper door to open and close. A control rod and gear connect the fresh
food control knob to the damper control.
Turning the fresh food control knob to the coldest position increases the flow of freezer air into the fresh food section. The freezer compartment temperature control warms at a faster rate and cools at a slower rate, increasing the compressor run time necessary to maintain a satisfied freezer temperature control.
Click Here=> Here is how to test a Maytag MSD2756GEW Auto Damper
There is always other possiilities but I see two other things that may cause this and that is the defrost heater with defrost Thermostat=> 61006199 Defrost Heater Assembly
I know this was long and possibly confusing but please ask if you should have questions or one on one assistance, Thanks, Sea Breeze
Sep 14, 2011 | Maytag MSD2756G Side by Side Refrigerator
I have a deluxe wired heat pump and am enquiring what the 2 zones" are
Debi - "2 zones" usually indicate, 2 separate areas of the house(upstairs & downstairs). But, this usually requires two separate heat pumps for each area. That is unless, you have an electronically controlled damper system in your home's duct work. If that's the case, when one area calls for heat or AC, the damper closes to the other area and vice versa. If both areas call for heat or AC, the damper stays in the neutral position.
Hope this helped you. Please let me know. Thanks.
Jun 20, 2011 | LG Heating & Cooling
Temperature does not go below 59 deg. refrigerator side.
Auto Damper models, The Auto Damper model refrigerator has
COLDEST position increases the flow of
Turning the fresh food control knob to a
WARMER setting decreases the flow of
chilled air into the fresh food section. The
warms at a slower rate and cools at a faster
rate, decreasing the compressor run time
It is ver possible that the auto damper has failed and will need to be cosidered as a likely cause. Part Number Click here=> 61005971 or 1005641 Auto damper control assembly here is the Service manual=> MSD2756G Instructions can be foun on pages 38 and 39 in your manual.If need you may contact me here on Fixya or my Forum=> Appliance 911 My contact information is located above the Fixya Ad on my blog here=> Sea Breeze Appliance Parts and Technical Services, www.pcappliancerepair.com
Feb 28, 2010 | Maytag MSD2756G Side by Side Refrigerator
Heating & Cooling Logo
55 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
