Question about Optics
Trigger assembly for a Mendoza rm377
My Mendoza rm377 pellet rifle won't ****.also idk how the spring goes back in the trigger assembly
5 Suggested Answers
miket756
  • 2702 Answers
SOURCE: beeman air rifle wont latch when cocking
you have a triger fault its not locking the piston back best and safest bet is a gun smith,, never play with a triger if your not good with guns,
Posted on Jan 15, 2010
Adrian762
  • 425 Answers
SOURCE: i took apart my crosman .177 pellet rifle, and
See the answer:
http://www.fixya.com/support/t4047835-put_trigger_back_together
Posted on Feb 08, 2010
agent91
  • 2100 Answers
SOURCE: winchester model 88. with the trigger assembly
Less Than Perfect
The Model 88 had its faults. The trigger moves with the lever and the resulting linkage to the sear results in a rather spongy, creepy trigger break. If you want to see your gunsmith turn pale, waltz into the shop with an M88 and ask for a crisp three-pound trigger.
If you already have taken the gun apart, don't be afraid to hone the parts on a stone , keep them flat, you don't want anything rounded off. Especially the sear. I found that quote up top from a winchester sight,
Posted on Feb 22, 2010
  • 19 Answers
SOURCE: need diagram of trigger assembly for CVA OPTIMA MUZZLELOADER RIFLE
go to www.ehow.com it has the assembly for everything i use it all the time. if that doesnt help let me know.
Posted on Apr 03, 2012
Want to buy daisy air gun
Buy an Eagle OWL statue
Daisy Outdoor Products
www.daisy.com/ Manufacturer of airguns, ammunition and accessories.
Daisy Airguns - Daisy BB guns, Pellet Guns and Air Rifles from ...
www.pyramydair.com/m/Daisy/20 Daisy air rifles and Daisy BB guns are household names. Daisy started making airguns and BB guns as early as 1886. Daisy BB guns and air rifles have been ... ‎Daisy BB guns & pellet guns · ‎(steel and lead). · ‎Airgun pellets · ‎PCP & CO2 accs.
Daisy Air Rifles ' Airgun Depot
www.airgundepot.com/daisy-air-rifles.html Daisy air rifles are the face of what everyone believes an air rifle should be as a result of the fame created by the Daisy Red Ryder. Daisy is the oldest air r.
Daisy Air Rifles from D&L Airgun
https://www.dlairgun.com/Air-Rifles/Daisy/ Daisy Avanti Champion 499 - (DSY-AR-001). Daisy Avanti Champion 499. $189.99. Underlever spring piston .177 Caliber BB @ 240 FPS. More Information.
Daisy Model 25 Pump BB Air Rifle ' Cabela's Canada
www.cabelas.ca/product/23625/daisy-model-25-pump-bb-air-rifle Daisy Model 25 Pump BB Air Rifle. Created by legendary Daisy designer, Charles Lefever, in 1914. The modern Model 25 will take adults back to the excitement ...
Replica Fake Plastic Owl Decoys
Dec 20, 2016 | Cell Phones
How to fix air pump
The crossman phantom is a spring powered air rifle which means that you pull the barrel down through the arc of its travel until the piston locks up to the trigger mechanism in one continuous movement
Feb 08, 2016 | Crosman Optics
Crossman repair
I have a crossman pulse r78 and it will not shoot ,when you pull trigger it Gus windes oner spring do not egage
Dec 05, 2013 | Crosman Model 760 Pumpmaster Air Rifle
I have a 'used' Beeman Sportsman 1000 Series rifle (no scope). Have a pellet in the rifle (it's been in there for about a year, heh), I'm moving the lever-near-trigger back and forth but rifle won't shoot...
If your pumping the rifle and you hear air seeping out then the seal on your air chamber is bad or got pushed from where it is suppose to be, you can take it apart and see, its real simple...
Aug 03, 2013 | Beeman SS1000T Sportsmans Series .177...
This is the izh 513m .177 rifle. It's brand new. I am not sure as of what to do and the hammer want budge and the trigger won't pull. The barrel has no tension and it won't go up like its supposed to.
This could be a factory safety that the hammer and trigger do not move while in the cocked position. The barrel may be locking down purposely. Look near the spring or in the path of the barrel where it folds back up and look for a release button. What do you see?
Jan 26, 2013 | Sport & Outdoor - Others
How to sight in crosman extreme g1 pellet rifle scope
You would sight in an air rifle scope in the same manner as any other standard scope that you might find on a rifle:
You want to secure the rifle as best you can with the sights pointed towards a target, which should be set at the desired distance.
Reduce the error of your sight adjustments either by mounting the rifle in a gun mount or simply resting the stock (not the barrel!) on a solid surface such as a table.
Make sure that the weight of the rifle is carefully supported and the **** is firmly pressed into your shoulder. Looking through the sights, aim at the very center of the target (which for your purposes can be as simple as a piece of paper with a dot drawn in the middle).
Take time to ensure a careful shot, and be sure to avoid any shaking, utilizing the support of the mount/table (try resting the fore-grip of the stock on a roll of paper towels if you're having trouble keeping the rifle steady).
Once you are confident with the placement of the cross-hairs over the center of the target, gently squeeze (don't pull) the trigger.
Determine where the pellet struck the target, and adjust the scope accordingly; while every scope is a little different, the same basic principles for adjustment apply. Unscrew the caps on the top and side of the scope, and carefully read the markings on the adjustment dials.
If the pellet struck low, twist the dial on the top of the scope 'up' (the markings should specify clockwise/counter), and if the pellet struck high, twist in the opposite direction. If the pellet struck to the left or right, follow the same procedure for the dial on the side of the scope.
If the pellet struck low and to the side, make the vertical (up/down) adjustments first, repeat the shot, and only move on to make adjustments left/right once the pellet strikes in vertical alignment with the center of the target.
Take your time, and adjust in increments of only 2-3 clicks to start. Repeat the procedure until the pellets are striking consistently in the center of the target (if you're having a hard time remembering which shot went where, replace the target and continue.
Once you are satisfied with placement of your shot groupings on the targets, replace the dial covers on the scope.
Tips and Notes:
- In order to maintain the accuracy of your rifle, try to avoid resting the rifle on its scope and try to prevent the barrel from contact.
- Take note of your rifle's range, and be aware that the further away you place the target, the less consistent your results will be.
- Be realistic; don't attempt to sight in an air rifle at 50 yards. Remember that even with a rifle that has been professionally sighted, good results still come down to the accuracy of the shooter.
-Sight in your rifle at a range where you are confident in your own abilities; start with a closer target and only move back (i.e. sight in at a greater distance) if necessary.
Further Instruction:
http://www.chuckhawks.com/sight-in_rifle.htm
http://www.youtube.com/watch?v=lLirsAFpsfE
May 05, 2011 | Sport & Outdoor - Others
Crosman 766 was shooting fine, the next shot did not shoot the pellet and just made a funny sound. Now when you pull the bolt back and forth there is no sound to indicate a shot fired when the trigger is...
Upon cocking your gun is there the same tension with the cocking spring as there was befor? Also check the condition of your barrel seal for tears or cracks in it.
Nov 23, 2010 | Crosman Optics
Optics Logo
18 people viewed this question
Top Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you an Optic Expert? Answer questions, earn points and help others
