Question about Thermador SMW272 Electric Double Oven
F7F1 error code
Beeping F7-F1
    Champion:
  • Thermador Expert
  • 323 Answers
Replace the ERC. may also require a new touch pad, but testing is required.
Posted on Feb 03, 2015
4 Suggested Answers
thaurfen
  • 623 Answers
SOURCE: F7 trouble code
One of the most common problems with GE electric built in ovens is the error code “F7′ shown on the display. I’ve seen it many times before and today I had a service call for the same problem again. The error code “F7” will be displayed along with a beeping sound if the ERC (Electronic Range Control) or “clock” senses one or more buttons on the control panel stuck. It could be displayed in any mode: “cook”, “clean” or even more often in the “time of the day” mode. In order to fix it, the control panel has to be replaced. This is a very simple job and you will need just a 1/4′ nut driver and a Phillips screwdriver.
To get the right replacement part just click on the link AppliancePartsPros then type the model number of your oven (it is located at the bottom left corner on the door frame of the lower oven) in the search box, click on the “search” button and in the new window type the word ”control panel” in the “search by keyword” box and click the “search” button.
Always turn off the circuit breaker first.
Open the oven door (if you have a double oven, it should be the upper one) and remove three screws (on some models just two on corners) from the bottom of the control panel. If the control panel on your oven is made of stainless steel, then you have to pull the oven out of the cabinet for about 2′ to 3′ to get better access. Pull the control panel forward and up to remove the tabs on the top of the frame, out of the holes in the end caps. Pull the control panel out and turn it about 90° toward yourself (the face of the control panel down). Unplug the control panel ribbon from the ERC. Remove four screws holding the ERC to the control panel. On some models you also have to remove the screw which attaches the ground wire to the control panel. Let the ERC hang on its wires, remove the old control panel and replace it with the new one. On some models before you do it, you have to remove the end caps and the bottom shield from the old control panel and install them on the new one. Do not forget to plug the new control panel ribbon into the ERS slot. Attach the new control panel to the oven and turn the circuit breaker on. Set the time of the day and you are back in business
Posted on Nov 10, 2008
  • 327 Answers
SOURCE: we had a power outage and when the electricity was
Hello, the F1 error code means internal logic failure (monitoring function) it sounds alarm and inhibit cook mode You can fix it by replacing the electronic range control (ERC)
F7 error code means the function key shorted for over 16 seconds, check for something pressing a key or preventing normal release of the key. You can fix it by replacing the electronic range control (ERC) if other component check normal.
Thanks
Posted on Jul 14, 2010
  • 417 Answers
SOURCE: my oven is beeping and the F1 code and F7 code are
Hi
F1 indicates a fault on the electronic oven controller (the clock) & F7 means a function key is stuck.
Check all the keys on the keypad if the fault remains you probably need a new clock.
Posted on Dec 19, 2010
GE Oven Model # JRS04B0W3BB is showing an F7 code, how do I fix it? I can stop the beeping noise by pushing the stop button, but the beeping returns after about 30 minutes. I have pulled the breaker for...
Hi
F1 Error indicates a bad control board and the control board (electronic control) should be replaced to solve this issue. Hope this helps...please post back for further assistance.
Daniel
Aug 06, 2011 | GE 24" Built-In Single Electric Wall Oven
My oven is beeping and the F1 code and F7 code are appearing on the screen
Hi
Dec 19, 2010 | Thermador SC302T Electric Double Oven
We had a power outage and when the electricity was restored the oven is displaying an F1 and F7 code and is beeping the alarm, how do i stop this?
Thanks
Jul 14, 2010 | Thermador CM302U Electric Double Oven
I have a Jenn Air Oven micro combo wall unit.The oven shows an error code F1/F7 with continuous beeping. I have to turn power off to get rid of it. But then I cannot use the mocrowave-any solutions?
Hello- The code described F1/ F7 indicates a 'stuck' key on the control panel. The problem is fairly common, and is not caused by computer. The panel is actually more expensive than the computer. On site diagnosis is needed to confirm. The switch is on a circuit board behind the panel and is not serviceable. Find a good service tech in your area to check it out. Wish I had good news, but I installed several of these under 1 year warranty period.  So- let me know if this info helps- have more if needed.   Thanks- Ed
Mar 17, 2010 | Jenn-Air JJW8530C Expressions Collection...
GE Electric Range Model #JBP95A F1 and F7 Error Code
F1 is a common error code indicating a failure of the oven control board (aka ERC or EOC). Often these control boards have been discontinued, "no longer available" or are very expensive. We may be able to help and save you money.
We refurbish oven control boards at www.fixyourboard.com.
Mar 29, 2009 | GE JTP27 Electric Double Oven
Error code F7 keeps coming up, what does this mean?
F1 error and beeping. Don't bother getting GE out there. Cost me $90 to learn they don't make the clock. WOuld have been $500+ for the control panel anyway. Better off just buying a new one. Planned obsolescence I guess. I won't buy GE again.
Mar 16, 2009 | GE JKP27 Electric Double Oven
F1 error message on kenmore gas range
The F1 usually means a problem with the touchpanel. It is also related to the F7 problem. I have developed a fix which may solve you problem. Please go to the following link for my fix.
http://www.fixya.com/howto/h155060-dreaded_f7_error
I have shared my fix with over two thousand unhappy GE customers. Most report success. Please let me know if this works for you too. I am making a statistical study of this problem.
Regards,
Powerman
hutchipop@yahoo.com
Dec 05, 2008 | Kenmore Ovens
Thermador SMW272 Electric Double Oven Logo
67 people viewed this question
Top Thermador Ovens Experts
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Thermador Oven Expert? Answer questions, earn points and help others
