Question about Estate Washing Machines
Still dripn wet some not spinin fast to get water out
  • Estate Master
  • 5,323 Answers
No spin, or lite spin try these: bare in mind that many times there is no spin it can be due to a clogged water pump so check it for debris and or broken propeller.
Other items to check Using a multi meter check for continuity the door switch, which when bad may not allow agitation or spin. Bare in mind the lid switch assembly can fail either mechanically or electrically.
Check the clutch, brake assembly and transmission, one way to check for slipping is to get under the machine after a spin cycle ( this is if u get a lil spin but not much leaving clothes still wet) mix in a spray bottle a lil water and some dish detergent, then spray it on the clutch assembly ( the metal round pc. Connected to the tranny) if it sizzles and steams up then u know its bad and slipping. Another way to check clutch if u get no spin at all? Is to take it out and use ur hand to try and turn the inner spring assembly pushing it around the inside? If its very easy, it BAD should be hard to push by hand.
Or try the hand test:
If no hammering sound has ever been heard out of this machine, one of the unofficial tests we professional appliantologists will do in the field is called the Hand Test. WARNING:This test is not sanctioned by Whirlpool Corporation; it involves bypassing safety equipment and then putting your hand on and near rotating machinery which could result in injury, dismemberment, disfigurement, disembowelment, mangling, hideous screaming, and a ****** *****. Proceed at your own risk! Have a nice day.
- put the timer on a spin cycle and open the lid- grab the inner basket with maybe 30% to 40% of your hand strength with your left hand
- turn on the machine and bypass the lid switch by depressing the lid switch with a key until the machine begins to spin
- if the clutch is engaging properly, the basket should immediately begin to spin and slip through your hand
- if it takes very little force to stop the tub from spinning, the clutch needs to be replaced.
Next check the motor coupler which engages the tub and tranny to the motor. ( if its bad u usually get no wash or spin or very little of either)
Next if belt driven check for a loose, worn or broken belt. And on some models there is no clutch but rather what is called a splutch. And a MODE shifter. These can go bad and effect the spin cycle.
On some front load models u may need to check the STATOR assembly.
The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed.
Sometimes a no spin machine can be due to a plugged waterpump hose or obstructed water pump propeller. Check these by eye and hand. And in some models check with a meter for continuity and voltage.
LID SWITCH TEST- next step is toremove the cabinetand jumper the lid switch harness (tan to gray). Put the unit in spin and watch the shiny metal clutch disc that is on top of the transmission where the shaft comes out. If the machine starts and runs in spin, check to see if the disc is spinning. If it is, then the problem isnot in the gearcase- look for trouble in theclutch,
basket driveor the tub drive block
If, on the other hand, the disc is NOT spinning, check for a problem withthe motor drive coupleror one of its retainers. This washer doesn't have a belt. Instead, the motor is directly coupled to the gearcase by a drive coupler; that's why it's called a direct drive washer.
Read more:Diagnosing and Repairing Spin and Agitate Problems in a Whirlpool / Kenmore Direct Drive Washer
By the way my advice is free cuz God is good!
Posted on Apr 25, 2016
  • Anonymous Apr 25, 2016
    Jorge, y u only answr old, try answr new???
Kenmore Series 70 Top Loading Washing Machine Model # 110.20722991 Serial# CL 1134809 Hello, Our washing machine is leaving our clothes soaking wet when finished. What could the problem be?
2 things are possible. Can you tell if the spin cycle is engaging? If the spin cycle is not engaging properly or very fast, then the water will not leave the clothes. less likely is that the machine is not draining the water away properly or fast enough.
Jun 09, 2016 | Kenmore Washing Machines
All cycles work but clothes come out wet, top loader model# AAV7000AWW is there a lint trap that needs cleaning?
Lint traps are in dryers, not washers If clothes still come out wet then perhaps the water pump is not working properly and/or the drum is not spinning fast enough to allow centrifugal force to remove water from clothes.
Feb 07, 2016 | Washing Machines
My Bosch next 300 washer doesn't spin as fast as it did. It leaves the clothes wet and some water in the drum. No error code comes up? How do we fix it?
If the tub still moves but it's just not spinning that fast (and the water is draining out), then that means your motor control board has just started to fail and it will need to be ordered and replaced to fix the issue. If you pull the washer out and remove the back panel, there is a control board mounted to the floor under the tub. This is the motor control board and it will need to be ordered and replaced to fix the issue.
Oct 28, 2012 | Bosch Nexxt 300 Series WFMC2201UC
I still have wet close after spin cycle Why?
check the drain hose for any kinks in it,is it a top load or a front load washer and how old is it?the pump could be blocked with something or the tranny is bad.if it's a top load,set the timer on spin cycle,open the lid,start the spin and with a screw driver push down on the lid switch and see how the machine is spinning,if it's not spinning fast the tranny is bad.if the drain hose is stuck into a drain pipe pull it out and drain the water to see if the water is draining out good or partially draining,something could be in the pump or to much detergent,the washer can't pump out suds as fast as water then the suds turn back into water form again and the clothes are wet.
Apr 02, 2011 | Kenmore Washing Machines
Losing pressure 2-3 min vacuum hose is attached to skimmer
de filters clog very fast i suggest put vac in pool put hose over pool attach a wet vac to get water out of hose remove wet vac and vac saves de and water
Jul 09, 2009 | Hayward 1HP Super Pump II Inground Pool...
Whirlpool will not spin out water
With it spinining fully it may be as simple as a sock or undergarment in the pump, if it is not spining fully the motor coupler is probably in need of replacement
Feb 10, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Clothes still wet after fast spin cycle
Belt loose or motor / motor control board possibly defective
Sep 13, 2017 | Hotpoint Aquarius WF000 Front Load Washer
Amana Distinction leaks
this is a very common probelm with AM washer you have a bad upper sping bearing and at this point you need to cut your loses and send this one to the washer graveyard because this repair in labor intense
Jun 01, 2008 | Amana 3.2 cu. ft. Top-Load Washer
Kenmore 90 Series, clothes wet after spin
First thing you need to check is the speed of the spin cycle. As long as you are not overloading the machine, it should spin the clothes pretty dry. the basket drive may need to be replaced. If it is spinning very fast, then check the drain hose, make sure the water is coming out nice and fast. If not you may have a water pump problem even lint clogged inside it.
Nov 29, 2007 | Kenmore 22422 Top Load Washer
Clothes wet, doesnt spin fast
Check the drain spigot, where the drain hose attaches to the drain trap under the sink/tub.There may be a blockage in the spigot which is causing the water to drain very slowly and therefor not allowing the machine to spin at normal fast speed.
Oct 22, 2007 | GE Energy Star WCVH6260F Front Load Washer
Washing Machines Logo
Top Estate Washing Machines Experts
Dan Webster
Dan Webster
dweatherby
Are you an Estate Washing Machine Expert? Answer questions, earn points and help others
