Hdmi says no signal - Televison & Video
When I switch from one HDMI input to another I get a no signal & spinning LG box. after several minutes it gets a signal
Try a different HDMI cable, then try the other HDMI inputs on the TV, then try to connect another HDMI device to the TV. If all are still bad main board needs replaced
Oct 19, 2014 | LG 55LK530 55 inch 1080p LCD HDTV, with...
Configuring a Sony STRDH510 - 3 HDMI & 1 composite input
Is the composite/analog signal going into the same input as one of the hdmi's? i.e. DVD,BD, etc.? If so, the receiver can only look at one of those signals at a time. To use two different signal types going into the same function, you will have to manually select where you want the receiver to look - either hdmi, analog, optical, etc. The receiver defaults to auto-selecting which signal to look at, and will always look for a hdmi signal if one is available.
Dec 26, 2012 | Sony STRDH510
Optoma hd65- componant signal OK but no hdmi signal found
whats the reason for no display on hdmi to hdmi connection- to the x box display is fine-?
Jun 25, 2012 | Optoma HD65 DLP Projector
No hdmi signal
hi good day
if you can not use your hdmi port first try to use with other hdmi cable just to know if the problem is with in the tv unit at the same time you need to use other source like dvd player. if still can not have signal.their is a problem with the hdmi input board check and re soldered the terminal port of the hdmi then check defective signal diode going the hdmi terminal. hope this will help thanks for consulting through fixya.
Sep 04, 2011 | Televison & Video
I just got a new Optoma HD20 and only after 1day of use it is not showing HDMI signal, although it is showing VGA signal. Why is this?
Hi miracles4all: I solved HDMI signal issue in my Optoma HD20. In my case it was the lack of contact between the HDMI cable plug male ending and the Optoma HD20 HDMI female port. My 35ft cable plug male HDMI ending was not completely "seating" in the Optoma HD20 HDMI female port. I solved the problem by purchasing a HDMI female to female coupler and adding a 3ft HDMI cable that had a slim male ending. This 3ft HDMI extension cable made better contact to the Optoma HDMI port and the projector was immediately able to detect HDMI signal. Hope this helps you... kaufmanekpr
Nov 05, 2010 | Optoma HD20 DLP Projector
I am looking to purchase a new Dell computer. In
HDMI is digital and uncompressed signal while the above mentioned interfaces are analog. A digital source is translated into less precise analog signal in an analog interface. After that signal is sent to the television and then converted back into digital signal to display on screen. Due to this, some distortion of picture quality is caused at each translation. HDMI removes the analog conversion and preserves original signal and delivers richest, sharpest picture. Separate audio signals are required by other video interfaces. Due to large amount of bandwidth available in HDMI, it not only transmits video but audio channels up to eight digital audio channels can also be transmitted through HDMI. The entire process becomes simple because a number of wires are replaced by a single wire. It also delivers much better performance.
The HDMI “Type B” have 29 wires while standard HDMI or “Type A” has 19 wires. Motion picture industry and other professional applications use “Type B” HDMI wires. HDMI enabled components talk to each other via an interface that is why it is also called Intelligent HDMI. All-in-one functionality of remote and other interoperable features are provided by HDMI but not by other technologies.
High-Definition and enhanced video and other standard formats are supported by HDMI. Backward compatibility with DVI (Digital Video Interface) is also supported. DVI/HDMI cable can be used to connect HDMI interface in high-end graphic cards that have DVI port. DVI/HDMI cable has HDMI connector at one end and DVI connector at the other. Another point to note is that degradation of signal can occur if the length of the HDMI cable exceeds 5 meters (15 feet).
At least one HDMI interface was provided in many high-end televisions since 2005. Two HDMI interfaces provides more flexibility and three might be better in cases where one wants to connect a game console. As the TV industry installs HDMI interfaces into more peripheral components, multiple interfaces will become common on TVs.
It is good to have it.
Please rate me if this solution works for you
Thanks......Have a great time.
Jul 15, 2010 | Dell Inspiron 580 Desktop Computer (Intel...
Can i connect a dvid cable from the monitor to my flat screen tv hdmi to watch videos from my computer? Thank you Martin
the Flat Screen TV if has, a HDMI input, also has VGA Input.
You must choose :HDMI or VGA, if HDMI The VGA board must Have HDMI Connector, and you connect a HDMI cable to the TV.
The HDMI is a digital signal input/output, VGA is Analog Signal. You must have Signal Converter if you Use the 2 signals
Oct 31, 2009 | LG Flatron F700P 17" CRT Monitor
Unable to play DTS-HD & True-HD
What do you hear? Do all other modes work ok?
If Audio Select (Page 44 and 98) is set to HDMI you will hear silence if no HDMI signal is present. I think AUTO is the best choice here.
On Page 98 of the manual it says a bunch of things concerning automatic signal detection and input selection.
Initial configuration D) INIT. CONFIG
Use this feature to select the settings of the audio input jack select, active decoders and extended surround when you tum on this unit.
Audio select AUDIO SELECT
Use this feature to designate the default audio input jack select setting (see page 44) for the input sources connected to the DIGITAL INPUT jacks when you tum on the power of this unit.
HDMI set E)HDMI SET
Use this feature to select the component to play back HDMI audio signals.
Support audio S. Audio
Use this feature to select whether to play back HDMI audio signals on this unit or on another HDMI component connected to the HDMI OUT jack on the rear panel of this unit.
CHOICE = RX-V663
FUNCTION
Plays back HDMI audio signals on this unit. The HDMI audio signals input at the HDMI input jacks of this unit are not output to the HDMI component connected to the HDMI OUT jack on the rear panel of this unit.
CHOICE = OTHER
HDMI component connected to the HDMI OUT jack.
NOTES
This unit transmits audio and video signals input at the HDMI input jacks to the HDMI out jack only when this unit is turned on even if "S.AUDIO" is set to "OTHER".
I'd look in these areas for specific guidance.
Apr 22, 2009 | Yamaha RX-V663 Receiver
HDMI ON ILO 32HD
it sounds like there is a problem with either the output on the PS3 or the input on the circuit board of the TV. I would try a reset on the PS3 first. Also make sure that there are no other video or audio cords plugged into the PS3 because this will cause the PS3 not to send the signal via the HDMI.
Mar 14, 2008 | iLO 2600 Television
Problems using HDMI
I've had a problem with the HDMI connector, had it replaced twice while my VPL-HS60 was under warranty. This connector seems very fragile, the first time I was not getting any signal from HDMI, so the repair shop ordered a new connector and replaced it, a couple of days after the it was not working again and found that they had to solder it back on the board. If you're not getting a signal from HDMI anymore that could be your problem.
Nov 29, 2007 | Sony VPL-HS51A / VPL-HS60 Multimedia...
Televison & Video Logo
21 people viewed this question
Top Televison & Video Experts
Electro Med Services...
