Question about Samsung LE32R73BD 32 in. HD-Ready LCD Television
Sony tv has purple tint on 3/4 of screen - Samsung LE32R73BD 32 in. HD-Ready LCD Television
Purple tint on corners of television screen
It needs degaussed. Turn the TV off for 24 hours and unplug it. Plug it back in and turn it on. If the degaussing coil in the TV hasn't worked buy a cheap degaussing wand off of ebay. 10 second fix. You can also ask the local repair shop to do it. Anything over $5 I would just buy the wand. Keep magnetic objects as well as electronics away from the TV. Vacuum cleaners can also cause this if it's on the floor.
Dec 28, 2012 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Projection tv flashes green and purple tints
Find your reciept then call mitsubishi . if you purchased it less than 3 years ago mitsubishi will pay to have the expensive light engine replaced.
Oct 05, 2009 | Mitsubishi WD-73827 73" HDTV DLP TV
Sony KV-36FV27 too dark, pink or green tint, 5 blink error,
Fuzzy,blury picture in CRT tv tube.Tv in long use not repairable.Tv tube is dying,it junk.
Mar 27, 2009 | Sony FD Trinitron WEGA KV-36FV27 36" TV
Purple-tinted transparent line
im thinking the set has a bad engine
Dec 18, 2007 | Samsung HL-R5678W 56" Television
My tv is turning everything purple like it is magnatized or something.
In English: 1-800-222-7669 or 1-888-772-7669
Hours: Mon-Fri 9:00AM-10:00PM / Sat-Sun 10:30AM-7:15PM EST
Call sony at this number and tell them what your tv is doing? If it is like mine they will replace the optical block. It seems that Sony will cover parts and labor if you do it before the end of the year. If the numbers don't work just go to sony's website and check for warranty or support information
Oct 23, 2007 | Sony Grand WEGA KDF-42WE655 42" Rear...
Purple tint on screen
Color splases can show up when the sets are move from one location to another or when they have been dropped while moving it,another reason is when a speaker is placed to close to the tv.The tv has an internal demagnetizer witch gets activated when you turn the tv on,I suggest to unplug the unit for about 15 minutes and then plug the unit and turn it on,If the unit was dropped this problem might not be repairable.I hope the information helps .
Oct 02, 2006 | Symphonic SC519DD 19 in. TV/DVD Combo
Purple tint
Do not put a colour television near a strong magnetic field. I have confirmed from several experts that this has the undesired effect of causing loss of colour
Jan 10, 2006 | Panasonic CT-27SF26 27" TV
Samsung LE32R73BD 32 in. HD-Ready LCD Television Logo
19 people viewed this question
Henry  Thomas
Henry Thomas
