Question about Garden
Diesel fuel is getting in the oil on my John deere 790 any ideas on what would make this happen or how I can fix it ? Thanks
2 Suggested Answers
wilsodfarm
  • 986 Answers
SOURCE: 3020 carburetor ? john deere gas tractor, 3020
those carbs are real simple you will not have any problem
Posted on Jul 29, 2009
My john deere 1070 loads up under a load and will stall. I changed fuel filter which was loaded with "gunk" and it ran ok for a while then is doing it again.
I am not sure what you are calling gunk but if this gunk is black it is engine oil. The tractor and the engine was built by Yanmar. The injection pump is lubricated with oil pressure from the engine. The seals in the pump will leak and engine oil will get in the fuel system and contaminate the diesel fuel and plug the fuel. Seals will have to be replaced in the injection pump to correct the gunk.
Nov 08, 2016 | John Deere Garden
John Deere 790 stalling out
My problem with my John Deere 790 stalling was my safety seat switch. It's a quick fix! What I had to do to fix my 2006 John Deere 790, was:
1. Un-hook the switch wires under the seat that connect to the seat switch.
2. Then, connect all of them with little wire clamps (or you can use a raw wire and connect them all) inside the wire connector, with the 4 connectors in it, to bypass the seat switch. Hot wire all of them together. It somehow resets the switch.
3. Then, with my 790 Deere in neutral, I started it up and held the key in starter position for about 2 seconds. (Instead of letting go right when it fires up) Somehow, in doing this, the seat switch reset and I was able to reconnect the switch and the seat switch works as it should now. My Deere 790 front loader fires right up without stalling now, while in neutral, of course. So, try this first because it's a quick fix. I hope this helps.
Cheers,
Aaron
Nov 15, 2013 | John Deere 420,1020,2010,2020,2510,2520...
What makes my john deere 2030 diesel engine fire
Super high compression ratios in the combustion chambers which ignite a highly COMBUSTIBLE, not overly FLAMMABLE fuel mixture. How they get the mixture to fire at or before top dead center of the compression stroke I have no idea.
Nov 11, 2013 | John Deere Garden
What would cause diesel in oil on a 1070 john deer
If the injector pump is driven from inside the crank case the pump could be the cause of fuel in oil. I saw this problem happen on a Ford
Sep 30, 2013 | John Deere 670 770 870 970 1070 Compact...
We fixed an engine of john deere 3020 diesel model 1966. All things it's ok. We took a watch which pressure the oil engine instead of the short lamp. When the engine is working and is cold, the pressure is...
I have been working on the my John Deere 3020 and can not get it to start. I had the starter rebuilt and have gone through everything I can think of! Any help would be great
Feb 18, 2011 | John Deere 3020 Gas & Diesel Tractor...
I ran my john deere 790 out of fuel.how do i restart
With diesel, sometimes you have to bleed air out before it will run again. Typically you disconnect the fuel line going to the injector pump, manually activate the fuel pump, or turn over until fuel comes out, then release one or more of the injectors, and turn engine over again. Normally that bleeds enough to start and then the rest of the air gets pushed through.
Feb 13, 2011 | John Deere 4020 Gas & Diesel Tractor...
John deere 2140 had gas put in it instead of diesal what going to happen
Don't run it until you've completely drained and flushed and refilled the fuel system, tank, lines, pump...
Don't run it! Diesel fuel is more of an oil whereas gas is more volitile... Avoid starting or running to prevent any damage to your engine!
Jun 11, 2010 | John Deere 4020 Gas & Diesel Tractor...
John Deere 115 lawn tractor - won't start. Replaced fuel filter, fuel pump, spark plug, oil filter (changed oil), but still won't start. Engine cranks, but won't run.
I have a 115 john deere tractor that runs but the engine will not run smooth I've put a new fuel cap on it a new pump and clean out the carb.
Apr 16, 2010 | John Deere Muffler 1010 Diesel Tractors
I have diesel in my oil on my 2030 john deere tractor
it can be one of three problems fuel pump leaking injectoin pump or a injector over fueling
Apr 03, 2010 | John Deere Tractor Side Screen...
Garden Logo
11 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
