Question about Samsung LN40A450 LCD TV
Vertical strpe on the screen
780
Its flashing UC MX-780 and I can;t get it to do anything its frozen and tv can;t be shut off or anything
I'm having the same problem. Screen on remote is flashing URC and MX-780 and I can't get it to stop. The device is frozen. I tried taking out the batteries and putting them back in, but it didn't help.
Oct 19, 2013 | Universal Remote Control Model MX-780
Problem on Dell OptiPlex 780 Desktop
You are going to need to start your computer in safe mode and find the XP drivers that will work for your motherboard manually from the web (Assuming that there are any created for XP for that board)..
That blue screen you keep getting is because you don't have the correct driver loaded for something on the motherboard that it needs to boot correctly and your XP install couldn't find it on the web to install automatically.
Start your PC and press F8 several times until the boot menu comes up. Then select "Safe Mode with Networking".
Now start looking for your drivers here:
http://www.dell.com/support/drivers/us/en/19/Product/optiplex-780
Aug 17, 2012 | Computers & Internet
Dell optiplex 780 i wanted to change from windows 7 to xp blue screen appears how to fix
You are going to need to start your computer in safe mode and find the XP drivers that will work for your motherboard manually from the web (Assuming that there are any created for XP for that board). That blue screen you keep getting is because you don't have the correct driver loaded for something on the motherboard that it needs to boot correctly and your XP install couldn't find it on the web to install automatically.
Aug 17, 2012 | Dell Computers & Internet
Ml-780 screen
Common fault. LCD fails. Very expensive. Usually comes on then fades to black or has stripes down half of display. Try a half clear first. If that doesn't solve it, almost certainly LCD panel failure.----------------------------------------If anyone needs more information, the Towa/ Geller ML-780 manuals are here:http://the-checkout-tech.com/manuals/cashregisters/towa1.php
Jan 13, 2012 | Casio Parts Cash Register PC Desktop
MAG LT765s monitor, model 780; where do i plug in adapter
Sometimes the power adapters on flat screens face the floor. So, if you look under the screen under the stand, you will likely see the plug.
May 22, 2010 | Mag Innovision InnoVision LT765 17" Flat...
Unlocking my 780 garmin
Hello. Carefully lift the frame around the screen using your fingernail. Under that frame is the reset button. Push it and you are good to go. Regards, Joe
Dec 22, 2009 | Garmin nuvi 780 GPS
Garmani nuvi 780 freezes on "updating bluetooth firmware 0%" when turned on
Worked for me but not sure why, I had the same problem of freezing when updating Bluetooth firmware on a Nuvi 770. I chose to reset all user data (press lower tight hand of touch screen while powering on) and next reboot it updated firmware sucesfully. No idea why this worked.
Feb 20, 2009 | Garmin nuvi 780 GPS
I have a Mitsubishi DLP 52525 that has a bluish static
the DM and/or FMT boards are bad. the chassis needs to be rebuilt.
check out www.tv-techs.com
Jan 02, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Samsung LN40A450 LCD TV Logo
18 people viewed this question
Henry  Thomas
Henry Thomas
