Question about GE GTWP2000MWW Washer
Spanner nut becomes loose machine makes loud noise will not work
5 Suggested Answers
  • 1314 Answers
SOURCE: WPSF5170W0WW G.E. Profile Performance Washing Machine
most ge washers you just get ya fingers under the bottom and jerk up hard they have a plastic piece under them that has to be replaced from time to time its no big deal
Posted on Jan 18, 2008
SOURCE: the 13/16 nut that holds the tub down keeps falling off
II suspect it is bad design, imagine that. We are having the same problem. After replacing the nut and using lock tight on threads, it worked two days and loosened again. My next attempt will be to "stake" the nut in place. This involves using a chisel and hammer to lock the nut in place by deforming the nut and shaft with a 90 degree dent. A second alternative will be to drill and install an allen head screw to lock shaft threads to nut.
Posted on Jan 04, 2009
MNTECH
  • 1543 Answers
SOURCE: washing machine
Are you aware of the fact that the hub nut on a GE washer has a left hand thread?
Posted on Jan 08, 2009
  • 555 Answers
SOURCE: Machine making a very loud noise when it spins
Sounds like the bearings are broken and it may need a major repair. You may need to consider to buy a new washer machine.
Posted on Oct 10, 2009
Maytag top-loading washer sometimes loud griding noise mvwc300xwo
The nut that holds the main biggest pulley under machine has worked loose. Depending on how long it's been grinding, pulley and splutch that gears on pulley seat against may need replacing. Use lock tite when putting pulley nut back on.
Sep 08, 2017 | Maytag Washing Machines
How do I clean it?
If it is a top loader, you have to remove the agitator, then get a spanner nut wrench and remove the spanner nut . Pull the inner basket up and out and check the condition of the aluminum drive block for broken off notches in the center where the basket drive tube ears lock in. This is a common problem among top loaders made by Whirlpool for Sears.
Jul 28, 2014 | Kenmore Washing Machines
My TAWS800JQ1 washing machine drum seems like it has shifted and is off balance
The bearings are likely shot. But it's possible the spanner nut that holds the basket in place is loose or damaged. Remove the agitator to check spanner nut. Changing bearings is a big job, but if you are handy with tools and good at keeping your cool you can do it yourself.
Jan 06, 2013 | Whirlpool Estate TAWS750PQ 27-Inch Washer
It's making a very loud banging noise in spin cycle
There can be any number of reasons for the tub slipping / jerking.
First, see the Sears parts site for your washer:
http://beta.searspartsdirect.com/partsdirect/getModel!retrieveModelDetails.pd?modelNumber=11092584100&productCategoryId=0153200&brandId=0582&brandDescription=KENMORE&modelName=WASHER&searchedModel=110.92584110
and you'll see a list of major sub-components with diagrams and parts.
It's possible that the drive block and / or tabs holding the tub to the block are worn / damaged.
Also see the Whirlpool / Kenmore Service Manuals for these washers:
WHIRLPOOL INST AND MAINTENANCE INCLUDING HOW TRANSMISSION WORKS
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
WHIRLPOOL TRANSMISSION DESCRIPTION AND SPRINGS
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/2550f737b3129b0c85256b0600504738/$FILE/787772%20%234.pdf
I'd essentially pull the washer apart to check that everything is in place.
(IT'S NOT AS DIFFICULT AS IT MAY SOUND AND MOST FIXES ON THESE WASHERS AREN'T VERY EXPENSIVE)
See the following for a detailed description of how to do it.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137&osCsid=75a4070beeb01ac4cd6c732ff4f740fc
NOTE:
You don't have to buy a special spanner wrench ($20) to remove the spanner nut. I've used a short 10" pipe wrench (about $9.00 also good for cracking walnuts) hooked over one of the tabs on the spanner nut, tap the handle with a hammer and it should loosen.
Also, don't directly hit the drive block with a hammer. Use a short piece of wood under the drive block and tap up on the wood.
The problem does point to the drive block and/or the nut holding the tub to the block. The block is soft metal and easily damaged if the nut isn't tight. Also check the tabs on the tub to make sure that they fit into the notches in the block.
Jul 24, 2010 | Kenmore Washing Machines
My K45SS started making a VERY loud noise when in use, and the lowest and highest gears don't work. Machine is about 20 yrs old.
This sometimes happens when the two nuts holding the motor in place become loose. To check, open up the back and move the foam around the edge to see the two nuts. Tighten them if they are loose. If the low speed still does not work, the screw adjustment at the bottom of the control plate may need adjustment.
Jan 25, 2010 | KitchenAid K45SS Classic Stand Mixer
Hello! my tub seems to be very loose and makes loud noise when spin cycle turns on....what might that be?
you will need to remove your agitator. There should be a bolt on the top center of the agitator. you will need to remove the top of agitator or the cap to get to this bolt. once you loosen this bolt the hole agitator shold pull straight up.
Now you should see the long shaft in the center. Follow that shaft from the top down to the area where the shaft disappers and ther is a big round nut with 4 notches spaced evenly. This is call the spanner nut and you should use a spanner rench to tighten it with a small sleg or hammer ( a couple of good wacks should do. ) I know you probably do not have this tool, but at least you can verify that this is your problem. your spanner nut may be loose. this nut holds your inner tub down to the block. here is the break down
Jan 08, 2010 | Kenmore 24032\24036 Top Load Washer
Kenmore direct drive knocks when itstops from spin tub very loose
you need to check your mounting stem. its what the inner tub sits on. you have to remove outer tub with spanner wrench. u need to check and make sure the unit is still level before you attempt to tear into machine. you have to remove cabinet and agitator assy. to get to the spanner nut.
Jun 24, 2009 | Washing Machines
Washer machine makes noise each time the tub stops spinning
theirs a brake that slows the tub down .Ive fixed 2 thousand off these washers and its not a normal problem.as a repair man i would remove traine,inspect clutch,brake and spanner nut and drive block area
Dec 31, 2008 | Kenmore 24032\24036 Top Load Washer
Maytag atlantis dryer squeals very loudly when running
you have answered your own question! The belt will have become loose due to age/stretching. You hear cars making the same squealing noise when thgey rev up. Its a real squeal/screech. It may possibly be the drum rubbing on the chassis due to beariing failure, but doubtful.
So on some machines the motor is on adjustable brackets that let you move the motor away from the drum pully by loosening the bolts/nuts and then re-tighten. Don't leaver the motor down and then lock off the nut/bolt as this will make the belt too tight, and cause the belt to fail or the bearing to fail over time Take the back cover off the machine and all will be revealed.
best of luck it's a simple fix if your diagnosis is correct
Nov 13, 2008 | Dryers
Washer won't drain, makes loud noise
This problem, or some variation thereof evidently is very common with these Whirlpool Washers!  I have same problem.  So far, best I have found is at  http://applianceguru.com/forum2/5958.html#
diagnosis by someone who knows.  What William Burk says there makes sense.  However, to get to the drive block there's quite a bit of disassembly required.  I am stopped because I cannot get the spanner nut off.  Hope this gives you some help toward finding a more comprehensive answer
Jul 01, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
GE GTWP2000MWW Washer Logo
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
