Question about Bosch WFK 2401
Replace bearing ***. on bosch washer wfk 2401
  • 1462 Answers
SOURCE: Bosch Washer WFK 2401
leaks could be from anywhere. remove the top and back cover, put on a cycle and try to trace where leak is. sorry if this is not very helpful. water in filter should not smell. this may be due to using liquid detergent which causes a smell like drains if used over a period. put on a boil wash and revert to using powder
Posted on Jun 14, 2007
barkencoa
  • 3463 Answers
SOURCE: Bosch WFK 2401 Washing Machine On/Off Switch Replacement
TRy www.espares.co.uk/bosch
or www.bosch-spareparts.co.uk
If it runs o/k with the switch held in .\then all youneed is a new switch.
Plz rate my advice.
Thanks.
Posted on Jan 03, 2009
barkencoa
  • 3463 Answers
SOURCE: installing carbon brushes on Bosch WFK 2401
Remove rear panel of washer.
Remove drive belt.
Unscrew the 2 bolts that hold motor to tub back.
Remove motor plug
Lever notor back with a screwdriver or similar, keeping a firm hold on motor.and remove motor
At the rear end of motor away from pulley you will see the brushes and the armature.
Remove brushes, and if there is less than 4 or 5mm of carbon left, then replace them.
Lightly clean the armature with emery cloth.
Refit in reverse order. Test.
Plz rate my solution.
Thanks.
Posted on Jan 15, 2009
SOURCE: I have a Bosch washer, model number WFK 2401 that
I just had the same problem last week Aug 1 2009
on our WFK 2401 purchased in 2001
If you hear no motor spinning when it should then it's something
with the motor. If you hear motor spinning, esp spin cycle, but
the drum doesn't spin, then probably broken belt ($30 part).
Since I work on cars (this is very much like an alternator+belt) and wanted to avoid a $100 service call (just to come to house) and
at least try for a quick fix before buying a new washer, I opened the back, confirmed belt looked ok, so tried
replacing the brushes in the motor, and it worked.
For a good description on how to do this see
http://dossy.org/2007/05/lots-of-miles-on-our-bosch-wfk2401uc-washer-motor/
I took some pics, and time permitting will post more details
to this dossy site to help fellow owners.
I purchased the brushes at partstap.com for $50 (incl tax+ship)
Posted on Aug 06, 2009
  • 78 Answers
SOURCE: Bosch WFK 2401 - Washer fails to spin.
Check the carbon brushes on the motor.
Posted on Apr 20, 2010
Bosch WFK 2401 impeller blockage
The pump uses an impeller to move the water into the drain pipe. Take the lower front off and you will see the impeller cover, behind the filter.
Jun 22, 2017 | Bosch WFK 2401
Hi, we have a Bosch washer model WFK 2401, in which we just replaced the door latch assembly and drain pump, and now it seems the electrical panel is going out. Since yesterday, when we push the...
Check with the repair man but I bet he didnt plug the panel back in all the way when he repaired it,maybe wanting another call. check it out
Feb 15, 2011 | Bosch WFK 2401
I have a Bosch washer model WFK 2401 and I need a new pressure switch. The repair company I'm dealing with says that they can't get the part from Bosch any longer. Do you have any suggestions for...
We own a Bosch- probably nearly 20 years old. I manged to get the parts I needed- but we live in France and I buy on-line from the UK!
I would go onto the Bosch site. You will probably find spares suppliers from which to inquire. Also I'm sure you could query the Bosch site directly.
I'm not criticizing your repair company but I will be very surprised if the part was not available from somewhere.
Good luck,
John C
Feb 09, 2011 | Bosch WFK 2401
Our 9 year old WFK 2401 needs >$900 repair (drum bearing bad=needs both inner and outer drum; pump motor squeals.) But dealer says we must replace BOTH washer and WTA 3500 drier (which if fine) because...
yes he is right!!! ask yourself this,,,,after 9 years have you had your money worth out the dryer yet? and the washer???
go on treet yourself,,,buy a new lot,,,you know you wont to?
and what a slap in the face for all your friends,,,"look what i got!"
rasssssp!
Aug 28, 2010 | Bosch WFK 2401
Apr 20, 2010 | Bosch WFK 2401
We have a Bosch WFK 2401 that is approximately 8 years old. I am not sure what cycle it was on when all of a sudden a loud noise started coming from the washer. Sounded like a gear stripping. A loud...
Check to see if inner drum is loose indicating bearing problem..Also check two springs on top of tub evident with lid off they can snap/ good luck
Sep 29, 2009 | Bosch WFK 2401
Installing carbon brushes on Bosch WFK 2401
Remove drive belt.
Remove motor plug
Thanks.
Jan 12, 2009 | Bosch WFK 2401
Plz rate my advice.
Thanks.
Jan 03, 2009 | Bosch WFK 2401
Bosch WFK 2401 Full of Cold Water!
put machine near an outside door let the empty hose lie outside that will drain the water out........then check the pump for a blockage ........
cheers
Jul 24, 2017 | Bosch WFK 2401
Washing Machines Logo
37 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
