Question about Royal VF1000MX Shredder
My shredder says it is in overload and it is empty
My shredder is clean and when I try to shred something it is says it is in overload
  • 35 Answers
SOURCE: My shredder keeps running and won't stop in on/auto mode
UNPLUG THE SHREDDER.
If this model has electronic eyes (optics) to control the auto-start/stop function and you oil the cutters, chances are the optics are contaminated with shredder oil. Take a cotton swab with a little alchohol and clean and dry the optics.
If you removed the top cover, it is a possibility that you disconnected the wires from the PC Board.
Posted on Mar 03, 2009
  • 45 Answers
SOURCE: Royal 15mx only works in reverse after clearing jammed paper
try resetting the shreddar, unplugging it waiting for about 20 seconds and then plugging back in. Check to make sure there is no paper or paper clips stuck in the shreddar, make sure the unit is properly mounted on bin, the overheat light isn't on is it? if none of this helps and you have a warranty on your shreddar now would be a good time ot call them as you might have a hardware problem.
Posted on Apr 16, 2009
  • 1218 Answers
SOURCE: Royal VF 1000, overloads with one sheet of paper
Try pouring some shredder oil into the cutting blades where you insert the paper then run the unit in reverse for a while. Then put some of the shredder oil onto a sheet of paper and try shredding the sheet of paper. Some lubrication on a x-cut shredder does not hurt.
Posted on Sep 05, 2010
  • 1218 Answers
SOURCE: Royal CIA12 crosscut shredder overload light came on.
Unplug immediately and wait 20 mins to see if motor will "cool-down"...when plugged back in hopefully the Overload light will be OFF....unless you have it completely jammed up in which case try running it in reverse if the overload light is OFF.
If the overload light wont go out you may need pcb...contact Royal at 1-800-524-0799 for further parts assistance.
Posted on Oct 05, 2010
  • 1218 Answers
SOURCE: red overload light is on
Try pouring some shredder oil into the throat where you normally insert the paper and run the machine in reverse.Put machine back into ready condition.
Put a piece of paper in the throat just enough so the machine should run but not all the way in so that the cutting mechanism catches the paper...all you want to do is make the machine run forwards but not actually be feeding in any paper.
If it wont even run in the forward direction you may have a pcb prob...give Royal a call at 1-800-524-0799 for parts assistance.
Posted on Oct 06, 2010
How to restore shredding capacity?
Access the mechanism and spend some time picking out all the bits of paper jammed in it.
Aug 22, 2016 | Office Equipment & Supplies
SHREDDER CONTINUALLY SAYS OVERLOAD EVEN THOUGH 2 SHEETS OF PAPER ARE INSERTED
It might need cleaning; mine had the shredded paper jammed in by cutters and some shreds got between the gears. First, try using a "cleaning sheet": a piece of paper lightly sprayed or smeared with vegetable oil or spray cooking oil. If that doesn't do fix it, the shredding mechanism, which has many parts, some of which are sharp as razors, might need to be disassembled and cleaned. Though I did that disassembly and cleaning, I would not recommend it to the casual DIY-er.
Sep 08, 2014 | Royal HG140MX Shredder
Overload light stays on
Most likely the cutters are still stuffed with paper shreds and needs to be dismantled and cleaned
Mar 29, 2014 | Honeywell Seven Sheet Micro Cut Paper...
Sh92100 shredder not power
Shredders will stop when overloaded and they have to be disassembled to get them moving again. There is way more paper inside the cutters than you can see. Remove all screws and carefully dig out all paper shreds. Manually turn gears and it should get get working again. Shredder life isn't long after this happens so you may want to look into a replacement.
Jan 06, 2014 | Staples Office Equipment & Supplies
Model SPL-TXC15A. Why doesn't it operate?
The shredder may have gone into thermal overload as a result of trying to shred something unsuitable, such as a credit card or as a result of prolonged use. Sometimes operation resumes after a "cooling off" period. At others, the thermal overload shutdown is permanent.
Jan 17, 2013 | Office Equipment & Supplies
Jul 21, 2009 | Royal Office Equipment & Supplies
Royal VF12mx shredder
Pour some shredder oil in the throat where you normally insert the paper...put some shredder oil directly onto 1 sheet of paper and try shredding 1 sheet. If it wont even shred 1 sheet I would ask is the shredder running???
Mar 05, 2009 | Royal VF1012mx Shredder
My shredder requires about an hour of cool down every time it shreds a load.
do spry lub down in the cutter shoot like WD40. If not do it. If you do there may be a billed up of paper dust in the machine it is a catch 20,22
Oct 24, 2008 | Royal VF-1200MX Shredder
Shredding paper partially
Your cutters have spread apart this could be caused by overloading machine to many times or something may have cracked internally that held them in place.
Jan 02, 2008 | Shredder Secure Shred Shredder
Royal VF1000MX Shredder Logo
99 people viewed this question
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Michael Vincent Cruz
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
