Question about Retail Supplies
Rp 99 coin sticks
My 99 Lexus es300 makes a popping noise on the front driver side wheel when I apply brakes
most propably a worn out tire rod end and or a worn braking disk.Change to Subaru.
Sep 20, 2015 | Rotora Brake Pads - Ceramic 97 - 99 LEXUS...
Drivers seat remove
Coin in seat track most likely near seat belt buckle. Use a long ear swab type stick with putty on the end without cotton to press against coin and fish it out.
Aug 19, 2014 | 1999 Nissan Frontier
Driver front caliber is sticking on my 2001 gmc sierra 1500
My guess would be maybe air in your brake line could be creating the issue. Bleeding both front brake lines probably wouldn't hurt. Not sure if this will solve the issue but worth a try.
Nov 21, 2013 | Rotora Brake Pads - Ceramic 01 - 01 GMC...
My daughter has put a coin into the wii thru the disc slot an now i cant get it out can u help
That will be very difficult, the Wii requires a special screw driver to get the face plate off. It is called a Tri-Wing screwdriver, you can google for it if you'd like to attempt to fix it yourself.
There are two other ways you could try to rectify this. Unplug all cables from the back of the wii, turn it upside down so that the cd-rom slot is facing the floor, and shimmy it around a bit to see if you can get to the point where you are sure the coin is agains the cd drive. Then you could carefully attempt to stick in some small tweezers and try to grab out the coin. Just don't stick the tweezers in more than an inch or so, that way you avoid doing any damage. If you still can't get the coin out you should probably call Nintendo, they can fix it for you, and probably for free. Their number is: 1-800-255-3700
Jul 07, 2009 | Nintendo Wii Console
2004 Odyssey coin tray
right above the coin holder shine a light up in there you will see a tab stick a screwdriver in there seperate the tabs and the cup holder will come out
Dec 03, 2008 | 2000 Honda Odyssey
Removing cover from steering whell horn to remove a coin
disconnect battery then take out screws lift from and coin will fall out without disconneting any wires
Oct 20, 2008 | 2003 Chevrolet Silverado 2500HD
Coin is stuck inside
where is this machine? apartment complex? YOUR private machine?
Dec 27, 2007 | Maytag MAH2400A Front Load Washer
Retail Supplies Logo
14 people viewed this question
Top Retail Supplies Experts
Electroboy
Electroboy
Patrick Tinashe...
Are you a Retail Supply Expert? Answer questions, earn points and help others
