Question about Uniden DECT 6.0 Cordless Phone ID
I am trying to register a uniden DECT HS950 headset to my Uniden DECT 6.0 9135
I can't seem to be able to register my new headset to the phones
  • Elizabeth Sandford
    Elizabeth Sandford May 11, 2014
    I have the same problem - did you resolve this?
  • 3 Answers
SOURCE: cant register/install a new dect 6.0 uniden 2060 phone
I had a similar problem which I finally fixed. You did not say if any of your phones registered.
First try the following recommended by Uniden Support:
Your phone(s) should be fully charged before putting them on the main base.
Unplug the battery from the phone by removing the battery cover and removing the connector. Then, push the # and * key together and hold while you plug the battery back in (requires some dexterity). Continue to hold the two keys until you hear a confirmation tone. This will force the phone to reregister. Put the phone on the main base (if you are sure it has a fully charged battery) and see if it will reregister it to solve the problem.
That did not work for me. So, I followed the instructions to de-register the handset (even though it hadn't really registered). But, I also pretended like the Base was not available (because using the base in this step also failed).
1) Press and hold the hang up and # keys for at least 5 seconds.
2) Move the cursor to select Base Unavailable and then press Select.
3) Select the base you want to deregister from, press Select and then move the cursor to Yes and select.
This causes the phone to delete any of its base information.
At this point, again insure that your phone shows the battery is fully charged and if it is not, put it on the stand alone charger base (not the main base). With the battery fully charged, place it on the base and try registering again by placing it in the main base.
If neither of these approaches help, contact support at Uniden.com.
However, my problems were cleared when I cleared the handset with the second set of instructions.
Posted on Apr 26, 2009
SOURCE: Will Uniden 2085 DECT phone work in india
Caller ID standards are different in India,so caller id won't display ; need to buy a converter which converts from DTMF to BellFSK standard
Posted on Aug 24, 2009
consultel1
  • 860 Answers
SOURCE: my cordless phone says
With the phone in standby, press MENU/SELECT on the base.
Move the cursor to select the Register Handset menu, and then press MENU/SELECT. Handset Registering will appear.
On the handset, press and hold # until the handset beeps and displays Handset Registering.
When the handset has registered to the base, the LCD will display Registration Complete then show the handset ID number.
If the display shows Registration failed, repeat the process again.
Note: If a handset has ever been registered to a base, reset the handset before you register it to a new base
Posted on Dec 21, 2009
  • 84 Answers
SOURCE: I have a Uniden 6.0 DECT cordless phone. Misplaced the manual.
Since you dont list which specifc model you have, I cannot list the specific manual. But here is a link to Uniden's list of manuals, you should be able to find yours here. http://www.uniden.com/index/manuals_results.cfm?cat+1
Posted on Feb 26, 2010
supernova278
  • 1932 Answers
SOURCE: searching and out of range message keep appearing.
This is because of the following reasons
1.The handset is far away from the base unit.Try to bring the hand set near the base unit and try.
2.The base unit is not plugged in to the power supply.Please check it.
Thanx
Posted on Jul 27, 2010
How do I register a used Uniden Cordless 6.0 phone?
Select the model of your Uniden DECT 6.0 phone from the list beginning at scat/dectphones_mnl">http://www.uniden.com/scat/dectphones_mnl to download a copy of the manual.
Sep 29, 2014 | Uniden DECT 6.0 Cordless Phone ID
How adjust ringer on uniden headset
Pick the model of your Uniden DECT 6.0 phone from the list beginning at http://www.uniden.com/scat/dectphones_mnl to download a copy of the manual.
Jul 07, 2014 | Uniden DECT 6.0 Cordless Telephone...
How to connect an HS 950 headset to Uniden DECT 9135
(I presume you have checked the headset is fully charged and powered on.)
Together with pressing "Find Headset" on the phone, you also have to press and hold "VOLUME +/-" for 5 seconds on the headset.
When the connection is made the headset LED will flash blue every 10 seconds.
I hope this helps.
May 11, 2014 | Uniden DECT 6.0 Cordless Phone ID
User manual for uniden cordless phone
Uniden might have a downloadable manual for your phone.
May 07, 2014 | Uniden DECT1560 DECT 6.0 Expandable...
I have a Uniden DECT 6.0 phone set. I damaged one
On the base, open the menu and select Register Handset. The display should say Handset Registering.
On the handset you want to register, press and hold # until the handset display says Handset Registering (about 2 seconds).
1.
2.
DSL filterTelephone cordTelephone wall jack
45
In about 30 seconds, the handset display should say Registration Complete. Press Talk/fl ash and make sure you get a dial tone.
If...
Try...
you don't hear a dial tone
the display says Registration Failed --
Making sure the handset is fully charged, then start over at step 1.
Sep 07, 2009 | Uniden DECT 6.0 Cordless Telephone...
Redistration to other brand DECT 6.0 base failed.
DECT 6.0 IS JUST A MARKET NAME FOR DIFFERENT BRANDS, THE WATERPROOF DWX207 WILL ONLY WORK WITH UNIDEN PHONES, ONLY BECAUSE YOU WANT THEM TO WORK TOGETHER DOES NOT MEAN THEY WILL WORK TOGETHER...
May 22, 2009 | Uniden DECT 6.0 Cordless Telephone...
How do I get 2 Uniden TRU8885 base to operate as one base?
NO ONLY DECT 6.0 MODELS ARE ABLE TO DO THAT, NOT YOUR MODEL.
Dec 26, 2008 | Uniden TRU8885 Digital Answering Machine
Uniden DECT 6.0 Cordless Phone ID Logo
73 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
