Question about LG DLE2514 Electric Dryer
My LG dryer will not power up
Quite simply the dryer will not power up....i have checked the breaker and do have power to the outlet....is there some sort of reset, fuse, etc ?  I purchased the dryer 23 months ago.
  • 10 more comments
  • christinac Nov 05, 2007
    check filter light is blinking and all the setting lights are blinking, when you push the start button it will not stay running
  • sokkermom Nov 17, 2007
    The door switch seems to be working fine...I don't know what an actuator is...anything else I can try?
  • MARGARETG Jan 29, 2008
    MY LG DLE2515S ELECTRCI DRYER WON'T POWER UP BECASEU THE CHECK FILTER LIGHT FLASHES EVERYTIME IT TURN IT ON. I CLENA THE FILTER AFTER EACH USE AND HAVE CONFIRMED IT IS CLEAN. WHAT ELSE CAN I TRY BEFORE CALLING BESTBUY TO COME AND REPAIR IT???? THANK YOU.
    DRYER ' CHECK FILTER LIGHT IS FLASHING AND WON'T ALLOW DRYER TO OPERATE. FILTER IS CLEAN.PLEASE HELP IF YOU CAN.
  • jillvill May 05, 2008
    Whe I turn on my 2 yr old dryer it has "check filter" light flashing and other lights flicker. When I hit start it runs for about 2 seconds before going off. I noticed the last few times I used it on sensor dry that it would get stuck at 6 minutes and not shut off. Now it no longer works. Help!! (Filter is cleaned after every use) It id LG Tromm DLE2515S
  • MARGARETG May 07, 2008
    Hi Jill, I had same problem with same dryer model in January of 2008 I just kept trying it and pulling out lint trap and putting it back in and after 2 days it started working again. I think somehow the lint trap was not in alignment and would trigger sensor and shut off dryer afer a few seconds. Yes It is extremely irritating and I don't know that it won't happen again. My dryer is now about 30 months old but the problmem started when it was 2 yrs old Bought it at Best Buy.
  • Anonymous May 18, 2008
    my LG electric dryer stuck on cool only
  • SKW914 May 22, 2008
    Have the exact same problem, started a few months ago with it being stuck at 6 min and now the check filter light is blinking, but the lint trap is clean and the dryer won't power up. Will try suggestions below and let you know if it works!
  • Anonymous Jun 21, 2008
    My LG Dryer (DLE2516W) will not power up at all. I checked the breaker - no issue. There is weird electrical smell near the dryer. Is there something in the unit that I can replace?
  • Ron Sep 07, 2008
    DLE8377WM owned for about a year and a half. Power to dryer is on (the light turns on when the door is open) but the power button will not turn on the super fancy lcd display. What a POS this thing is!!!! Even when it worked, it never dryed very reliably (sometimes very damp). The old kenmore it replaced worked better and in the 13 years I had that one it never had a SINGLE problem. I wish I never purchased this LG washer/dryer. $2700. %$#@$#
  • Anonymous Oct 25, 2008
    Same problem here, light works but no dryer. I fixed the problem though by using a dryer brush & vacuum on the lint collector. Lint trap was packed with lint and after I cleaned out, it worked again. Poor design.
  • Anonymous Feb 06, 2009
    i just had the dryer installed and i turned it on once and it will not turn back on...help!!
  • 27 Answers
Check the door switch or the actuator for the door switch. hope this helps.
Posted on Nov 02, 2007
    Champion:
  • 210 Answers
The check filter light comes on when you turn the dryer on and at the end of the cycle. This is normal and is just a reminder. The blinking lights are indicating a problem with the door switch/light switch. Check the connections and replace if necessary.
Sometimes if you have a very short venting run it will not read the sensors correctly so you have to restrict the air flow and it will correct this. Tape part of the outside vent, but only on real short runs.
Inside the door there are two sensors and they can get coated with fabric softener, use a nylon scotch pad and clean them if your sensor dry is not working correctly.
Also clean your lint trap once a year as it can get clogged as well.
Sgt 48
Posted on Jun 07, 2008
I vaccumed out the filter area and unplugged for about 30 minutes. Seems to be working fine now. But haven't done much laundry...
Posted on May 07, 2008
2 Suggested Answers
  • 489 Answers
SOURCE: My LG dryer will not power up
You may have a broken door switch.  That would be the most likely source of your problem since the machine will not work if the computer senses that the door isn't closed.
Posted on Apr 28, 2008
Answer not provided. Please read my question.
is it 110 or 220? if it is a 110 first check your breaker/ fuse panel for tripped breaker or blown fuse if 220 it would be a double breaker. if you find tripped breaker remember some panels require you to turn the breaker fully off then back on to reset. if 110 and no blown breakers, check your laundry room for a GFI (ground fault interrupt) outlet. make sure that it is not tripped either. to reset that just push the reset button on the outlet. best of luck to you
Nov 19, 2015 | Dryers
LER8648LWD
Check voltage at dryer plugin. If no voltage go to breaker panel and reset breaker by making sure you move breaker switch fully to the off position and then you will feel tension as you turn breaker back on.If it kicks back off you will need to turn off main breaker and open dryer outlet and probably clean it out.
Dec 07, 2012 | Whirlpool Dryers
Quit heating. when we flipped main breaker and turned it back on the power is not getting from outlet to dryer. What can we do?
This is the most common locations for thermal fuses and heating element on Whirlpool,Kenmore,Estate dryers. Check these fuses for continuity and replace the one that does not have continuityseth765.jpgseth765_0.jpg
Jan 22, 2011 | Whirlpool LER4634J Electric Dryer
While air fluffing some shirts the dryer quit and will not start. is there a breaker or fuse internal to the unit?
Check the breaker in your home's breaker box. The dryer will be the only thing that is on it. It will be a double breaker and looking might not tell you if it has tripped. If it isn't marked just grab the swich and see if it's "wiggly" on each double breaker. If you find a wiggler, flip it all the way over to "off" then back to "on". If the breakers are all fine, the next place to check is the wall outlet itself. If you have a volt meter, first check the slots in the outlet. If you get nothing, pull the wall plate off of the outlet and check the wires leading to the outlet. If they have power, replace the outlet. To the best of my somewhat experienced knowledge, there is no fuse in dryer and I know there is no breaker in it.
Nov 29, 2009 | Maytag MEDC500V Dryer
I have no power
Check all your breakers/fuses panel if none are tripped or blown we will assume power is @ the outlet, check it w/ a meter if you have one. I have never seen a reset button on one before but there could be a internal fuse inside the unit, to check for that you will have some disassemble work 1st
Oct 25, 2009 | Dryers
Kenmore Elite HE3 Dryer PF on control panel,
HI, there may have been a slight power failure within the home breaker unit or the dryer may have lost power to the control for some sort of reason.
I recommend a thorough inspection of the terminal block on the back side of this unit. make sure the power cord is attached tightly and the wall outlet is secure and holding the power cord correctly. if everything looks great with the terminal block and the power cord is plugged in the outlet correctly, simply unplug this unit for 5 minutes to reset the control. after the 5 minutes are up, plug the unit in once more and the PF alert should reset.
Make sure the breaker box in your home is working properly. (the actual breaker switch for the dryer must be in the on position)
Apr 26, 2009 | Kenmore Elite HE3 Steam 8674 Dryer
Washer won't turn on
Begin by checking to be sure the outlet where you have the washer plugged in has power. you may have blown a fuse or popped a circuit breaker. If no power, either replace the fuse or reset the circuit breaker by turning it all the way off and then all the way on.
Feb 28, 2009 | Washing Machines
Whirlpool Cabrio Electric Dryer - No Power
you have to send the model number off of the dryer,also if the dryer hasn't been taken apart and cleaned out also the vent line it could be clogged with lint and you could have popped the thermal fuse or something like that,you'll need a meter,unplug it take it apart and check the t-stats to see if one of them popped,or if it has a belt switch the belt could have broke but if you want to fix it send the model number and more info like any lights coming on but it won't start?if so then you know power is coming to the dryer but it won't start stuff like that.
Dec 26, 2017 | Dryers
Dryer shut off towels were not yet dry, turned dial to restart dryer acts as if it isn't getting power I closed door and pushed start button. Nothing! Checked breakers and power cord at outlet all checked...
Hello mdonettaYou said,
Dryer shut off towels were not yet dry, turned dial to restart dryer acts as if it isn't getting power I closed door and pushed start button. Nothing! Checked breakers and power cord at outlet all checked okay. Any ideas.
yes, try unplugging the power cord or turning off the breaker for 5 minutes. Either will due. Some times the system needs to be reset!
If this does not work there are internal fuses that can be replaced!
Let me know how it goes!
Huuum
Sep 19, 2008 | Dryers
Mar 15, 2008 | LG DLG5932W Gas Dryer
LG DLE2514 Electric Dryer Logo
8,402 people viewed this question
Top LG Dryers Experts
Mike
Mike
John Tripp
John Tripp
Craig Butler
Craig Butler
Are you a LG Dryer Expert? Answer questions, earn points and help others
