Question about Select Jazzy Used Electric Wheelchair
Is my jazzy wheelchair a 12volt od 24 volt system
What is the electrical system 12 volt or 24 volt, parallel or series wiring?
How do I wire two tandem batteries for an electric scooter
Tandem batteries... is a fairly loose term to be dealing with on batteries... SIMPLY BECAUSE THEY ARE EXPLOSIVE.
TANDEM voltage
(assuming you were trying to achieve 24 volts with 2
12 volt batteries would NORMALLY be called serial...
Where as to increase AMPACITY ... called "parallel."
Rather than risk severe burn, blindness (end of life
experimenting with EXPLOSIVES...
You need to go back to your source for better information ...
or
Provide better information here... Pretty please
Jan 12, 2017 | Electric Health & Beauty
What voltage should come out of a 24 v 3 pin charger? single 12 v pin with two ground pins?
It depends on how it and the wheelchair are wired and how the voltage is derived.
Presumably the 24 volt wheelchair requirement is provided by two 12 volt batteries connected in series and these could be recharged in series by a 24 volt charger and a pair of wires or by a 12 volt charger providing a 12 - 0 - 12 using three wires where one 12 is a positive in relation to the 0 and the other is a negative in relation to the zero making a potential difference of 24 volts.
There could conceivably be circuitry within the wheelchair that requires only 12 volts for recharging and causes the two batteries to be charged separately, though while this method could be desirable and offer some benefits it would be considered unnecessarily expensive and complicated for most commercial purposes.
As usual you really need to know what is supposed to happen or is designed to happen before fault-finding can begin. One of the wires could be a safety ground wire but most likely it is used to provide some sort of feedback to the charger from, perhaps, a thermal switch close to the batteries so charging will cease if too much heat is generated.
Nov 02, 2015 | Pride Jazzy 1113 ATS Indoor Power...
I put two new batteries in my jazzy ultra are they
They need to be wired in series. Jazzy chairs run on 24 - 26 volts.
Sep 02, 2014 | Health & Beauty
There are about 30 models of Jazzy. Which one do you have?
Feb 13, 2014 | Select Jazzy Used Electric Wheelchair
Will not charge when plugged in to electricity
1) Order a new charger. 24 volt 3-amp.
2) Replace the batteries if they are over a year old. Usually two each size U1 gel\AGM or SLA 12volt 34amp-hour.
Nov 01, 2013 | Ctm HS-2800 Power Wheelchair
Batteries run down within 10 minutes after full charge
Either the charger is bad or the batteries are too old. If the batteries are allowed to go dead completely the 24 volt charger will not recover. You'll need to seperate the batteroes and use a 12 volt automotive charger to charge the batteries. Make sure the 12volt charger is able to charge gell cell batteries. Not all will.
Aug 04, 2013 | Pride Jazzy 1113 Power Chair
Is the horn on my jazzy power chair 12 or 24 volt? the horn is so weak that you can barely hear it and i would like to replace it with a roadrunner beep beep horn, but it is 12 volt. and the system on my...
Bob why don't you run a small 2 wire cable from one battery to the armrest where your joystick is located and attach the new horn and a small push button switch to the joystick bracket coming from under the armrest. loosen the knob tightening the joystick bar and pull it out enough for you to attach the horn and button to it. I 'm not sure if that will work because I don't know what the new horn looks like but you can also mount the horn under the shroud near the battery and run the wire to the switch at the joystick. Good luck sounds like an good project
Feb 27, 2011 | Pride Jazzy 1103 Ultra Standard Power...
I want to add 2 more 12v 20ah batteries to my 48w electric scooter and im not sure how to wire it and charge it.Please help
join them in parallel if there all 12 volt you could just charge the 1 battery with 12 volts and that would charge them all but all the other batterys have to be in series you cant do it if u have 2 24 volt batterys they all have to be 12 v
Dec 18, 2010 | Electric Bicycle Motor, Bike,electric...
Are batteries connected in series?
yep they are so that you are providing 24 v dc to power the motors. Your chair should have 2 battery boxes that contain one 22nf battery each and have the connectors that allow them to supply 24 volts to your chair. Hope this helps
Oct 17, 2010 | Electric Jazzy 1115 Power Wheelchair
Is the chair wired in series or parallel 12 or 24
It should be wired in series and therefore 24 Volts.
Apr 05, 2010 | Jet 3 Ultra Power Chair
Select Jazzy Used Electric Wheelchair Logo
94 people viewed this question
Top Select Health & Beauty Experts
wcdoc1953
wcdoc1953
Scooter Doctor
Scooter Doctor
Colin Taylor
Are you a Select Health and Beauty Expert? Answer questions, earn points and help others
