Question about Samsung 1.8 Cu. Ft. Over-the-Range Microwave
Screws on samsung microwave don't fit handle - Samsung 1.8 Cu. Ft. Over-the-Range Microwave
2 Suggested Answers
MicrowaveSvc
  • 9085 Answers
SOURCE: smh7187sgt samsung microwave handel replacement,how to get to the screws
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Sep 25, 2008
How do I replace jvm1490sd broken handle?
Disconnect, open door, remove screws from rear of door, dismantle door. Here's a diagram showing how it fits together.
01 Control Panel Door Grille Case Parts for GE JVM1490SD003
The part you need is #1801 on diagram
Microwave Door Handle
Color: Black. For white order WB15X10070. For bisque order WB15X10071. For the screws order WB01X10305.
by GE
Part Number AP3184331
May 19, 2014 | Microwave Ovens
I need to change the lightbulb on my em-s5002w Sanyo Microwave. What screwdriver size & style do I need for lower star-shaped screws
The star-shaped screws are called TORX and range in size from T-1 [small] to T-50[ quite large]. a set of inexpensive bits that fit a driver handle can be found at a hardware or auto supply.
Jan 24, 2013 | Sanyo EM-S5002W Microwave Oven
My smh8165 microwave stopped working and the display says "SE" and is less then a year old
Unplug microwave. Remove (2) flat head machine screws on the top of the microwave holding in the top front trim. My trim slid left and gently pulling was removed. The control panel has (1) screw holding it in. Remove screw, slide up and gently pulling detach from microwave. There are (5) electrical disconnects which need to be disconnected. Do not force they should come easily. Lay control panel on and old towel. Squirt both the male and female connections(in microwave control panel opening) with electrical cleaner. Carefully clean up excess. Connect the (5) quick disconnects and carfully fit back in the control panel opening. Attach screw. Place top trim in and slide right to lock. Once it is in secure the top two screws. Clean area and plug back in. Hopefully your up and running. These pieces break real easy so don't force anything.
May 26, 2011 | Samsung Microwave Ovens
My samsung SMH7187STG microwave handle broke off.
You can order new "cap handles" (the plastic parts that join the aluminum handle to the door for 3.99 each plus 8.99 shipping and handling at the Sears Parts Direct Website. The part number is DE67-00222C. When you have the parts in hand, open the microwave oven door. On the inside surface of the door their is a black plastic frame around the door that pops off easily (gently use a screw driver to pry up the door frame) so that you can have access to the screws that attach the end caps to the door. You will need to hold the remant of the cap handle (the part that is probably broken off even with the glass surface on the outside side of the door) still while you unscrew the screws. Once the screws and broken remnant of the handle caps are out, you are ready to put new handle caps on the handle, then put the handle with the new handle caps on the door. By the way, Samsung was absolutely NO help with this. The agent I chatted with denied that their were any reports of the handles breaking off, so I had to cut and past the postings about the door handle breaking off ON THEIR OWN WEBSITE under "Community Q and A" into the chat box -- still the agent did not acknowldege the existance of these reports...or the possibility of a poor design. I asked for them to send me a couple of the $4 parts as a good will gesture....got nothing but lofty words about Samsung commitment etc. and only a authorized technition blah blah, no action. All you need is a strong thumbnail, a phillips head screw driver, new handle caps.
May 02, 2010 | Samsung 1.8 Cu. Ft. Over-the-Range...
Loose handle.
To access the door screws on MOST microwave ovens, you need to remove the inner door panel that goes around the perimeter of the glass. The following link explains:
http://www.fixya.com/support/r3696942-microwave_oven_door_handle_replacement
This can be peroformed with the door in place, or with the door removed. If you have any questions, please post back with your complete model number and let me know. I hope this helps you.
Feb 18, 2010 | Kenmore 62622 Microwave Oven
GE 1540 handle...bottom fastener is broken. How
remove w putty knife the inter face. you can see the screws at this point ,. just remove screws and reinstall handle . pop interface back in **** . you can get a brake down of how this fits on sears web sight . **** / hope this helps ( it;'s not a hard job /time 1/2 hr / mm .
Dec 22, 2009 | GE Spacemaker JVM1540 Microwave Oven
Smh7187sgt samsung microwave handel replacement,how to get to the screws
Sep 24, 2008 | Samsung SMH7178STD Microwave Oven
Broken handle on GE Spacemaker XL1800 microwave
New handles for microwaves can be bought on amazon. Take a look here Amazon com microwave handle and choose one (which fits). P.S. watch out on reviews and handle sizes. I hope this was helpful. cheers
Sep 07, 2008 | GE JVM1851BD 1100 Watts Microwave Oven
Door handle broke off
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
You can get Samsung parts here.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 18, 2008 | Samsung 1.8 Cu. Ft. Over-the-Range...
Samsung 1.8 Cu. Ft. Over-the-Range Microwave Logo
12 people viewed this question
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Henry  Thomas
Henry Thomas
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
