Question about Panasonic Audio Players & Recorders
I have the panasonic SC-HT400 receiver which I've connected to a bluray DVD player using an digital coaxial cable mainly because I have no other outputs on the blue ray dvd. As you know the Ht 400 does not have Hdmi connections. My problem is I cant determine what source to use on the receiver. I dont get sound with if I select DVD, TV or any of the other sources, and there any selections for coax. Need advice.
  • Panasonic Master
  • 5,484 Answers
Press the SFC MODE switches at the same time to enter the "settings".
Change these settings to suit the connections you have made to the three digital input terminals, COAX, OPT1 and OPT2, so that the correct source is selected when you turn [INPUT SELECTOR].
The factory settings are: CD: COAX
DVD: OPT 2
TV: OPT 1
If you are allowed change them all to Coaxial. That should solve the sound problem.
Posted on Jun 30, 2017
SOURCE: panasonic SC-pt960 home theater
You must set up the Reciever manue to accept Digiatl Audio in... refer to your manual
Posted on Nov 05, 2008
srinivasb81
  • 51 Answers
SOURCE: right cables for connecting devices
You have connected from PC to TV right???
1.To get the video you have to connect to TV
2.Please take a separate cables for to listen audio and to watch video,
for audio connect cables from DVD Player to Home Theater you can listen the audio
for video please connect the HDMI video to TV Where You can enjoy both.
Posted on Jan 08, 2009
dunnbiker
  • 8546 Answers
SOURCE: I just purchased a new
If you look in the manual of unnamed BD and read up on its output bitstream, you may find the problem.
Posted on Jan 29, 2011
SOURCE: Blu Ray player and dish
Hey my nameis Mike Houston of DISH Network and I see there is a problem with the Sony hometheater system connecting with the DISH receiver. To get the full surroundsound you want there are two different options you can use, the first is to usethe HDMI and connect the RCA cable or you can use the Optical cable for sound.If you have any questions or concerns please e-mail me back; michael.houston@dishnetwork.com.
Posted on May 08, 2011
SOURCE: have lenoxx ht 500 surround sound speakers & dvd but dvd is broken, need to purchase another dvd player but can't source lenoxx model, what other models can i connect surround sound to? or whe
If your surround sound receiver unit has rca audio inputs(red/white), you can hook up any brand of DVD player that has rca outputs. You would hook the yellow output from DVD player to yellow input on TV. Hook red/white output from DVD player to red/white input on surround receiver. Hope this helps.
Posted on Jan 03, 2012
How can i connect the system to a new sony bluray
use your tv as a common connection in your theatre system. Connect your hdmi blue ray player to the tv,connect the audio output of your tv (rca style cables -red&white) or if your tv and audio system has optical you can use that also.
Dec 23, 2009 | Panasonic SC-HT500 System
Denon AVR-786S 7.1 Channels Receiver
First set the DVD player To mono and then see.
Check if the DVD assigned to coaxial input in receiver menu?
Check if the Digital out activated in player menu?
There are quite a few ways to connect cable box, DVD, receiver and TV together. At a minimum---Connections between DVD and a/v receiver: For Audio, either digital coaxial, digital optical or simple RCA (CABLE ONE); If you did not use RCA you need to connect Video with either component or s-video (CABLE TWO). For connection between a/v receiver and TV: either component, s-video or RCA (CABLE THREE) You did not mention how your cable (or sattelite) box is connected. You could use same set-up as between DVD and a/v receiver for another one or two cables depending on set-up used.
Goodluck..
Feb 23, 2008 | Denon AVR-786S Receiver
Tip
DVD PLAYER to TV HOOKUP
Basic DVD player hookup to TV cable diagram. RCA cable (yellow) video and RCA cables (white and red) audio. This is all you need for picture and sound. If your TV only has a single RF input, then you need a RF modulator. RF modulators accept the yellow, white and red cables and output a coaxial cable to the TV single input jack. Usually the TV is tuned to channel 3 or 4 to pickup the RF modulators output.
Alternative connection options are many and include HDMI for HDTVs, component video and for sound, surround sound digital audio connection using optical or coaxial digital audio cable.
Surround sound requires a decoder such as a A/V receiver with Dolby Digital 5.1 or DTS 5.1 or more. 6 speakers connected to the A/V receiver surrounds the listener.
Bluray players will play DVDs and Bluray discs. Bluray gives you High Definition video and typically connects to a HDTV using a HDMI cable.
dvd_howtoconnect.htm
for more information and pictures on DVD player hookups.
on Aug 17, 2010 | Audio Players & Recorders
I was using my vsx D510 with a hiteker dvd player
Each digital input is assigned a name and a function by you. You have to dig out the manual and assign the digital inputs.
My $.02. Why do you not want to use the coaxial imputs? There is no functional superiority of one over the other BUT coaxial is a) cheap, since it uses standard RCA cables; b) adaptable, since you can splice or split them among two devices; c) not delicate or prone to failure due to tight bends. I share one coaxial input between two digital device with an RCA splitter cable. Just have to make sure to turn the one I'm not using OFF. Try that with optical.
Dec 21, 2009 | Pioneer VSX-D510 Receiver
When connecting hdmi out from my panasonic blue-ray player to the dvd input in my yamaha rx-v365 there is not audio or video,why?
There are several video and audio inputs named DVD. For video you have HDMI, component and composite. For audio you have standard analog stereo and digital coaxial spdif input.
You need to configure the receiver to use the correct inputs - that means HDMI and coax. Also you need to connect the BD player via coax spdif cable to the receiver, because rx-v365 doesn't support audio via HDMI. If BD player has only optical output, use DTV/CABL HDMI input and DTv/CABL Optical input on the receiver.
Nov 23, 2009 | Yamaha DVD-S661 HDMI DVD Player
Only one HDMI port on new receiver/dvd player
Chances are good that your panasonic would not support HDMI 1.3b firmware and you would loose audio or video anyway. If your Panasonic has digital inputs, ie. coaxial digital or optical, run audio to your receiver and HDMI direct from Cable box/ DVD/other source to TV. On the TV settings menu, turn the speakers "off". If you need further help, post a comment and I can help you more
Oct 14, 2009 | Audio Players & Recorders
Panasonic SC-HT500
Not really an option to modify cable.Connections inside subwoofer and main unit are difficult to work with.Common problems with dvd are laser/traverse deck failure and dvd tray ailgnment.You can run a seperate Dvd player by using the Tv or Tape audio input in the receiver and run the Video cable direct to TV.
Apr 01, 2008 | Panasonic SC-HT500 System
SA-AX7
its the orange input on the back of the amp left side of it from the fan says coaxial either above the input or below im not 100% if that will work for you i would suggest you use rca cable.
Dec 20, 2007 | Technics SA-AX730 Receiver
Too many Cables??
Firstly, let me address audio cables. Optical audio is the same (essentially) as a coaxial digital audio cable, just in a different form. Since you just purchased a Bluray player, you'll see an HDMI out on the rear. This is a high definition video and audio cable rolled into one (however it looks like your receiver does not support this). I would recommend running an HDMI cable from the Bluray player right to the TV, then run an optical audio cable (or coaxial digital) from the TV to the receiver. This will give you the best picture on your TV, and the best available sound through your receiver.
Depending on your DVD player and Bluray player, you might want to consider using just the Bluray player for DVD's and Bluray discs. If your plasma supports 1080p (or really anything better than 480i), you would most likely get a better picture out of DVD's since the Bluray player will upconvert the video to the better signal (of course this depends on your exact model of Bluray player). This will help to eliminate some cabling also.
Other than that, you're not going to eliminate much more cabling. If you really want to get tricky with it, pick up some split loom wire management and wrap them up with that. Be sure to run the power and signal wires separately though! Best of luck, and hope this has helped.
Dec 20, 2007 | Audio Players & Recorders
Digital optical from DVD player produces no audio
Hi, It sounds like your receiver is still looking for audio on the coaxial connection, rather than the optical.
1. Make sure the optical connection is between your DVD player and the LD/DVD Optical In on the back of your receiver.
2. If you have a monitor connected to the receiver to show the on-screen display, click Setup from the main menu, click Input Mode, then, next to LD/DVD choose Optical. It may be set to coaxial, analog or auto.
Alternatively, choose the input source on the front of your receiver (LD/DVD), then press Input Mode button (bottom right, near the input selector) till it displays Digital Optical.
If all else fails, reset the receiver by:
1. Turn off the receiver
2. Hold down DISPLAY and PANEL UP/DOWN buttons and press power.
3. All Clear should appear on the screen.
Use caution, however, as this will erase all the settings in your receiver.
Nov 28, 2007 | Sony STR-DA90ESG
43 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
